[Ovmsdev] USSD Codes
Tue Jan 13 14:03:09 HKT 2015
This seems to be a one-liner in res/layout/dlg_pin.xml:
<EditText android:id="@+id/etxt_input_value"
android:layout_width="match_parent"
android:layout_height="wrap_content"
android:digits="0123456789"
android:password="true"
android:inputType="numberSigned" />
It seems that the re-use of the showPinDialog in so many places in the Android code is a bit restrictive.
We could try changing this to andoid:inputType textPassword.
On 12 Jan, 2015, at 1:57 am, Michael Balzer <dexter at expeedo.de> wrote:
> Hi Pierre,
> that's a known bug of the App. You currently need to use the perl client to send USSD codes.
> Command code for this is 41, so for your USSD code it's...
> ./cmd.pl 41 "*131#"
> Am 11.01.2015 um 17:33 schrieb Pierre Uhl:
>> Hi everybody,
>> I am trying to use USSD Codes. But the App (Android 3.2.2) does not accept * and # but only numbers. How can I input *131# to recharge the Prepaid SIM-Card?
>> Pierre Uhl
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150113/845d472e/attachment.html>
