[Ovmsdev] Android update 3.5.1
Christopher Cook
christopher.cook at webprofusion.com
Thu Feb 26 20:21:45 HKT 2015
Thanks Michael,
I've tried changing the settings as you've suggested but no luck so far,
I possibly need to reinstall. I'd suggest that the default be to enable
the feature and enable all connections (no connection filtering) then
let the user decide which ones they're not interested in (which will be
region specific).
Chris
On 25/02/2015 16:54, Michael Balzer wrote:
> Chris,
> 1. Check "Options > Settings > Enabled"
> 2. If the menu reads "Filtered Stations OFF" that means your filter is
> currently ON, selecting the menu will switch to OFF... not very clear
> IMO, changing that is on my list, the whole menu code is a little bit
> strange, depending on hard coded labels... Btw, same menu switching
> logic applies to the range filter.
> 3. For the filter you need to configure your connection types in the
> car menu: click on the edit pen of the car, then on the joystick icon
> in the top bar, then button "Connections".
> Am 25.02.2015 um 03:11 schrieb Christopher Cook:
>> Hi Michael,
>> I don't use the OVMS app but I tried your version on Android with the
>> demo car selected. On the Location view should I see charge points or
>> do I have to do something to make them appear by default? For me the
>> Demo car is appearing near San Jose, Filtered Stations is Off, Only
>> show Stations in range is Off.
>> Chris
