[Ovmsdev] Add ChaDeMo and CSS to car_chargemode
Wed Dec 9 17:37:47 HKT 2015
Or
car_chargetype
Mark
> On 9 Dec 2015, at 4:44 PM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
> Robert, maybe this is something you could do? As your first task in OVMS? :-)
> Geir
> Sendt fra min iPhone
>> Den 9. des. 2015 kl. 07.50 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
>> Yep, please steer clear of the car_chargermode variable. That is really badly named and is more an operation mode (like Eco/Normal on a Prius, for example). I think it is named as it is because the source on the roadster is the charger message.
>> I suggest:
>> unsigned char car_chargeplug;
>> and setup an enumeration as desired. Create it in ovms.{h,c} and then add it on the end of the ’S’ message.
>> If someone wants to commit that and send in a pull request, I’ll accept (and update the protocol guide myself).
>>> On 9 Dec 2015, at 3:10 AM, Robert Cotran <robert at cotran.ca> wrote:
>>> I like the idea of having charge type for logging purposes.
>>> I agree it shouldn't be combined with the Roadster charging types.
>>> Can just create a new "field" called connector type?
>>>> On 12/8/2015 2:07 PM, Nikki Gordon-Bloomfield wrote:
>>>> Charge type would become important if you were automatically sending charge session data back (anonymously) to the OCM database…
>>>> ᐧ
>>>> about.me/aminorjourney
>>>>> On Tue, Dec 8, 2015 at 10:46 AM, Tom Saxton <tom at idleloop.com> wrote:
>>>>> The chargemode currently encodes software charging profiles, based on what the Roadster offers. It's similar to what the early Leafs offered, charging to full or charge to 80%, but more complex setting both a charging limit and target battery temperature ranges.
>>>>> What you are proposing adding is to encode the charging connection type, which is a different kind of thing, orthogonal to the car's chosen charging profile.
>>>>> A Roadster can charge in any of the four profiles from either a Level 1 connection (120V, 12A to 16A) or Level 2 (208V to 240V at up to 70A), for example Standard mode on Level 1 or Range mode on Level 2. So, you can't encode both a charging profile and a connection type with a single number. A Leaf is similar in how those two interact.
>>>>> To me, the interesting thing is more the charge rate (V/A or kW) more than which connector my car uses. I don't need OVMS to tell me how I plugged in, but I do care about knowing how fast it's charging.
>>>>> Tom
>>>>> On 12/8/15, 10:19 AM, "Geir Øyvind Vælidalo" <ovmsdev-bounces at lists.teslaclub.hk on behalf of geir at validalo.net> wrote:
>>>>> >Hi guys,
>>>>> >I would like to have ChaDeMo and CSS added to car_chargemode, and maybe Type 1 and Type 2 too. Then we can display those names in the apps and maybe even add images for those charge plugs.
>>>>> >I would propose this:
>>>>> >0x00 - Standard
>>>>> >0x01 - Storage
>>>>> >0x02 - ???
>>>>> >0x03 - Range
>>>>> >0x04 - Performance
>>>>> >0x05 - ChaDeMo
>>>>> >0x06 - CSS
>>>>> >0x07 - J1772 Type 1
>>>>> >0x08 - Mennekes Type 2
>>>>> >What to you guys think? Would it be problematic for the server and/or apps if suddenly the Kia Souls stated sending chargemode 0x05?
>>>>> >Best regards,
>>>>> >Geir
>>>>> >_______________________________________________
>>>>> >OvmsDev mailing list
>>>>> >OvmsDev at lists.teslaclub.hk
>>>>> >http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20151209/5429286c/attachment.html>
