[Ovmsdev] Broken pipes
Mon Aug 24 05:27:32 HKT 2015
Thanks for installing the fix, all scripts now work without
disconnecting the Apps.
Btw: my Edimax smart plug script inspired another user to create a
version for the Homematic system, he gave his OK to include that as well.
It's now located under "client/homematic". It also checks the GPS
location and automatically switches the charge plug on when the car
comes home.
Coupling the OVMS with home automation systems is really easy and adds a
lot of geek value ;-)
Am 23.08.2015 um 14:36 schrieb Mark Webb-Johnson:
> Yep, that looks correct. Nice find.
>> On 22 Aug, 2015, at 1:27 am, Michael Balzer <dexter at expeedo.de
>> Mark,
>> on line 485 sub io_terminate deletes all app_conns of the vehicleid:
>> delete $app_conns{$vehicleid};
>> I changed that to delete only the $fn entry:
>> delete $app_conns{$vehicleid}{$fn};
>> ...which seems to fix the bug, my local test server no longer closes
>> all app connections as soon as one terminates.
>> Do I miss something?
>> Am 21.08.2015 um 18:01 schrieb Michael Balzer:
>>> Uh... just after sending, I remembered my new Edimax plug script running
>>> as a cron job.
>>> And indeed: the app loses the connection each time the status.pl script
>>> checks the SOC (currently once per minute).
>>> It's not related to the router / NAT, as my phone loses the connection
>>> right at the same time.
>>> Seems to be some bug in the server code regarding multiple client
>>> connections to the same vehicle id... I'll have a look.
>>> Am 21.08.2015 um 17:48 schrieb Michael Balzer:
>>>> Mark,
>>>> I've had lots of broken pipes on the car side yesterday and I've got the
>>>> same for the app side today.
>>>> Do you know of any change on the server side that could cause this?
>>>> Regards,
>>>> Michael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150823/4752710c/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150823/4752710c/attachment-0002.vcf>
