[Ovmsdev] iOS 8.4
Fri Aug 21 22:56:50 HKT 2015
A lot has changed in iOS 8, and it seems to have broken push notifications (APNS) for new users. Existing users are fine.
So, I find the few lines that need to be changed, and fixed that. Cool.
Now, submit to App Store, and Apple requires 64bit.
OK, change the building settings for a 32bit + 64bit dual package, and rebuild.
(old) Testflight sdk not compatible (32bit only).
Remove testflight sdk, and all its tendrils throughout the code base.
Rebuild.
190+ warnings about int vs long.
Crap de crap de crap.
Rebuild.
OK. All clean, built and ready to go.
Only issue is that all my working devices are IOS 9 beta (for work), and Apple’s not accepting iOS 9 built stuff yet, so I can’t properly test.
Each of the above steps needs about 15-to-45 minutes of googling.
So, I have a build (v1.6.6). It is 32bit and 64bit. It seems to work. But, I need help testing.
Seems Apple have a new test flight integrated to iTunes connect. Never tried it, but you are all about to get an invite ;-)
