[Ovmsdev] Android beta 3.9.0
Fri Apr 3 18:13:57 HKT 2015
Here's the source status for version 3.9.1:
https://github.com/openvehicles/Open-Vehicle-Android/commit/8444f06335a54e1b270d3b2da9afc7c3ee0eec13
The new tools are based on the -currently- Twizy specific historical
records, in this case
RT-PWR-BattPack
RT-PWR-BattCell
...plus the -currently- Twizy specific command code 206 "BatteryStatus".
As no other car currently can deliver this data and also as I'm lazy,
the data model & chart layout is currently tailored to the Twizy battery
pack layout. But that's easy to extend if other cars start providing the
necessary data. Btw: if the proposed record format is OK for other cars,
we should rename the records from "RT-" to "*-".
Same applies to the diag logs tool, which is currently only implemented
for SEVCON diag data but can be extended for others.
I guess the charge alerts control can be adopted for other cars most
easily. As far as I know the roadster module already provides charge
time estimations, but it seems the charge alerts and max range cannot
yet be set by the user. Maybe we can move the Twizy commands for this
into the framework.
Am 03.04.2015 um 11:05 schrieb Jille Berends:
> Testing 3.9.1 :)
> I guess I should get a Twizzy because of all the coolness coming to
> the app.
> Loving the graphs. Do you think this could be used on the Roadster
> too, or does it need specific features in the car itself?
> Also, can you update Github?
> 2015-04-03 6:00 GMT+02:00 <ovmsdev-request at lists.teslaclub.hk
> <mailto:ovmsdev-request at lists.teslaclub.hk>>:
>     Send OvmsDev mailing list submissions to
>     ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
>     To subscribe or unsubscribe via the World Wide Web, visit
>     http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>     or, via email, send a message with subject or body 'help' to
>     You can reach the person managing the list at
>     ovmsdev-owner at lists.teslaclub.hk
>     <mailto:ovmsdev-owner at lists.teslaclub.hk>
>     When replying, please edit your Subject line so it is more specific
>     than "Re: Contents of OvmsDev digest..."
>     Today's Topics:
>        1. Re: Android beta 3.9.0 (Julien (JaXX) Banchet)
>        2. Re: Android beta 3.9.0 (Michael Balzer)
>     Message: 1
>     Date: Thu, 02 Apr 2015 20:48:38 +0200
>     From: "Julien (JaXX) Banchet" <jaxx at jaxx.org <mailto:jaxx at jaxx.org>>
>     Subject: Re: [Ovmsdev] Android beta 3.9.0
>     To: OVMS Developers <ovmsdev at lists.teslaclub.hk
>     <mailto:ovmsdev at lists.teslaclub.hk>>
>     Message-ID: <551D8F06.9000801 at jaxx.org
>     <mailto:551D8F06.9000801 at jaxx.org>>
>     Content-Type: text/plain; charset="windows-1252"; Format="flowed"
>     Mark, Micheal,
>     Could this be eventually published to the Google Web Store using the
>     recently pushed ARC-Welder ?
>     I tried it out, and it's kinda cool having it on the desktop!
>     https://dl.dropboxusercontent.com/u/684235/arc_ovms_crop.jpg
>     Getting Started with ARC:
>     https://developer.chrome.com/apps/getstarted_arc
>     MfG
>     JaXX./.
>     Le 01/04/2015 19:33, Michael Balzer a ?crit :
>     > Hi Julien,
>     > thanks for reporting. Not sure how 3.9.0 could cause that, there was
>     > no db/file structure change.
>     > Last db update was in 3.8.2 with a bug that lead to wrong database
>     > creation on new installs or wiped data -- 3.8.3 fixed that, but
>     should
>     > only have needed a wipe if 3.8.2 was installed from scratch...
>     > I'm waiting for some more reports to see if there's a pattern.
>     > Regards,
>     > Michael
>     > Am 01.04.2015 um 16:41 schrieb Julien (JaXX) Banchet:
>     >> Hi Michael,
>     >> FYI, a plain update didn't make it, crashes on start (even after a
>     >> fully reboot), without a crashlog... First time an apk update
>     on OVMS
>     >> does that.
>     >> Had to wipe it
>     >> JaXX./.
>     >> Le 31/03/2015 22:50, Michael Balzer a ?crit :
>     >>> Hi everyone,
>     >>> this is a beta test release mainly for Twizy users, there's
>     just an
>     >>> updated charger plug image (created by jilleberends) for other
>     cars.
>     >>> dexters-web.de/f/tw/oVMS-release-3.9.0.apk
>     <http://dexters-web.de/f/tw/oVMS-release-3.9.0.apk>
>     >>> New function is the graphical battery monitor using the Twizy
>     >>> specific history records. Access by the options icon on the
>     battery tab.
>     >>> It concentrates on the data display for now, suggestions for later
>     >>> analysis functions are welcome.
>     >>> Data download takes up to 20 seconds depending on the data amount
>     >>> and phone capabilities, I'll add a sub progress bar for this.
>     >>> The chart engine was not suitable for this kind of chart, so I
>     >>> switched to github.com/PhilJay/MPAndroidChart
>     <http://github.com/PhilJay/MPAndroidChart>
>     >>> <https://github.com/PhilJay/MPAndroidChart> for this.
>     >>> Please test & report.
>     >>> Regards,
>     >>> Michael
>     >>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>     >>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>     >>> _______________________________________________
>     >>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL:
>     <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150402/733d5858/attachment-0001.html>
>     Message: 2
>     Date: Thu, 02 Apr 2015 21:10:28 +0200
>     From: Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>
>     To: ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
>     Message-ID: <551D9424.2050607 at expeedo.de
>     <mailto:551D9424.2050607 at expeedo.de>>
>     Hi Julien,
>     strange this rather complex part works in ARC while main tabs for
>     car /
>     maps / notifications are crashing immediately...
>     I was thinking about making a prebuilt android emulator image
>     before, as
>     having a desktop version really would be cool.
>     Meanwhile here's a new release adding the localisation and sub
>     progress
>     + fixing some bugs:
>     |http://dexters-web.de/f/tw/oVMS-release-3.9.1.apk|
>     <http://dexters-web.de/f/tw/oVMS-release-3.9.1.apk%7C>
>     Regards,
>     Michael
>     Am 02.04.2015 um 20:48 schrieb Julien (JaXX) Banchet:
>     > Mark, Micheal,
>     > MfG
>     > JaXX./.
>     >> Hi Julien,
>     there was
>     >> should only have needed a wipe if 3.8.2 was installed from
>     scratch...
>     >> Regards,
>     >> Michael
>     >>> Hi Michael,
>     >>> fully reboot), without a crashlog... First time an apk update on
>     >>> OVMS does that.
>     >>> Had to wipe it
>     >>> JaXX./.
>     >>>> Hi everyone,
>     just an
>     other cars.
>     battery
>     >>>> tab.
>     later
>     >>>> Regards,
>     >>>> Michael
>     URL:
>     <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150402/196dc775/attachment-0001.html>
>     A non-text attachment was scrubbed...
>     Type: text/x-vcard
>     Desc: not available
>     URL:
>     <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150402/196dc775/attachment-0001.vcf>
>     End of OvmsDev Digest, Vol 39, Issue 3
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150403/2f9111f9/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150403/2f9111f9/attachment-0002.vcf>
