[Ovmsdev] Android beta 3.9.0
Julien (JaXX) Banchet
jaxx at jaxx.org
Fri Apr 3 02:48:38 HKT 2015
Mark, Micheal,
Could this be eventually published to the Google Web Store using the
recently pushed ARC-Welder ?
I tried it out, and it's kinda cool having it on the desktop!
https://dl.dropboxusercontent.com/u/684235/arc_ovms_crop.jpg
Getting Started with ARC: https://developer.chrome.com/apps/getstarted_arc
MfG
JaXX./.
Le 01/04/2015 19:33, Michael Balzer a écrit :
> Hi Julien,
> thanks for reporting. Not sure how 3.9.0 could cause that, there was
> no db/file structure change.
> Last db update was in 3.8.2 with a bug that lead to wrong database
> creation on new installs or wiped data -- 3.8.3 fixed that, but should
> only have needed a wipe if 3.8.2 was installed from scratch...
> I'm waiting for some more reports to see if there's a pattern.
> Am 01.04.2015 um 16:41 schrieb Julien (JaXX) Banchet:
>> Hi Michael,
>> FYI, a plain update didn't make it, crashes on start (even after a
>> fully reboot), without a crashlog... First time an apk update on OVMS
>> does that.
>> Had to wipe it
>> JaXX./.
>> Le 31/03/2015 22:50, Michael Balzer a écrit :
>>> Hi everyone,
>>> this is a beta test release mainly for Twizy users, there's just an
>>> updated charger plug image (created by jilleberends) for other cars.
>>> dexters-web.de/f/tw/oVMS-release-3.9.0.apk
>>> <http://dexters-web.de/f/tw/oVMS-release-3.9.0.apk>
>>> New function is the graphical battery monitor using the Twizy
>>> specific history records. Access by the options icon on the battery tab.
>>> It concentrates on the data display for now, suggestions for later
>>> analysis functions are welcome.
>>> Data download takes up to 20 seconds depending on the data amount
>>> and phone capabilities, I'll add a sub progress bar for this.
>>> The chart engine was not suitable for this kind of chart, so I
>>> switched to github.com/PhilJay/MPAndroidChart
>>> <https://github.com/PhilJay/MPAndroidChart> for this.
>>> Please test & report.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20150402/733d5858/attachment.htm>
