[Ovmsdev] Android beta 3.9.0
Jille Berends
jjberends at gmail.com
Fri Apr 3 18:37:39 HKT 2015
Thanks Michael,
I'm not that advanced to create such a feature for the Roadster... but
maybe it's easier to have to server poll the car every x-minutes, and log
the last 100 SOC entries or something like that. It could provide the data
needed to create such a graph.
Also, thanks for the source code update :)
I'm planning to do some more work on the user interface this weekend, and I
just did a succesful test with more advanced notifications on my smartwatch
(android wear), I'll see if I can turn this into something useful.
Message: 2
> Date: Fri, 03 Apr 2015 12:13:57 +0200
> From: Michael Balzer <dexter at expeedo.de>
> Subject: Re: [Ovmsdev] Android beta 3.9.0
> To: ovmsdev at lists.teslaclub.hk
> Message-ID: <551E67E5.3050409 at expeedo.de>
> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
> Thanks :)
> Here's the source status for version 3.9.1:
> https://github.com/openvehicles/Open-Vehicle-Android/commit/8444f06335a54e1b270d3b2da9afc7c3ee0eec13
> The new tools are based on the -currently- Twizy specific historical
> records, in this case
> RT-PWR-BattPack
> RT-PWR-BattCell
> ...plus the -currently- Twizy specific command code 206 "BatteryStatus".
> As no other car currently can deliver this data and also as I'm lazy,
> the data model & chart layout is currently tailored to the Twizy battery
> pack layout. But that's easy to extend if other cars start providing the
> necessary data. Btw: if the proposed record format is OK for other cars,
> we should rename the records from "RT-" to "*-".
> Same applies to the diag logs tool, which is currently only implemented
> for SEVCON diag data but can be extended for others.
> I guess the charge alerts control can be adopted for other cars most
> easily. As far as I know the roadster module already provides charge
> time estimations, but it seems the charge alerts and max range cannot
> yet be set by the user. Maybe we can move the Twizy commands for this
> into the framework.
> Am 03.04.2015 um 11:05 schrieb Jille Berends:
> > Testing 3.9.1 :)
> > I guess I should get a Twizzy because of all the coolness coming to
> > the app.
> > Loving the graphs. Do you think this could be used on the Roadster
> > too, or does it need specific features in the car itself?
> > Also, can you update Github?
> > 2015-04-03 6:00 GMT+02:00 <ovmsdev-request at lists.teslaclub.hk
> > <mailto:ovmsdev-request at lists.teslaclub.hk>>:
> > Send OvmsDev mailing list submissions to
> > ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
> > To subscribe or unsubscribe via the World Wide Web, visit
> > or, via email, send a message with subject or body 'help' to
> > You can reach the person managing the list at
> > ovmsdev-owner at lists.teslaclub.hk
> > <mailto:ovmsdev-owner at lists.teslaclub.hk>
> > When replying, please edit your Subject line so it is more specific
> > than "Re: Contents of OvmsDev digest..."
> > Today's Topics:
> > 1. Re: Android beta 3.9.0 (Julien (JaXX) Banchet)
> > 2. Re: Android beta 3.9.0 (Michael Balzer)
> > Message: 1
> > Date: Thu, 02 Apr 2015 20:48:38 +0200
> > From: "Julien (JaXX) Banchet" <jaxx at jaxx.org <mailto:jaxx at jaxx.org>>
> > To: OVMS Developers <ovmsdev at lists.teslaclub.hk
> > <mailto:ovmsdev at lists.teslaclub.hk>>
> > Message-ID: <551D8F06.9000801 at jaxx.org
> > <mailto:551D8F06.9000801 at jaxx.org>>
> > Mark, Micheal,
> > Could this be eventually published to the Google Web Store using the
> > recently pushed ARC-Welder ?
> > I tried it out, and it's kinda cool having it on the desktop!
> > https://dl.dropboxusercontent.com/u/684235/arc_ovms_crop.jpg
> > Getting Started with ARC:
> > https://developer.chrome.com/apps/getstarted_arc
> > MfG
> > JaXX./.
> > Le 01/04/2015 19:33, Michael Balzer a ?crit :
> > > Hi Julien,
> > > thanks for reporting. Not sure how 3.9.0 could cause that, there
> was
> > > no db/file structure change.
> > > Last db update was in 3.8.2 with a bug that lead to wrong database
> > > creation on new installs or wiped data -- 3.8.3 fixed that, but
> > should
> > > only have needed a wipe if 3.8.2 was installed from scratch...
> > > I'm waiting for some more reports to see if there's a pattern.
> > > Regards,
> > > Michael
> > > Am 01.04.2015 um 16:41 schrieb Julien (JaXX) Banchet:
> > >> Hi Michael,
> > >> FYI, a plain update didn't make it, crashes on start (even after a
> > >> fully reboot), without a crashlog... First time an apk update
> > on OVMS
> > >> does that.
> > >> Had to wipe it
> > >> JaXX./.
> > >> Le 31/03/2015 22:50, Michael Balzer a ?crit :
> > >>> Hi everyone,
> > >>> this is a beta test release mainly for Twizy users, there's
> > just an
> > >>> updated charger plug image (created by jilleberends) for other
> > cars.
> > >>> dexters-web.de/f/tw/oVMS-release-3.9.0.apk
> > <http://dexters-web.de/f/tw/oVMS-release-3.9.0.apk>
> > >>> New function is the graphical battery monitor using the Twizy
> > >>> specific history records. Access by the options icon on the
> > battery tab.
> > >>> It concentrates on the data display for now, suggestions for
> later
> > >>> analysis functions are welcome.
> > >>> Data download takes up to 20 seconds depending on the data amount
> > >>> and phone capabilities, I'll add a sub progress bar for this.
> > >>> The chart engine was not suitable for this kind of chart, so I
> > >>> switched to github.com/PhilJay/MPAndroidChart
> > <http://github.com/PhilJay/MPAndroidChart>
> > >>> <https://github.com/PhilJay/MPAndroidChart> for this.
> > >>> Please test & report.
> > >>> Regards,
> > >>> Michael
> > >>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
> > >>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
> > >>> _______________________________________________
> > >>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL:
> http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150402/733d5858/attachment-0001.html
> > Message: 2
> > Date: Thu, 02 Apr 2015 21:10:28 +0200
> > From: Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>
> > To: ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
> > Message-ID: <551D9424.2050607 at expeedo.de
> > <mailto:551D9424.2050607 at expeedo.de>>
> > Hi Julien,
> > strange this rather complex part works in ARC while main tabs for
> > car /
> > maps / notifications are crashing immediately...
> > I was thinking about making a prebuilt android emulator image
> > before, as
> > having a desktop version really would be cool.
> > Meanwhile here's a new release adding the localisation and sub
> > progress
> > + fixing some bugs:
> > |http://dexters-web.de/f/tw/oVMS-release-3.9.1.apk|
> > <http://dexters-web.de/f/tw/oVMS-release-3.9.1.apk%7C>
> > Regards,
> > Michael
> > Am 02.04.2015 um 20:48 schrieb Julien (JaXX) Banchet:
> > > Mark, Micheal,
> the
> > > MfG
> > > JaXX./.
> > >> Hi Julien,
> > there was
> > >> should only have needed a wipe if 3.8.2 was installed from
> > scratch...
> > >> Regards,
> > >> Michael
> > >>> Hi Michael,
> a
> > >>> fully reboot), without a crashlog... First time an apk update on
> > >>> OVMS does that.
> > >>> Had to wipe it
> > >>> JaXX./.
> > >>>> Hi everyone,
> > just an
> > other cars.
> > battery
> > >>>> tab.
> > later
> amount
> > >>>> Regards,
> > >>>> Michael
> > URL:
> http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150402/196dc775/attachment-0001.html
> > A non-text attachment was scrubbed...
> > Type: text/x-vcard
> > Desc: not available
> > URL:
> http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150402/196dc775/attachment-0001.vcf
> > End of OvmsDev Digest, Vol 39, Issue 3
> URL: <
> http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150403/2f9111f9/attachment.html
> Type: text/x-vcard
> Desc: not available
> URL: <
> http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150403/2f9111f9/attachment.vcf
> End of OvmsDev Digest, Vol 39, Issue 4
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20150403/9701e219/attachment-0001.html>
