[Ovmsdev] CFG commands on RT_Production
Aatheus virtualhermit at gmail.com
Wed Sep 24 15:06:17 HKT 2014
Thank you for posting this info! I was able to get the experimental Nissan Leaf code to compile and (sort of) do useful things now. The configuration that I had to use was V2_EXPERIMENTAL. I cloned it to be V2_EXPERIMENTAL_LEAF. I set these flags:
OVMS_CAR_NONE
OVMS_HW_V2
OVMS_DIAGMODULE
OVMS_INTERNALGPS
OVMS_NISSANLEAF
OVMS_LOGGINGMODULE
OVMS_POLLER
OVMS_ODBII
OVMS_TRACK
I also excluded acc.c and all of the other vehicle source files except for these:
vehicle_nissanleaf.c
vehicle_none.c
vehicle_odbii.c
vehicle_track.c
vehicle.c
Now the hex file builds and the OVMS v2 module is able to give me a different inaccurate battery percentage (0% instead of 80%). Progress? :)
-Jeff Orr
Message: 2
Date: Mon, 22 Sep 2014 20:02:47 +0200
Subject: Re: [Ovmsdev] CFG commands on RT_Production
To: ovmsdev at lists.teslaclub.hk
Message-ID: <54206447.5010806 at expeedo.de>
Content-Type: text/plain; charset="windows-1252"; Format="flowed"
(snip)
To compile yourself you need to define these (and only these) compiler
flags:
OVMS_CAR_NONE
OVMS_CAR_RENAULTTWIZY
OVMS_HW_V2
OVMS_DIAGMODULE
OVMS_INTERNALGPS
OVMS_TWIZY_BATTMON
OVMS_TWIZY_CFG
...and you need to manually exclude source files "acc.c", "logging.c"
and all other "vehicle*.c" from the build, because otherwise...
(snip)
