[Ovmsdev] OVMS v3
William Petefish william.petefish at gmail.com
Thu Oct 16 17:53:24 HKT 2014
They do say to use 5v 2a power adaptors. BUT I'd be willing to bet that the
number was with a 2.5" HDD.
They say in a blog entry that fully powered up w/o HDD it uses ~300ma.
No word on sleep mode.
-W
On Thu, Oct 16, 2014 at 3:51 AM, Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> Any idea on power consumption at normal run? Also, any support for sleep
> mode low power?
> Regards, Mark
> On 16 Oct, 2014, at 4:32 pm, William Petefish <william.petefish at gmail.com>
> wrote:
> It cleanly shutsdown. It also has a power button and a reset button.
> It is using an entirely different processor. (Broadcom SOC for the
> raspberry pi VS Allwinner A20 for the banana pi)
> -W
> On Thu, Oct 16, 2014 at 3:22 AM, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
>> Seems to be very similar to raspberry pi - just faster cpu.
>> Presumably suffers from same issues, though - power requirements and
>> issues with unclean shutdown?
>> Regards, Mark
>> On 16 Oct, 2014, at 2:55 pm, William Petefish <william.petefish at gmail.com>
>> wrote:
>> Y'all might try the Banana Pi. I have 2. They run Linux and Android. Tons
>> of GPIO.
>> No Onboard WiFi. BUT that can be fixed with a $10 dongle. It only has one
>> CAN though. BUT another can be added via an expansion board with the
>> MicroOBD 200 module OR it can be made with a SPI-CAN uart from Microchip.
>> -W
>> On Wed, Oct 15, 2014 at 10:04 PM, Mark Webb-Johnson <
>> mark at webb-johnson.net> wrote:
>>> Kevin,
>>> An Arduino Due clone is about US$30, and a dual CAN bus shield about
>>> US$25.
>>> But, that doesn't solve the Bluetooth, Wifi, GPS, GPRS, etc, issues.
>>> The problem we are seeing is that while the hardware seems trivial, it
>>> is proving to be impossible to find. Refer back to the original list:
>>> • 32bit CPU with enough grunt, and a low-power sleep mode
>>> • Dual CAN
>>> • Async + I2C + SPI + GPIO expansion
>>> • SD-Card
>>> • USB
>>> • Lots of RAM and FLASH
>>> • Wifi
>>> • Bluetooth
>>> • Optional GSM
>>> • Optional display (or can we get away with bluetooth to a cellphone?)
>>> That is what we need. Finding it in a low-power, low-cost, framework is
>>> proving impossible. It seems that we are just too early, and I suspect than
>>> in a couple of years this will actually be trivial. While GEVCU comes
>>> close, the US$600++ pricetag is just too high. The EVTV kit doesn't even
>>> come close but still costs eight times what we have now.
>>> On 16 Oct, 2014, at 2:08 am, Kevin Sharpe <
>>> kevin.sharpe at zerocarbonworld.org> wrote:
>>> Just to be clear the EVTV CAN KIT retails at 149 USD and includes an
>>> Arduino Due board, dual channel CAN bus shield, and DB-9 to J1962 Type A
>>> ODBII cable;
>>> http://store.evtv.me/proddetail.php?prod=ArduinoDueCANBUS&cat=23
>>> This is by no means a OVMS replacement as it stands but it does give
>>> some idea of how little the base hardware should cost especially when you
>>> consider that EVTV does not strive to be the cheapest in the market by any
>>> means.
>>> In an ideal world I would like to see a family of hardware products that
>>> can scale up or down to meet the requirements of OVMS users (both power and
>>> basic) as well as those using GEVCU, CAN-KIT, JLD505, and future products.
>>> My motivation is to get developers using the same software platform and
>>> libraries because this is where we need the effort… the hardware is trivial
>>> in comparison.
>>> Kevin Sharpe | Founder & Chair of Trustees
>>> Tel: +44 122 566 7544 ext: 800 | Skype: zerocarbonworld
>>> kevin.sharpe at zerocarbonworld.org  <kevin.sharpe at zerocarbonworld.org>|
>>> www.zerocarbonworldorg <http://wwwzerocarbonworld.org/> |
>>> twitter.com/zerocarbonworld <http://twitter.com/ZCWcharlie>
>>> Zero Carbon World is a UK Registered Charity #1141347
>>> From: Mark Webb-Johnson <mark at webb-johnson.net>
>>> Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>>> Date: Wednesday, 1 October 2014 12:40
>>> Subject: Re: [Ovmsdev] OVMS v3
>>> Kevin, Colin,
>>> Last we discussed this, didn't we come to the conclusion that there
>>> wasn't enough overlap between the two projects? Different goals, and most
>>> importantly, requirements. I am also concerned about the US$600 cost of the
>>> gevcu (without stuff like bluetooth, GSM and GPS which we need) - I don't
>>> think people are going to pay that much for a telematics module.
>>> Or, have things changed?
>>> Regards, Mark
>>> On 1 Oct, 2014, at 7:07 pm, Kevin Sharpe <
>>> It’s been interesting to watch the GEVCU development and the inevitable
>>> move to a more robust hardware platform which will be based on the Cinch
>>> Enclosure and connector (version 6). Something many people wanted at the
>>> start of the project.
>>> IMO we need a robust hardware platform and the more we can focus
>>> software developers on a single platform the better for us all… my vote is
>>> hardware that’s compatible with GEVCU and the amazing libraries that exist
>>> today (including Colin’s excellent CAN library).
>>> www.zerocarbonworld.org | twitter.com/zerocarbonworld
>>> From: Collin Kidder <collink at kkmfg.com>
>>> Date: Tuesday, 30 September 2014 15:53
>>> I haven't really been involved with your OVMS project but I have
>>> continued to follow it with interest. I really like what you're doing With
>>> the GEVCU project we went through much the same discussion you're having.
>>> We obviously settled on using the Arduino Due (eventually rolling our own
>>> board based on the Cortex M3 from the Due). The MBed has many similarities
>>> to the Arduino Due hardware-wise but uses a totally different development
>>> environment and library.
>>> Ultimately I think you are making the right choice. It's very tempting
>>> to see something like the BeagleBone Black and want to go that route. But,
>>> development of code for something like the BBB is much more complicated
>>> unless you write it all in Python. LINUX is awesome on the desktop but I'm
>>> not convinced that it is worth the trouble for small embedded projects.
>>> Dealing with the complications that linux brings will just make the project
>>> more complex and difficult to jump into.
>>> I know of other people using the MBED platform for vehicle use and it
>>> seems to be going well for them. I don't see anything really wrong with
>>> MBED and I think it will serve your uses very well. In my view going with
>>> the MBED platform would serve you well and propel your project into the
>>> future.
>>> -Collin Kidder
>>> On Tue, Sep 30, 2014 at 10:34 AM, Mark Webb-Johnson <
>>>> And the winner is (or at least who I think the winner should be):
>>>> *MBED (and probably Freescale **K64F variant)*
>>>> <unknown.jpg>
>>>> Firstly, hats off to Mastro for pointing this out last year. Back then,
>>>> I didn’t think much of it - it had some good points, but I am very wary of
>>>> cloud projects, and closed source cloud terrifies me. But, in the past
>>>> year, the project has come so far, and actually using the hardware left me
>>>> very impressed.
>>>> I think our decision comes down to two choices:
>>>>    1. A Linux base, probably compute-module style, with Megabytes of
>>>>    RAM, Gigabytes of Flash, incredible flexibility but a challenge to keep
>>>>    power consumption down
>>>>    2. An embedded base, with hundreds of Kilobytes of RAM, Megabytes
>>>>    of Flash, and all the complexities that go along with embedded systems
>>>> For me, the MBED architecture now offers a viable compromise between
>>>> the two. The latest M4 processors give enough flash space (10 times what we
>>>> have in our OVMS v2 hardware CPU), and RAM (64 times what we have in our
>>>> OVMS v2 hardware CPU), that the limitation are lifted More importantly,
>>>> drag-and-drop programming means that even if flash space became an issue,
>>>> we could always just offer different firmware for different vehicles - but
>>>> this time with re-flashing being simply plugging the module into the PC and
>>>> drag-and-drop the new firmware file in place. Think of it as like having a
>>>> PICKIT built onto the board, but with the programming software being the
>>>> file manager of the operating system - the OVMS v3 module shows up as a
>>>> drive on the desktop and you just drop the new firmware onto it.
>>>> Let me explain, in a little more detail, how MBED works.
>>>>    - The MBED boards actually have two processors. The larger
>>>>    processor runs the end-user application (OVMS in our case), and the smaller
>>>>    processor makes up a system called the MBED HDK, based on the CMSIS-DAP
>>>>    standard.
>>>>    - The MBED HDK consists of a USB port (standard Micro-B type)
>>>>    connected to the MBED HDK CPU (on the board), some control circuitry, and
>>>>    an ICSP connection to the main CPU.
>>>>    - When you plug the MBED into the host O/S, it emulates a flash
>>>>    drive; dropping a file onto that drive programs the file onto the main CPU
>>>>    flash.
>>>>    - It also emulates a serial port to the host O/S so when you plug
>>>>    it in you get a serial port to the main CPU.
>>>>    - It provides a CMSIS-DAP standard debugger interface (for more
>>>>    advanced debugging).
>>>>    - The board itself can be powered from the USB, during MBED
>>>>    development or firmware updating.
>>>>    - As well as support for open source GCC toolchain (and others),
>>>>    the MBED included access to an on-line compiler - the code is kept in the
>>>>    cloud, in a shared revision control system, can be compiled there, and
>>>>    binaries downloaded for installation on the boards.
>>>>    - There are a large number of open source libraries available for
>>>>    the MBED platform.
>>>>    - Coding is in C / C++.
>>>>    - The MBED software includes a RTOS with thread support (which
>>>>    should make our job much easier than the current state-based and interrupt
>>>>    systems).
>>>>    - There are lots of low-power modes to work with.
>>>> The MBED platform provides the lowest barrier-to-entry I’ve ever seen
>>>> for embedded computing. No serial ports necessary. Just clone the project,
>>>> tweak, compile, download (with no large IDEs required). Drag-and-drop
>>>> firmware flashing.
>>>> It is also still raw in places. For example, I purchased an NXP LPC4088
>>>> MBED board to also experiment with (512KB flash, 96KB RAM, 32MB SDRAM, dual
>>>> CAN) - only to find that the firmware on the HDK for that board doesn’t
>>>> support OSX (despite the board being available for a year). That said, the
>>>> freescale K64F seems pretty close to what we want, and has no such issues
>>>> The other part of the puzzle is how we offer this. Some people want
>>>> displays, other don’t. For 2G GSM one module was fine, but for 3G we need
>>>> different modules for Asia, Europe and USA. Some want Bluetooth 2.1, others
>>>> 4.0 BLE. Some want Wifi, others want cheap. Some want expansion. etc. What
>>>> I’m thinking of is a baseboard design, with plug-in expansion modules.
>>>>    - The baseboard would contain the MBED HDK + main processor, power
>>>>    supplies, as well as connectors for vehicle, diag, expansion, and USB.
>>>>    - It would most likely be based off the K64F open source
>>>>    architecture.
>>>>    - We would have several (perhaps 4 or so) plug-in sockets on the
>>>>    baseboard, to allow expansion modules to be plugged in. Each of these
>>>>    sockets would have connections to the main processor as well as expansion
>>>>    ports.
>>>>    - The baseboard would give OVMS on 1x CAN port.
>>>>       - A 3G module would provide GSM + GPS (and would expose both
>>>>       antenna connectors to the outside world). The expansion board for this
>>>>       would be the same, but we would solder on different modules depending on
>>>>       the frequencies required.
>>>>       - A CAN expansion module would use Microchip MCP2515 controllers
>>>>       + MCP2551 transceivers (or something like it) to take SPI bus from the main
>>>>       CPU and expand CAN pins on the vehicle connector. Plug it in, and the
>>>>       system then has one or two more CAN ports available.
>>>>       - A wifi expansion module would provide WIFI connectivity.
>>>>       - A Bluetooth expansion module would use the HC-?? style
>>>>       bluetooth SPP modules. Similar to the 3G module, we can simply use the same
>>>>       expansion board - just solder on different bluetooth modules for v2.1 or
>>>>       v4.0 BLE
>>>>       - A generic expansion module could be used to add custom
>>>>       functions.
>>>>    - For the expansion modules, I’m think of two rows of connectors
>>>>    (one on each side) to provide connectivity and support. Very sturdy and
>>>>    cheap (something like this: https://www.sparkfun.com/products/10414
>>>> Anyway, those are my thoughts, and suggestions given what is available
>>>> today. I started this v3 search looking for a Linux base, and really had my
>>>> heart set on it. But I just can’t solve the power and complexity issues. To
>>>> meet the goals of having something easy to pick up, MBED really seems the
>>>> only viable option today.
>>>> But, this is no longer my project. There are now so many people
>>>> involved, and so many end-users. We are about to hit 1,000 users on the
>>>> openvehiclescom <http://openvehicles.com/> website.
>>>> So what do others think?
>>>> Regards, Mark.
>>>> On 17 Jun, 2014, at 9:06 am, Mark Webb-Johnson <mark at webb-johnson.net
>>>> <mark at webb-johnsonnet>> wrote:
>>>> Mastro,
>>>> Actually, an opportune time as I've made some progress. I'll reply to
>>>> your mail here, but take into account the follow-up discussions.
>>>>    - The requirements of the OVMS community are diverse. Some want
>>>>    pre-heating, some want relay control, some want a display, some want to
>>>>    reprogram their ECUs, some want GSM, and others want none of these. What we
>>>>    are trying to build is a framework that can be adapted by others.
>>>>    - I am stunned that nothing like this exists on the market I've
>>>>    spent the past six months looking for a low-power, low-cost, module with
>>>>    wifi+bluetooth and a development environment. Linux/RTOS/whatever. But, I
>>>>    haven't found anything perfect. I understand Kevin's frustration - it seems
>>>>    that GEVCU and OVMS could base on the same hardware, but even with that
>>>>    there appear to be difference in requirement that would just drive up costs
>>>>    for OVMS (or drive down functionality for GEVCU).
>>>>    - On the GEVCU front, I tend to agree with Rickard's comment that
>>>>    the two systems complement each other, but are very different. OVMS could
>>>>    be a telematics module for GEVCU, and would add great functionality to that
>>>>    project.
>>>>    - I spent some time looking at a modular approach. Design a base
>>>>    board with CPU, power and CAN buses. Have that base board support plug-in
>>>>    modules for wifi, bluetooth, cellular, etc. In that way, we can use
>>>>    pre-certified modules, and the user buys what they need. But, the problem
>>>>    with this approach is that if what you need is bluetooth+wifi+cellular, the
>>>>    cost is driven up considerably.
>>>>    - Talking to the China factories, it turns out that bluetooth/wifi
>>>>    is cheap as hell and trivial to implement - so long as we are ARM based.
>>>>    They laugh when we mention Microchip. They are stunned when we say we don't
>>>>    run Linux.
>>>>    - A data plan just for the car is expensive (particular in some
>>>>    countries like USA), but if we can offer hotspot functionality then it can
>>>>    be shared with other devices in the car. For that, we would need to be
>>>>    Linux based.
>>>>    - On the power front, I don't really see the problem as being low
>>>>    power while running, but rather the ability to support a sleep mode when
>>>>    the car is off. We don't need low power always - we just need it for the
>>>>    90% of the time the car is sitting idle, not charging, not driving. The CPU
>>>>    is not an issue here - they all support a deep sleep mode and we can reduce
>>>>    power requirement to quite literally a trickle. The problem is the comms.
>>>>    We need to be able to be remotely 'woken up' and keeping these
>>>>    GSM/Wifi/Bluetooth modules low power while supporting network stacks is
>>>>    just not possible. The established industry uses USSD messages to remotely
>>>>    wake up their systems, and now I understand why. A GSM module can be
>>>>    designed to be in deep sleep, with very little power usage, but still able
>>>>    to receive a USSD message.
>>>>    - GSM modules like the TELIT and SIMCOM are interesting in that
>>>>    they support running code inside the module itself This is something we
>>>>    haven't taken advantage of, but offers us the opportunity of offloading a
>>>>    significant amount of what we do.
>>>>    - For me, the requirement comes down to a base framework and module
>>>>    that supports:
>>>>    - 32bit CPU with enough grunt, and a low-power sleep mode
>>>>       - Dual CAN
>>>>       - Async + I2C + SPI + GPIO expansion
>>>>       - SD-Card
>>>>       - USB
>>>>       - Lots of RAM and FLASH
>>>>       - Wifi
>>>>       - Bluetooth
>>>>       - Optional GSM
>>>>       - Optional display (or can we get away with bluetooth to a
>>>>       cellphone?)
>>>>       - What is interesting is the advent of low-cost Linux frameworks
>>>>    that are very close to what we need. Things like the BeagleBone and
>>>>    RasberryPi are fascinating, but really designed for HDMI video output - and
>>>>    the overhead of GPU + HDMI is a huge power drain. The closest I've found to
>>>>    what we require is (
>>>>    http://compulab.co.il/products/computer-on-modules/cm-t335/) -
>>>>    pretty amazing little device - low power, wifi+bluetooth, dual CAN, up to
>>>>    512MB RAM and 1GB FLASH, for around US$50 (in horrendous quantities). I'm
>>>>    working with my contacts in China to see if we can base on a dev board
>>>>    something like that. If they can make Android phones for US$50, we should
>>>>    be able to get the guts of such a device for something similar. Then, add
>>>>    on GSM, take it from a BOM to a product, and we're probably looking at
>>>>    something still <US$150 but with so much more. The closest thing to ideal
>>>>    I've found at the moment is build a baseboard (connectors, power, CAN
>>>>    buses, etc) and have slots to take that CM-T335 module and an optional GSM
>>>>    module. But, I still think we can find something on the China market even
>>>>    closer to what we want/need.
>>>> Anyway, those are my thoughts My conclusion is that to me it seems
>>>> sensible to work from a low-power linux base with built in dual-can, wifi +
>>>> bluetooth
>>>> Regards, Mark.
>>>> OvmsDev mailing list
>>>> http://lists.teslaclubhk/mailman/listinfo/ovmsdev
>>>> <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
>>> _______________________________________________ OvmsDev mailing list
>>> <unknown.jpg>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20141016/8129b831/attachment.htm>
