[Ovmsdev] OVMS v3
William Petefish william.petefish at gmail.com
Thu Oct 16 14:55:34 HKT 2014
Y'all might try the Banana Pi. I have 2. They run Linux and Android. Tons
of GPIO.
No Onboard WiFi. BUT that can be fixed with a $10 dongle. It only has one
CAN though. BUT another can be added via an expansion board with the
MicroOBD 200 module OR it can be made with a SPI-CAN uart from Microchip.
-W
On Wed, Oct 15, 2014 at 10:04 PM, Mark Webb-Johnson <mark at webb-johnson.net>
wrote:
> Kevin,
> An Arduino Due clone is about US$30, and a dual CAN bus shield about US$25.
> But, that doesn't solve the Bluetooth, Wifi, GPS, GPRS, etc, issues.
> The problem we are seeing is that while the hardware seems trivial, it is
> proving to be impossible to find. Refer back to the original list:
> • 32bit CPU with enough grunt, and a low-power sleep mode
> • Dual CAN
> • Async + I2C + SPI + GPIO expansion
> • SD-Card
> • USB
> • Lots of RAM and FLASH
> • Wifi
> • Bluetooth
> • Optional GSM
> • Optional display (or can we get away with bluetooth to a cellphone?)
> That is what we need. Finding it in a low-power, low-cost, framework is
> proving impossible. It seems that we are just too early, and I suspect than
> in a couple of years this will actually be trivial. While GEVCU comes
> close, the US$600++ pricetag is just too high. The EVTV kit doesn't even
> come close but still costs eight times what we have now.
> On 16 Oct, 2014, at 2:08 am, Kevin Sharpe <
> kevin.sharpe at zerocarbonworld.org> wrote:
> Just to be clear the EVTV CAN KIT retails at 149 USD and includes an
> Arduino Due board, dual channel CAN bus shield, and DB-9 to J1962 Type A
> ODBII cable;
> http://store.evtv.me/proddetail.php?prod=ArduinoDueCANBUS&cat=23
> This is by no means a OVMS replacement as it stands but it does give some
> idea of how little the base hardware should cost especially when you
> consider that EVTV does not strive to be the cheapest in the market by any
> means.
> In an ideal world I would like to see a family of hardware products that
> can scale up or down to meet the requirements of OVMS users (both power and
> basic) as well as those using GEVCU, CAN-KIT, JLD505, and future products.
> My motivation is to get developers using the same software platform and
> libraries because this is where we need the effort… the hardware is trivial
> in comparison.
> Kevin Sharpe | Founder & Chair of Trustees
> Tel: +44 122 566 7544 ext: 800 | Skype: zerocarbonworld
> kevin.sharpe at zerocarbonworld.org  <kevin.sharpe at zerocarbonworld.org>|
> www.zerocarbonworldorg <http://wwwzerocarbonworld.org/> |
> twitter.com/zerocarbonworld <http://twitter.com/ZCWcharlie>
> Zero Carbon World is a UK Registered Charity #1141347
> Date: Wednesday, 1 October 2014 12:40
> Subject: Re: [Ovmsdev] OVMS v3
> Kevin, Colin,
> Last we discussed this, didn't we come to the conclusion that there wasn't
> enough overlap between the two projects? Different goals, and most
> importantly, requirements. I am also concerned about the US$600 cost of the
> gevcu (without stuff like bluetooth, GSM and GPS which we need) - I don't
> think people are going to pay that much for a telematics module.
> Or, have things changed?
> Regards, Mark
> On 1 Oct, 2014, at 7:07 pm, Kevin Sharpe <kevin.sharpe at zerocarbonworld.org>
> wrote:
> It’s been interesting to watch the GEVCU development and the inevitable
> move to a more robust hardware platform which will be based on the Cinch
> Enclosure and connector (version 6). Something many people wanted at the
> start of the project.
> IMO we need a robust hardware platform and the more we can focus software
> developers on a single platform the better for us all… my vote is hardware
> that’s compatible with GEVCU and the amazing libraries that exist today
> (including Colin’s excellent CAN library).
> www.zerocarbonworld.org | twitter.com/zerocarbonworld
> From: Collin Kidder <collink at kkmfg.com>
> Date: Tuesday, 30 September 2014 15:53
> I haven't really been involved with your OVMS project but I have continued
> to follow it with interest. I really like what you're doing. With the GEVCU
> project we went through much the same discussion you're having. We
> obviously settled on using the Arduino Due (eventually rolling our own
> board based on the Cortex M3 from the Due). The MBed has many similarities
> to the Arduino Due hardware-wise but uses a totally different development
> environment and library.
> Ultimately I think you are making the right choice. It's very tempting to
> see something like the BeagleBone Black and want to go that route. But,
> development of code for something like the BBB is much more complicated
> unless you write it all in Python. LINUX is awesome on the desktop but I'm
> not convinced that it is worth the trouble for small embedded projects.
> Dealing with the complications that linux brings will just make the project
> more complex and difficult to jump into.
> I know of other people using the MBED platform for vehicle use and it
> seems to be going well for them. I don't see anything really wrong with
> MBED and I think it will serve your uses very well. In my view going with
> the MBED platform would serve you well and propel your project into the
> future.
> -Collin Kidder
> On Tue, Sep 30, 2014 at 10:34 AM, Mark Webb-Johnson <mark at webb-johnson.net
> > wrote:
>> And the winner is (or at least who I think the winner should be):
>> *MBED (and probably Freescale **K64F variant)*
>> <unknown.jpg>
>> Firstly, hats off to Mastro for pointing this out last year. Back then, I
>> didn’t think much of it - it had some good points, but I am very wary of
>> cloud projects, and closed source cloud terrifies me. But, in the past
>> year, the project has come so far, and actually using the hardware left me
>> very impressed.
>> I think our decision comes down to two choices:
>>    1. A Linux base, probably compute-module style, with Megabytes of
>>    RAM, Gigabytes of Flash, incredible flexibility but a challenge to keep
>>    power consumption down.
>>    2. An embedded base, with hundreds of Kilobytes of RAM, Megabytes of
>>    Flash, and all the complexities that go along with embedded systems
>> For me, the MBED architecture now offers a viable compromise between the
>> two. The latest M4 processors give enough flash space (10 times what we
>> have in our OVMS v2 hardware CPU), and RAM (64 times what we have in our
>> OVMS v2 hardware CPU), that the limitation are lifted. More importantly,
>> drag-and-drop programming means that even if flash space became an issue,
>> we could always just offer different firmware for different vehicles - but
>> this time with re-flashing being simply plugging the module into the PC and
>> drag-and-drop the new firmware file in place. Think of it as like having a
>> PICKIT built onto the board, but with the programming software being the
>> file manager of the operating system - the OVMS v3 module shows up as a
>> drive on the desktop and you just drop the new firmware onto it.
>> Let me explain, in a little more detail, how MBED works.
>>    - The MBED boards actually have two processors. The larger processor
>>    runs the end-user application (OVMS in our case), and the smaller processor
>>    makes up a system called the MBED HDK, based on the CMSIS-DAP standard.
>>    - The MBED HDK consists of a USB port (standard Micro-B type)
>>    connected to the MBED HDK CPU (on the board), some control circuitry, and
>>    an ICSP connection to the main CPU.
>>    - When you plug the MBED into the host O/S, it emulates a flash
>>    drive; dropping a file onto that drive programs the file onto the main CPU
>>    flash.
>>    - It also emulates a serial port to the host O/S so when you plug it
>>    in you get a serial port to the main CPU.
>>    - It provides a CMSIS-DAP standard debugger interface (for more
>>    advanced debugging).
>>    - The board itself can be powered from the USB, during MBED
>>    development or firmware updating.
>>    - As well as support for open source GCC toolchain (and others), the
>>    MBED included access to an on-line compiler - the code is kept in the
>>    cloud, in a shared revision control system, can be compiled there, and
>>    binaries downloaded for installation on the boards.
>>    - There are a large number of open source libraries available for the
>>    MBED platform.
>>    - Coding is in C / C++.
>>    - The MBED software includes a RTOS with thread support (which should
>>    make our job much easier than the current state-based and interrupt
>>    systems).
>>    - There are lots of low-power modes to work with.
>> The MBED platform provides the lowest barrier-to-entry I’ve ever seen for
>> embedded computing. No serial ports necessary. Just clone the project,
>> tweak, compile, download (with no large IDEs required). Drag-and-drop
>> firmware flashing.
>> It is also still raw in places. For example, I purchased an NXP LPC4088
>> MBED board to also experiment with (512KB flash, 96KB RAM, 32MB SDRAM, dual
>> CAN) - only to find that the firmware on the HDK for that board doesn’t
>> support OSX (despite the board being available for a year). That said, the
>> freescale K64F seems pretty close to what we want, and has no such issues.
>> The other part of the puzzle is how we offer this. Some people want
>> displays, other don’t. For 2G GSM one module was fine, but for 3G we need
>> different modules for Asia, Europe and USA. Some want Bluetooth 2.1, others
>> 4.0 BLE. Some want Wifi, others want cheap. Some want expansion. etc. What
>> I’m thinking of is a baseboard design, with plug-in expansion modules.
>>    - The baseboard would contain the MBED HDK + main processor, power
>>    supplies, as well as connectors for vehicle, diag, expansion, and USB.
>>    - It would most likely be based off the K64F open source architecture.
>>    - We would have several (perhaps 4 or so) plug-in sockets on the
>>    baseboard, to allow expansion modules to be plugged in. Each of these
>>    sockets would have connections to the main processor as well as expansion
>>    ports.
>>    - The baseboard would give OVMS on 1x CAN port.
>>       - A 3G module would provide GSM + GPS (and would expose both
>>       antenna connectors to the outside world). The expansion board for this
>>       would be the same, but we would solder on different modules depending on
>>       the frequencies required.
>>       - A CAN expansion module would use Microchip MCP2515 controllers +
>>       MCP2551 transceivers (or something like it) to take SPI bus from the main
>>       CPU and expand CAN pins on the vehicle connector. Plug it in, and the
>>       system then has one or two more CAN ports available.
>>       - A wifi expansion module would provide WIFI connectivity.
>>       - A Bluetooth expansion module would use the HC-?? style bluetooth
>>       SPP modules. Similar to the 3G module, we can simply use the same expansion
>>       board - just solder on different bluetooth modules for v2.1 or v4.0 BLE.
>>       - A generic expansion module could be used to add custom functions.
>>    - For the expansion modules, I’m think of two rows of connectors (one
>>    on each side) to provide connectivity and support. Very sturdy and cheap
>>    (something like this: https://www.sparkfun.com/products/10414).
>> Anyway, those are my thoughts, and suggestions given what is available
>> today. I started this v3 search looking for a Linux base, and really had my
>> heart set on it. But I just can’t solve the power and complexity issues. To
>> meet the goals of having something easy to pick up, MBED really seems the
>> only viable option today.
>> But, this is no longer my project. There are now so many people involved,
>> and so many end-users. We are about to hit 1,000 users on the
>> openvehicles.com website.
>> So what do others think?
>> On 17 Jun, 2014, at 9:06 am, Mark Webb-Johnson <mark at webb-johnson.net>
>> wrote:
>> Mastro,
>> Actually, an opportune time as I've made some progress. I'll reply to
>> your mail here, but take into account the follow-up discussions.
>>    - The requirements of the OVMS community are diverse. Some want
>>    pre-heating, some want relay control, some want a display, some want to
>>    reprogram their ECUs, some want GSM, and others want none of these. What we
>>    are trying to build is a framework that can be adapted by others.
>>    - I am stunned that nothing like this exists on the market. I've
>>    spent the past six months looking for a low-power, low-cost, module with
>>    wifi+bluetooth and a development environment. Linux/RTOS/whatever. But, I
>>    haven't found anything perfect. I understand Kevin's frustration - it seems
>>    that GEVCU and OVMS could base on the same hardware, but even with that
>>    there appear to be difference in requirement that would just drive up costs
>>    for OVMS (or drive down functionality for GEVCU).
>>    - On the GEVCU front, I tend to agree with Rickard's comment that the
>>    two systems complement each other, but are very different. OVMS could be a
>>    telematics module for GEVCU, and would add great functionality to that
>>    project.
>>    - I spent some time looking at a modular approach. Design a base
>>    board with CPU, power and CAN buses. Have that base board support plug-in
>>    modules for wifi, bluetooth, cellular, etc. In that way, we can use
>>    pre-certified modules, and the user buys what they need. But, the problem
>>    with this approach is that if what you need is bluetooth+wifi+cellular, the
>>    cost is driven up considerably.
>>    - Talking to the China factories, it turns out that bluetooth/wifi is
>>    cheap as hell and trivial to implement - so long as we are ARM based. They
>>    laugh when we mention Microchip. They are stunned when we say we don't run
>>    Linux.
>>    - A data plan just for the car is expensive (particular in some
>>    countries like USA), but if we can offer hotspot functionality then it can
>>    be shared with other devices in the car. For that, we would need to be
>>    Linux based.
>>    - On the power front, I don't really see the problem as being low
>>    power while running, but rather the ability to support a sleep mode when
>>    the car is off. We don't need low power always - we just need it for the
>>    90% of the time the car is sitting idle, not charging, not driving. The CPU
>>    is not an issue here - they all support a deep sleep mode and we can reduce
>>    power requirement to quite literally a trickle. The problem is the comms.
>>    We need to be able to be remotely 'woken up' and keeping these
>>    GSM/Wifi/Bluetooth modules low power while supporting network stacks is
>>    just not possible. The established industry uses USSD messages to remotely
>>    wake up their systems, and now I understand why. A GSM module can be
>>    designed to be in deep sleep, with very little power usage, but still able
>>    to receive a USSD message.
>>    - GSM modules like the TELIT and SIMCOM are interesting in that they
>>    support running code inside the module itself. This is something we haven't
>>    taken advantage of, but offers us the opportunity of offloading a
>>    significant amount of what we do.
>>    - For me, the requirement comes down to a base framework and module
>>    that supports:
>>    - 32bit CPU with enough grunt, and a low-power sleep mode
>>       - Dual CAN
>>       - Async + I2C + SPI + GPIO expansion
>>       - SD-Card
>>       - USB
>>       - Lots of RAM and FLASH
>>       - Wifi
>>       - Bluetooth
>>       - Optional GSM
>>       - Optional display (or can we get away with bluetooth to a
>>       cellphone?)
>>       - What is interesting is the advent of low-cost Linux frameworks
>>    that are very close to what we need. Things like the BeagleBone and
>>    RasberryPi are fascinating, but really designed for HDMI video output - and
>>    the overhead of GPU + HDMI is a huge power drain. The closest I've found to
>>    what we require is (
>>    http://compulab.co.il/products/computer-on-modules/cm-t335/) - pretty
>>    amazing little device - low power, wifi+bluetooth, dual CAN, up to 512MB
>>    RAM and 1GB FLASH, for around US$50 (in horrendous quantities). I'm working
>>    with my contacts in China to see if we can base on a dev board something
>>    like that. If they can make Android phones for US$50, we should be able to
>>    get the guts of such a device for something similar. Then, add on GSM, take
>>    it from a BOM to a product, and we're probably looking at something still
>>    <US$150 but with so much more. The closest thing to ideal I've found at the
>>    moment is build a baseboard (connectors, power, CAN buses, etc) and have
>>    slots to take that CM-T335 module and an optional GSM module. But, I still
>>    think we can find something on the China market even closer to what we
>>    want/need.
>> Anyway, those are my thoughts. My conclusion is that to me it seems
>> sensible to work from a low-power linux base with built in dual-can, wifi +
>> bluetooth.
> <unknown.jpg>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20141016/eec38ecb/attachment.htm>
