[Ovmsdev] module GPRS connection frequency
Lee Howard lee.howard at mainpine.com
Tue Oct 28 05:17:32 HKT 2014
For those of you using unlimited data plans this may not matter, but for
those of us using per-use/per-minute/per-MB plans the frequency at which
the OVMS module connects via GPRS to the OVMS server is quite relevant
for the long-term cost of using OVMS.
For example, I'm using AT&T "GoPhone" per-minute plans which basically
result in a $0.01 charge every time the OVMS module connects via GPRS to
the OVMS server.  The OVMS module does this a bit more-frequently than I
had anticipated... about 3X more frequently.  Consequently, I was a bit
surprised to find what I had hoped to be a $100-per-year account get
used faster than that... requiring me to add $100 to the account every
four months or so.  So the per-minute/per-use/per-MB plan I'm on ends up
not really being less-expensive than their $25 per-month plan.
I see that the OVMS module is connecting with the OVMS server roughly
every 7 minutes... even if the car is stationary and there have been no
changes to SOC or other vehicle information.  I see this behaviour both
with module type "VA" and "XX".
I would prefer to see the OVMS module connect with the server with
*greater* regularity (like, every 2 minutes) when GPS position is
changing (more than the expected 60-meter or so "jitter" that I usually
see) or when SOC is changing or some other information changes.
However, if the vehicle is stationary and there are no SOC changes or
other information changes, then I would prefer to see the OVMS module
connect to the OVMS server very infrequently... like only every 30-90
minutes.
Is this, by chance, something configurable?  Or is this something that
I'm going to need to build-into the firmware, myself?
Thanks,
Lee.
*Lee Howard*
*Mainpine, Inc. Chief Technology Officer*
Tel: +1 866 363 6680 | Fax: +1 360 462 8160
lee.howard at mainpine.com | www.mainpine.com
