[Ovmsdev] Can't set OVMS time zone
Wed Nov 26 15:38:43 HKT 2014
Tom,
Is your iPhone on the latest iOS? There was a bug in 8.0 that caused this.
Also, is the OVMS App up-to-date?
The latest OVMS App on the latest iOS should be fine. I have iOS v8.1.1 and App v1.6.4, and it seems on work fine on that combination.
P.S. History:
  1] last betas of iOS 8 had this problem
  2] We changed the App to work around the problem (thinking apple had changed the view container hierarchy)
  3] iOS 8 was released, as was our App, and all was fine.
  4] iOS 8.0.1 was released, reverting to old iOS 7 style view container hierarchy, and we were broken again
  5] We released an updated App to resolve the problem (revert to our old behaviour)
On 26 Nov, 2014, at 3:28 pm, Tom Saxton <tom at idleloop.com> wrote:
> I'm having problems setting the time zone from the iPhone app. When I try
> to change parameter #23 from -07:00 to -08:00 (or simply -8, or even
> -07:00), I get a "parameter out of range" error.
> The server log says:
> 2014-11-26 07:23:11 C 4 -200 -07:00
> 2014-11-26 07:23:14 c 4 1 Parameter out of range
> 2014-11-26 07:23:18 C 4 -200
> 2014-11-26 07:23:22 c 4 1 Parameter out of range
> 2014-11-26 07:23:29 C 4 -200 -08:00
> 2014-11-26 07:23:32 c 4 1 Parameter out of range
> 2014-11-26 07:24:02 C 4 -200
> 2014-11-26 07:24:05 c 4 1 Parameter out of range
> 2014-11-26 07:24:12 C 4 -200 -07:00
> 2014-11-26 07:24:16 c 4 1 Parameter out of range
> Is anyone else having this issue?
> I do have a few small changes in my version of the firmware, but nothing
> anywhere near the parameter setting code.
>   Tom
