[Ovmsdev] How to get a quick and reliable GPS fix
Arthur Hebert
ahebert at gmail.com
Thu Nov 6 05:26:03 HKT 2014
Thanks for the info Christopher and Michael! I'll try it without resetting,
and see if that helps.
-Arthur
On Wed, Nov 5, 2014 at 4:20 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Hi Arthur,
> the SIM908 hardware design doc says:
> *Power down mode: The GPS engine will be set into this mode by sending AT
> command “AT+CGPSPWR=0”. In this mode the internal power supply for GPS will
> be shutdown, and the current consumption is very low. The last position,
> current time and ephemeris data will be stored in the GSM host memory.*
> ...and...
> *User can power on GPS engine by sending AT command “AT+CGPSPWR=1”. *
> So it seems a GPS reset is not necessary after a software power down /
> sleep state, I'd first try without.
> If you find out you need to do a reset, I'd first try to cope with "hot" /
> "warm". The command manual says:
> *COLD start mode is recommended For first time reset.*
> So I think this is normally only needed for the first power up.
> Am 04.11.2014 um 17:42 schrieb Arthur Hebert:
> Hi All,
> Does anyone know the details of how, most reliably and most quickly, to
> get a location fix from the GPS module after it has been powered up and
> after it has come out of sleep mode?
> I have written my own code using the OVMS hardware. To save power, it
> turns off the GPS power (AT+CGPSPWR=0) and puts the module to sleep
> (AT+CSCLK=2) while the vehicle is parked (i.e. no CAN bus activity). Once
> there is CAN activity again, it comes out of sleep mode (AT+CSCLK=0) and
> turns on the GPS (AT+CGSPPWR=1). Immediately after turning on the GPS
> power, I also issue one of the GPS reset commands (AT+CGPSRS=0 or
> AT+CGPSRST=1).
> The module documentation if vague about when to use the 0 reset or the 1
> reset.
> I know that the GPS module itself isn't made to function while the
> module is asleep even though the commands may not give an error.
> I've read that it takes up to 15 minutes to get a fix on most GPS
> devices. In practice, sometimes I get a fix within a minute every time I
> start up, and other times I don't get a fix even after hours of trying with
> either reset option.
> Any information will be greatly appreciated.
> Thanks,
> Arthur
> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20141105/a21c076e/attachment.html>
