[Ovmsdev] PICkit changes parameters (EEPROM)
Sat May 31 23:40:49 HKT 2014
I've never had anything like that happen and I've flashed my device plenty
of times when doing occasional coding. I have blasted it to all zeros a
few times, which I attribute to forgetting to flip that setting either in
the MPLab project or in the PICkit2 downloader.
Perhaps you have a bad chip or a bad programmer?
Very curious.
   Tom
-----Original Message-----
Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
Date: Saturday, May 31, 2014 at 6:19 AM
Subject: [Ovmsdev] PICkit changes parameters (EEPROM)
>Hi all,
>my PICkit2 frequently alters single EEPROM cells on flashing. It's set
>to "preserve EEPROM" and mostly does so, the effect only for example
>changes the server parameter from "64..." to "S4...".
>Other parameter slots also have been affected, my last flash changed my
>registered phone id, and a forum member reports a change of the first
>vehicle id byte from "D" to "R".
>Is there a way to make the flashing process reliably preserve the EEPROM?
>Thanks,
>Michael
>Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>_______________________________________________
>OvmsDev mailing list
>OvmsDev at lists.teslaclub.hk
>http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
