[Ovmsdev] GEVCU 5 hardware
Kevin Sharpe
kevin.sharpe at zerocarbonworld.org
Mon May 19 20:46:43 HKT 2014
The CINCH case is lovely and it looks as if it would be pretty easy to
produce hardware that is compatible with OVMS/GEVCU and bring out GPS, GSM,
and WiFi antennas on the rear panel leaving the exiting 30 pin connector for
I/O. Bluetooth would use an internal antenna.
I¹ll ask my colleagues to investigate the possibility of porting the OVMS
software to the AT915AM3X8E used on the Arduino DUE. I¹ll also look into
realistic build costs for the hardware.
Kevin Sharpe | Founder & Patron | Zero Carbon World is a UK Registered
Charity #1141347
Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
Date: Thursday, 15 May 2014 13:13
Subject: Re: [Ovmsdev] GEVCU 5 hardware
Kevin,
Do you have anything on target pricing for GEVCU v3?
While there is some synergy between the two projects, when I looked at GEVCU
v2 last year, my three biggest concerns were:
1. I/O: GEVCU was more about digital I/O and PWM, while OVMS needs a bunch
of different comms options (mostly async).
2.
3.
4. Price: GEVCU retails for US$595 (vs US$99 for OVMS v2).
5.
6.
7. Power consumption: In general, units like GEVCU are designed to be on
when the car is driving or charging, and off at other times. Doing
telematics separately seems a sensible approach.
I was wondering about a hybrid approach. Some of the GSM units (like the
SIMCOM OVMS uses) can run user programs alongside the traditional modem and
have I/O. All the telematics could run on such a processor (always on) and
an I/O line could be used to wake up the GEVCU if required. But, such an
arrangement would be far from trivial and a stretch for a hobbyist approach.
A dual-processor, dual-firmware, system is much more complex to maintain and
keep up-to-date.
Regarding full linux boxes (like raspberry pi, beagle bone, etc), my concern
is power consumption. It would be wonderful to have a linux base, but the
overhead is horrendous.
On 15 May, 2014, at 6:55 pm, Kevin Sharpe <kevin.sharpe at zerocarbonworld.org>
wrote:
> Hi Rob,
> I¹ll send a complete GEVCU 5 hardware list when I get a moment. It¹s based on
> a Arduino Due architecture with a 84Mhz 32-bit microcontroller :-)
> Here¹s a link to the enclosure which is IP67/69 (submersible!)
> http://www.cinch.com/products/modular-integrated-connector-enclosure
> <MODIce_enclosure.png>
> Kevin Sharpe | Founder & Patron | Zero Carbon World is a UK Registered Charity
> #1141347
> From: Robert Sharpe <robert.sharpe at evergreen-consulting.co.uk>
> Date: Thursday, 15 May 2014 11:31
> Hi Kevin,
> It seems sensible to assess the opportunity.
> If someone more informed than me can list the relative features, potential and
> cost of the two units then that would put us in a better position to comment.
> Rob
> ---- On Thu, 15 May 2014 11:00:50 +0100 Kevin Sharpe
> <kevin.sharpe at zerocarbonworld.org> wrote ----
>> Version 5 of the Generalised Electric Vehicle Control Unit (GEVCU) will
>> include BT, WiFi, and isolated I/O in a low cost and rugged automotive
>> enclosure. Many of the things on my OVMS wish list!
>> GEVCU development is progressing well and I¹ve suggested they add GPS as an
>> option in the final version;
>> https://groups.google.com/forum/#!forum/gevcu-development
>> Would their be any interest in porting OVMS to the GEVCU hardware? Or even in
>> merging the projects possibly?
>> I ask this because the more resources we can bring to the project the more
>> likely it is to flourish.
>> Charity #1141347
> OvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
> <MODIce_enclosure.png>_______________________________________________
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140519/95fe57b5/attachment-0001.html>
Type: image/jpeg
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140519/95fe57b5/attachment-0002.jpe>
Type: image/jpeg
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140519/95fe57b5/attachment-0003.jpe>
