[Ovmsdev] Just up and running with OVMS (leaf)
Nigel Jones
nigel at cherrybyte.me.uk
Sun May 4 00:35:47 HKT 2014
Thanks.. it didn't seem to work, so I figured I'd reset via the programmer
- then for some reason pc originally used wouldn't work. All
reflashed/reset ok now via laptop, I don't know the mplab sw well but
suspect something's amiss with the drivers. Still I'm run out of time today
and at least it's all configured correctly now (type NL) and I've proven
ability to build. So a decent start before launching into the code. Not
tried debugging yet. Thanks for the tips. Close shave this afternoon ;-)
On 3 May 2014 17:26, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Just re-send the MODULE command to redefine the vehicle type.
> On 3 May, 2014, at 10:25 pm, Nigel Jones <nigel at cherrybyte.me.uk> wrote:
> Hi,
> Just a quick update. As of yesterday all my hardware arrived so I spent
> an hour or two this morning setting up OVMS
> I have the toolchain sorted, and was able to build the v2 experimental fw
> from source. This incldues a definition of OVMS_CAR_NISSANLEAF so should
> load the leaf prototype module
> The firmware also flashed fine though I had to use the standalone flash
> tool rather than the IDE for this step as I couldn't find the option to
> provide 5V from the programmer? Never mind....
> Once flashed I was able to go through updatign password, registering,.
> including on openvehicles website. I can chat via SMS, and can see the car
> in the android app. I can get GPS data and check firmware revision.
> Great.
> I did though when configuring specify a vehicle type of "LE"
> +44NNNNNNNNNN:Module:
> VehicleID:XXX
> VehicleType:LE
> Units:K
> Notifications:SMSIP 9:36 AM
> Me:MODULE XXX K SMSIP LE 9:36 AM
> I then updated this by replacing the correct "NL" for LE, but now I just
> get back:
> VehicleID:JN1FAAZE0U0005853
> VehicleType:
> Units:K
> Notifications:SMSIP
> NO idea why vehicle type is NULL. I tried a reset. I was thinking I may
> reset the config completely, but have I done anything obviously wrong? Is
> it possible to change vehicle type once set?
> Very early stages of learning... with the intent of course to refine the
> leaf support :-)
> Nigel.
> Nigel Jones
Nigel Jones
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140503/a8c378a7/attachment.html>
