[Ovmsdev] v2.6.5 Firmware
Mon Mar 10 21:58:20 HKT 2014
http://www.openvehicles.com/node/136
Vehicle firmware v2.6.5 has been pushed to github. It is tagged (as v2.6.5) and we have uploaded pre-built .hex files in the vehicle/firmware directory.
2014-03-10 2.6.5 Firmware 2.6.5
# Change car_tmotor to signed int
# Call vehicle_fn_poll0() in OVMS_POLLER, if no poll list defined
# Twizy release 3.2.0
# EEPROM CFG profile storage (3 custom profiles)
# CFG profile management commands: LOAD, SAVE, INFO
# CFG profile selection & display via simpl
# Tesla Roadster: Treat TBattery as signed
# ACC: Add a RADIUS parameter, supporting geo-fencing per acc locations
# ACC: Route MSG commands through to ACC (for special handling)
# ACC: Support charge, stop, and cooldown overrides
2014-01-19 2.6.2 Firmware 2.6.2
# Remove duplicate car_stale_* decrements in individual vehicle modules
# Updates to vehicle_thinkcity
# Mitsubishi: tbergo changes 1.5 ... 1.8
# Move can bus low level register access to vehicle.c,
# (out of individual vehicle modules)
# OBDII: Implementation using new vehicle polling framework
# Structural changes to support new vehicle polling framework
# Changes to crypt_md5 library to save 62 bytes of initialised ram
# GSM clock polling, Request, and sync, GSM time
# Fix to doors2 bits
# Some work on nissan leaf
# Fixed QC detection and 12V alarm issue
# Twizy V3.0.2: CFG TSMAP allows 0..100 for levels 2..4
# Twizy version 3.1.0:
# TSMAP: levels 1..4 now allow 0%
# Power map generator extended for pwr max lo/hi, added sanity check
# Renamed command "POWER" to "DRIVE", "TORQUE" to "POWER",
# Changed param handling
# Twizy 3.1.1:
# SDO segmented upload support (readsdo_buf)
# new command: CFG READS (read string), CFG WRITEO (write only)
# Error counter hardening (counter reset by CFG command)
# Twizy V3.1.2:
# access to SEVCON logs / monitoring
# new command: MSG 209 = CMD_ResetLogs
# new command: MSG 210 = CMD_QueryLogs
# active faults log included with fault alert
# added Twizy client scripts
# Switch to extended mode compilation
# car_ambient_temp, car_tpem, car_tmotor and car_tpms_t to signed int
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140310/1156bf7c/attachment.html>
