[Ovmsdev] SEVCON ALERT
Gianluca Magalotti gianluca at magalotti.net
Mon Jun 30 17:59:33 HKT 2014
Thankyou both
I'll check with Renault asap
Il 30/giu/2014 00:40 <ovmsdev-request at lists.teslaclub.hk> ha scritto:
> Send OvmsDev mailing list submissions to
>         ovmsdev at lists.teslaclub.hk
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         ovmsdev-owner at lists.teslaclub.hk
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OvmsDev digest..."
> Today's Topics:
>    1. Re: SEVCON ALERT (Michael Balzer)
>    2. Re: SEVCON ALERT (Julien (JaXX) Banchet)
> Message: 1
> Date: Sun, 29 Jun 2014 23:08:43 +0200
> From: Michael Balzer <dexter at expeedo.de>
> Subject: Re: [Ovmsdev] SEVCON ALERT
> To: ovmsdev at lists.teslaclub.hk
> Message-ID: <53B0805B.8000607 at expeedo.de>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Gianluca,
> there's a fault code list in the SEVCON DVT package, you can find it on
> the web.
> Info from that list:
> Description: "Throttle appears to be stuck. This fault will clear if
> throttle starts to work again."
> Recommended action: "Check throttle wiring and installation."
> There once was a throttle service callback concerning mechanically stuck
> pedals, maybe that's the cause?
> But first check if the fault persists.
> Am 29.06.2014 22:42, schrieb Gianluca Magalotti:
> > Tonight I've received on my app the following message:
> > SEVCON ALERT 0x4582 Safety Case 1
> > What does it mean?
> > *Gianluca*
> > Il giorno 29/giu/2014, alle ore 06:00,
> >> ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
> >> Today's Topics:
> >>   1. Re: changing android app server IP (Tom Saxton)
> >>   2. Re: changing android app server IP (Lee Howard)
> >> Message: 1
> >> Date: Sat, 28 Jun 2014 09:28:52 -0700
> >> From: Tom Saxton <tom at idleloop.com>
> >> Subject: Re: [Ovmsdev] changing android app server IP
> >> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
> >> Message-ID: <CFD43A7E.6BBAD%tom at idleloop.com>
> >> Content-Type: text/plain;charset="US-ASCII"
> >> I just downloaded the Android Open Vehicle app and configured it for our
> >> Roadster. It gives me an error message that it can't connect and
> >> recommends checking my passwords. I've double-checked the passwords and
> I
> >> think they are right.
> >> I don't see anywhere to enter my OVMS server user name, which the iOS
> app
> >> requires. Is that the problem?
> >>    Tom
> >> -----Original Message-----
> >> From: Mark Webb-Johnson <mark at webb-johnson.net>
> >> Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
> >> Date: Saturday, June 28, 2014 at 6:06 AM
> >>> Lee,
> >>> Looks good. I merged it, and submitted v3.2.2 to google play.
> >>> Regards, Mark.
> >>> On 28 Jun, 2014, at 3:44 am, Lee Howard <lee.howard at mainpine.com>
> wrote:
> >>>> On 06/27/2014 10:38 AM, Lee Howard wrote:
> >>>>> On 06/26/2014 08:38 PM, Tom Saxton wrote:
> >>>>>> Arguably the server account should be per-vehicle but I'm
> >>>>>> guessing the
> >>>>>> thought was that anyone who has multiple OVMS vehicles will have
> them
> >>>>>> all
> >>>>>> on the same server and making that app-wide means you only have to
> >>>>>> enter
> >>>>>> username, password and server IP once.
> >>>>>> Of course none of this is any help for figuring out how to do it on
> >>>>>> Android...
> >>>>> As I dug-into the Android code better to hard-code the address change
> >>>>> I discovered - to my delight - that the app server address is
> >>>>> stored in
> >>>>> a per-car data object.  Yay!  So this is nice.  I'm going to give
> this
> >>>>> another shot.
> >>>> Here is the patch.  Someone with privs can apply it and commit these
> >>>> changes to the repository if it meets with their approval.
> >>>> It's a very small enhancement - basically permitting an interface to
> >>>> sel_server in the CarData object.  The interface is right where it
> >>>> should be, IMO: right where you enter the vehicle info and passwords.
> >>>> The default is left to "tmc.openvehicles.com", but the user now has
> the
> >>>> capability to modify it (on a per-car basis, even).
> >>>> I did not change the sel_server initialization value of
> >>>> "tmc.openvehicles.com".  I could have changed this to "" as with the
> >>>> other CarData strings, but it probably makes little difference.
> Leaving
> >>>> it to initialize with "tmc.openvehicles.com" possibly it could be
> >>>> confusing to someone later who doesn't recognize that the initialized
> >>>> value is always overwritten by the configured value (as with the other
> >>>> CarData strings which are initialized to "").  If someone cares
> >>>> they can
> >>>> modify that at the top of CarData.java.
> >>>> This patch also makes one obvious grammatical correction in a string
> >>>> appearing on the same page layout.
> >>>> If there is any concern just look at the patch - it's a very, very
> >>>> benign set of changes.  This e-mail is longer than the patch is.
> >>>> Thanks,
> >>>> Lee.
> >>>> *Lee Howard*
> >>>> *Mainpine, Inc. Chief Technology Officer*
> >>>> Tel: +1 866 363 6680 | Fax: +1 360 462 8160
> >>>> lee.howard at mainpine.com | www.mainpine.com
> <ovms-android-editserver.patch>__________________________________________
> >>>> _____
> >>>> OvmsDev at lists.teslaclub.hk
> >>> _______________________________________________
> >> Message: 2
> >> Date: Sat, 28 Jun 2014 10:05:43 -0700
> >> From: Lee Howard <lee.howard at mainpine.com>
> >> Message-ID: <53AEF5E7.1060806 at mainpine.com>
> >> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> >> I'm using my built .apk instead of the one from Google Play, but my
> >> source code is now identical to the one in the git repository.
> >> Mine is working fine for me.
> >> Admittedly, I do get confused about which one is the server password and
> >> which one is the module password, and so I just swap them around if I
> >> get the password error.  Maybe the Android app has the two mixed-up?
> >> As for the app not needing the your account username... I've never
> >> needed it on the Android app before.  I think that it just uses the car
> >> info.
> >> Thanks,
> >> Lee.
> our
> >>> and I
> >>> iOS app
> >>>     Tom
> >> *Lee Howard*
> >> End of OvmsDev Digest, Vol 29, Issue 73
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140629/55996af9/attachment-0001.html
> A non-text attachment was scrubbed...
> Type: text/x-vcard
> Desc: not available
> URL: <
> http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140629/55996af9/attachment-0001.vcf
> Message: 2
> Date: Mon, 30 Jun 2014 00:40:29 +0200
> From: "Julien (JaXX) Banchet" <jaxx at jaxx.org>
> Message-ID: <etPan.53b095dd.2ae8944a.d56e at jBookPro.local>
> Content-Type: text/plain; charset="utf-8"
> Hi,
> Renault isn?t to my experience very good at callbacks (they ??forgot?? to
> do my callback about the power line water infiltration issue). That said
> yeah, I confirm, there is a callback on badly responding pedals,
> ??logically?? stuck and/or ??physically?? slow to come back to initial
> position. I don?t know how the sevcon determinates the state but well, give
> Renault a call with the VIN number and they?ll tell you for sure or call
> you in for a checkup (as sometimes out of series VIN remain affected, I had
> a non responding pedal effect a couple of times in the past, barely
> noticeable as you rekick it in by reflex within a second, didn?t have the
> OVMS yet at the time)
> JaXX./.
> PS: The throttle issue can be accentuated by cold weather I?ve heard on
> french forums? which can be the case as? well? summer still hasn?t showed
> up everywhere yet ;-)
> De:?Michael Balzer <dexter at expeedo.de>
> R?pondre:?OVMS Developers <ovmsdev at lists.teslaclub.hk>>
> Date:?29 juin 2014 at 23:08:54
> ?:?ovmsdev at lists.teslaclub.hk <ovmsdev at lists.teslaclub.hk>>
> Sujet:? Re: [Ovmsdev] SEVCON ALERT
> > Gianluca,
> > the web.
> > Regards,
> > Michael
> > > What does it mean?
> > > *Gianluca*
> > >> Today's Topics:
> > >> Message: 1
> > >> From: Tom Saxton
> > >> To: OVMS Developers
> > >> Message-ID:
> our
> and I
> app
> > >> Tom
> > >> To: OVMS Developers
> > >>> Lee,
> > >>> Regards, Mark.
> > >>>>>> guessing the
> them
> > >>>>>> all
> > >>>>>> enter
> on
> > >>>>>> Android...
> change
> > >>>>> stored in
> > >>>>> a per-car data object. Yay! So this is nice. I'm going to give this
> > >>>>> another shot.
> passwords.
> has the
> Leaving
> initialized
> other
> > >>>> they can
> > >>>> Thanks,
> > >>>> Lee.
> > >>>> *Lee Howard*
> > >>>> _____
> > >> Message: 2
> > >> From: Lee Howard
> and
> > >> info.
> > >> Thanks,
> > >> Lee.
> our
> > >>> and I
> > >>> iOS app
> > >>> Tom
> > >> *Lee Howard*
> End of OvmsDev Digest, Vol 29, Issue 75
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140630/840409d1/attachment.htm>
