[Ovmsdev] SEVCON ALERT
Mon Jun 30 05:08:43 HKT 2014
Gianluca,
there's a fault code list in the SEVCON DVT package, you can find it on
the web.
Info from that list:
Description: "Throttle appears to be stuck. This fault will clear if
throttle starts to work again."
Recommended action: "Check throttle wiring and installation."
There once was a throttle service callback concerning mechanically stuck
pedals, maybe that's the cause?
But first check if the fault persists.
Am 29.06.2014 22:42, schrieb Gianluca Magalotti:
> Tonight I've received on my app the following message:
> SEVCON ALERT 0x4582 Safety Case 1
> What does it mean?
> *Gianluca*
> Il giorno 29/giu/2014, alle ore 06:00,
> ovmsdev-request at lists.teslaclub.hk
> <mailto:ovmsdev-request at lists.teslaclub.hk> ha scritto:
>> Send OvmsDev mailing list submissions to
>> ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
>> To subscribe or unsubscribe via the World Wide Web, visit
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> ovmsdev-owner at lists.teslaclub.hk
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of OvmsDev digest..."
>> Today's Topics:
>> 1. Re: changing android app server IP (Tom Saxton)
>> 2. Re: changing android app server IP (Lee Howard)
>> Message: 1
>> Date: Sat, 28 Jun 2014 09:28:52 -0700
>> From: Tom Saxton <tom at idleloop.com>
>> Subject: Re: [Ovmsdev] changing android app server IP
>> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>> Message-ID: <CFD43A7E.6BBAD%tom at idleloop.com>
>> Content-Type: text/plain;charset="US-ASCII"
>> I just downloaded the Android Open Vehicle app and configured it for our
>> Roadster. It gives me an error message that it can't connect and
>> recommends checking my passwords. I've double-checked the passwords and I
>> think they are right.
>> I don't see anywhere to enter my OVMS server user name, which the iOS app
>> requires. Is that the problem?
>> Tom
>> -----Original Message-----
>> From: Mark Webb-Johnson <mark at webb-johnson.net>
>> Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>> Date: Saturday, June 28, 2014 at 6:06 AM
>>> Lee,
>>> Looks good. I merged it, and submitted v3.2.2 to google play.
>>> On 28 Jun, 2014, at 3:44 am, Lee Howard <lee.howard at mainpine.com> wrote:
>>>> On 06/27/2014 10:38 AM, Lee Howard wrote:
>>>>> On 06/26/2014 08:38 PM, Tom Saxton wrote:
>>>>>> Arguably the server account should be per-vehicle but I'm
>>>>>> guessing the
>>>>>> thought was that anyone who has multiple OVMS vehicles will have them
>>>>>> all
>>>>>> on the same server and making that app-wide means you only have to
>>>>>> enter
>>>>>> username, password and server IP once.
>>>>>> Of course none of this is any help for figuring out how to do it on
>>>>>> Android...
>>>>> As I dug-into the Android code better to hard-code the address change
>>>>> I discovered - to my delight - that the app server address is
>>>>> stored in
>>>>> a per-car data object. Yay! So this is nice. I'm going to give this
>>>>> another shot.
>>>> Here is the patch. Someone with privs can apply it and commit these
>>>> changes to the repository if it meets with their approval.
>>>> It's a very small enhancement - basically permitting an interface to
>>>> sel_server in the CarData object. The interface is right where it
>>>> should be, IMO: right where you enter the vehicle info and passwords.
>>>> The default is left to "tmc.openvehicles.com", but the user now has the
>>>> capability to modify it (on a per-car basis, even).
>>>> I did not change the sel_server initialization value of
>>>> "tmc.openvehicles.com". I could have changed this to "" as with the
>>>> other CarData strings, but it probably makes little difference. Leaving
>>>> it to initialize with "tmc.openvehicles.com" possibly it could be
>>>> confusing to someone later who doesn't recognize that the initialized
>>>> value is always overwritten by the configured value (as with the other
>>>> CarData strings which are initialized to ""). If someone cares
>>>> they can
>>>> modify that at the top of CarData.java.
>>>> This patch also makes one obvious grammatical correction in a string
>>>> appearing on the same page layout.
>>>> If there is any concern just look at the patch - it's a very, very
>>>> benign set of changes. This e-mail is longer than the patch is.
>>>> Thanks,
>>>> Lee.
>>>> *Lee Howard*
>>>> *Mainpine, Inc. Chief Technology Officer*
>>>> Tel: +1 866 363 6680 | Fax: +1 360 462 8160
>>>> lee.howard at mainpine.com | www.mainpine.com
>>>> <ovms-android-editserver.patch>__________________________________________
>>>> _____
>> Message: 2
>> Date: Sat, 28 Jun 2014 10:05:43 -0700
>> From: Lee Howard <lee.howard at mainpine.com>
>> To: ovmsdev at lists.teslaclub.hk
>> Message-ID: <53AEF5E7.1060806 at mainpine.com>
>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>> I'm using my built .apk instead of the one from Google Play, but my
>> source code is now identical to the one in the git repository.
>> Mine is working fine for me.
>> Admittedly, I do get confused about which one is the server password and
>> which one is the module password, and so I just swap them around if I
>> get the password error. Maybe the Android app has the two mixed-up?
>> As for the app not needing the your account username... I've never
>> needed it on the Android app before. I think that it just uses the car
>> info.
>> Thanks,
>> Lee.
>>> and I
>>> iOS app
>>> Tom
>> *Lee Howard*
>> End of OvmsDev Digest, Vol 29, Issue 73
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140629/55996af9/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140629/55996af9/attachment-0002.vcf>
