[Ovmsdev] Twizy 45
Gianluca Magalotti
gianluca at magalotti.net
Sun Jun 29 17:53:50 HKT 2014
Yes Michael, I was referring to the intro stating it was for the 80 kph only (i said it was ambiguous because of that...).
BTW I also solved the modem issue.. was my fault.. I didn't check the switch on the board and it was in "disable" position. Now everything works well and I've also downloaded last Android App.
Gianluca
Il giorno 28/giu/2014, alle ore 16:33, ovmsdev-request at lists.teslaclub.hk ha scritto:
> Send OvmsDev mailing list submissions to
> ovmsdev at lists.teslaclub.hk
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> ovmsdev-owner at lists.teslaclub.hk
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OvmsDev digest..."
> Today's Topics:
> 1. Re: Twizy 45 (Michael Balzer)
> Message: 1
> Date: Sat, 28 Jun 2014 16:33:36 +0200
> From: Michael Balzer <dexter at expeedo.de>
> Subject: Re: [Ovmsdev] Twizy 45
> To: ovmsdev at lists.teslaclub.hk
> Message-ID: <53AED240.903 at expeedo.de>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Gianluca,
> the CFG macro commands work identically on both models, automatically
> respecting the lower T45 limits.
> So there is no usage difference between the models, and no need for
> separate instructions.
> I just saw I forgot to remove one "only 80 kph" passage from the manual
> on page 27, I suppose that's what you mean... fixed, will check that in
> later.
> Section intro now is:
> "All macro commands work identically for the 80 kph and the 45 kph
> versions of the Twizy, automatically using the respective limits (see
> previous section on limit differences). The limits will be applied on
> setting the registers, so you can even load a T80 macro profile into a
> T45 (but don't expect similar driving results)."
> Am 28.06.2014 14:28, schrieb Gianluca Magalotti:
>> First of all please confirm that CFG commands (SPEED, POWER, RECUP,
>> etc.) will work properly with Twizy 45. I've tried them on it and
>> everything
>> In any case I think we have to update twizy documentation at page 26
>> to be less ambiguous.
>> More in general I think guide should be upgraded to provide
>> instructions for both 45 and 80 model. I can try to do it with support.
>> *G.*
>> Il giorno 28/giu/2014, alle ore 06:00,
>>> ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
>>> Today's Topics:
>>> 1. Re: changing android app server IP (Christopher Cook)
>>> 2. Re: changing android app server IP (Lee Howard)
>>> 3. Re: changing android app server IP (Lee Howard)
>>> Message: 1
>>> Date: Fri, 27 Jun 2014 12:44:52 +0800
>>> From: Christopher Cook <christopher.cook at webprofusion.com>
>>> Subject: Re: [Ovmsdev] changing android app server IP
>>> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>>> Message-ID: <r7evp31xp6nup2wd3sya83eu.1403844292014 at email.android.com>
>>> Content-Type: text/plain; charset=utf-8
>>> Off topic but long term it would be prudent to investigate the cross
>>> platform options for the app, otherwise there's a lot of duplicate work.
>>> I'd consider HTML/Cordova, Xamarin (and perhaps Xamarin Forms),
>>> Titanium Sdk, etc.
>>> Not saying cross platform doesn't have its challenges but otherwise
>>> there's probably not enough dev resources to expect to develop a
>>> complete app for all platforms.
>>> Chris
>>> Tom Saxton <tom at idleloop.com> wrote:
>>>> On iOS, the App settings is buried in the System Settings app, a
>>>> terrible
>>>> UI design. Finally, with iOS 8, there will be a way for apps to send you
>>>> straight to the app settings. But for now...
>>>> Open the Setting app, then scroll down to the bottom to find a list of
>>>> apps that use the built-in settings mechanism. You'll find an item for
>>>> "Open Vehicle". In there you'll find the configuration for your OVMS
>>>> account, including the server IP address.
>>>> That's also where you can turn the Open Charge Map stuff on/off and
>>>> where
>>>> you can override the module's choice for distance and temperature units.
>>>> Arguably the server account should be per-vehicle but I'm guessing the
>>>> thought was that anyone who has multiple OVMS vehicles will have
>>>> them all
>>>> on the same server and making that app-wide means you only have to enter
>>>> username, password and server IP once.
>>>> Of course none of this is any help for figuring out how to do it on
>>>> Android...
>>>> Tom
>>>> -----Original Message-----
>>>> From: Lee Howard <lee.howard at mainpine.com>
>>>> Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>>>> Date: Thursday, June 26, 2014 at 4:22 PM
>>>>> On 06/11/2014 05:23 PM, Mark Webb-Johnson wrote:
>>>>>> I think the 'tmc' server is hard-coded in the Android App.
>>>>>> The code on github is up-to-date, if anyone wants to take a stab at
>>>>>> making it configurable.
>>>>> I spent a few days getting acquainted with Android development and
>>>>> toying with the OVMS Android app code, loading it onto the Android
>>>>> emulator, etc.
>>>>> I couldn't decide where was the best place was to put an "app settings"
>>>>> menu item, and so I caved and downloaded OVMS from the App Store
>>>>> onto my
>>>>> iPad...
>>>>>> The iOS App has it in the system settings tab.
>>>>> I don't see it. Is this in unreleased/unpublished code?
>>>>> There is the "OVMS Server IP" in the "Parameters" section of the
>>>>> "Control" menu for each configured car. However, I believe that refers
>>>>> to the server IP configured in the car module and not for the app. AND
>>>>> this same section and menu exist on the Android app (after waiting
>>>>> long-enough for it to populate... or getting lucky... I can't
>>>>> figure out
>>>>> which since it often doesn't populate at all).
>>>>> Since for each car the app needs to talk to the same server as the car
>>>>> module it would be ideal for changes made to this "OVMS Server IP" in
>>>>> the "Parameters" section to apply to both the IP where the module
>>>>> communicates *AND* to where the app communicates for that car, but
>>>>> since
>>>>> this "Parameters" section doesn't even come up at all until the app can
>>>>> talk to the server and module, I don't think that's how it works,
>>>>> presently, and it would appear to need a lot of effort to get it
>>>>> working
>>>>> in that fashion.
>>>>> It would be nice if I could have different car modules talking to
>>>>> different servers and for me to be able to use one app to rule them
>>>>> all. The app would merely talk to different servers for each car.
>>>>> Anyway... since my initial interest is in doing server-side and
>>>>> car-module-side developments (and not so much the app-side of things)
>>>>> I'm inclined to just make a hard-coded change to the server IP address
>>>>> in my Android app and move on for the sake of being productive.
>>>>> Thanks,
>>>>> Lee.
>>>>> *Lee Howard*
>>>>> *Mainpine, Inc. Chief Technology Officer*
>>>>> Tel: +1 866 363 6680 | Fax: +1 360 462 8160
>>>>> lee.howard at mainpine.com | www.mainpine.com
>>> Message: 2
>>> Date: Fri, 27 Jun 2014 10:38:05 -0700
>>> Message-ID: <53ADABFD.4010407 at mainpine.com>
>>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>>> terrible
>>>> UI design.
>>> Oh, I see. Thank you. That was very helpful.
>>> Yes, it is a terrible UI design by Apple on iOS.
>>> I was going to try to do on Android similar to what had been done on
>>> iOS, but since this is so terrible, I'd rather not do it like that.
>>>> them all
>>>> Android...
>>> As I dug-into the Android code better to hard-code the address change I
>>> discovered - to my delight - that the app server address is stored in a
>>> per-car data object. Yay! So this is nice. I'm going to give this
>>> another shot.
>>> Thanks,
>>> Lee.
>>> *Lee Howard*
>>> Message: 3
>>> Date: Fri, 27 Jun 2014 12:44:16 -0700
>>> Message-ID: <53ADC990.5010708 at mainpine.com>
>>>>> thought was that anyone who has multiple OVMS vehicles will have them
>>>>> all
>>>>> enter
>>>>> Android...
>>>> I discovered - to my delight - that the app server address is stored
>>>> in a per-car data object. Yay! So this is nice. I'm going to give
>>>> this another shot.
>>> Here is the patch. Someone with privs can apply it and commit these
>>> changes to the repository if it meets with their approval.
>>> It's a very small enhancement - basically permitting an interface to
>>> sel_server in the CarData object. The interface is right where it
>>> should be, IMO: right where you enter the vehicle info and passwords.
>>> The default is left to "tmc.openvehicles.com", but the user now has the
>>> capability to modify it (on a per-car basis, even).
>>> I did not change the sel_server initialization value of
>>> "tmc.openvehicles.com". I could have changed this to "" as with the
>>> other CarData strings, but it probably makes little difference. Leaving
>>> it to initialize with "tmc.openvehicles.com" possibly it could be
>>> confusing to someone later who doesn't recognize that the initialized
>>> value is always overwritten by the configured value (as with the other
>>> CarData strings which are initialized to ""). If someone cares they can
>>> modify that at the top of CarData.java.
>>> This patch also makes one obvious grammatical correction in a string
>>> appearing on the same page layout.
>>> If there is any concern just look at the patch - it's a very, very
>>> benign set of changes. This e-mail is longer than the patch is.
>>> Thanks,
>>> Lee.
>>> *Lee Howard*
>>> -------------- next part --------------
>>> A non-text attachment was scrubbed...
>>> Type: text/x-patch
>>> Desc: not available
>>> URL:
>>> <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140627/df2a0078/attachment-0001.bin>
>>> End of OvmsDev Digest, Vol 29, Issue 69
> An HTML attachment was scrubbed...
> URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140628/d5bdb152/attachment.html>
> Type: text/x-vcard
> Desc: not available
> URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140628/d5bdb152/attachment.vcf>
> End of OvmsDev Digest, Vol 29, Issue 72
