[Ovmsdev] OVMS - HW
Thomas Bergo
thomas.bergo at gmail.com
Wed Jun 18 10:15:34 HKT 2014
Hi Olav
Why don't do it easy and use a MOSFET and a 12V relay. Then you don't need
to worry about heat and 5V power consumption.
See attached picture sample circuit. You should probably also add a
resistor from the output of the PIC to GND to make sure the relay is turn
properly off.
Regards, Thomas
2014-06-17 10:04 GMT+02:00 Olav A. Antonsen <olav at ansit.no>:
> Seems like most car phone chargers uses a MC34063 switchmode-regulator
> chip that is much more efficient than a 7805. Will strip one out of its
> casing and give it a try.
> For stronger currents I was told to use a UBEC.
> --Olav
> *From:* ovmsdev-bounces at lists.teslaclub.hk [mailto:
> ovmsdev-bounces at lists.teslaclub.hk] *On Behalf Of *Mastro Gippo
> *Sent:* 17. juni 2014 09:38
> *To:* OVMS Developers
> *Subject:* Re: [Ovmsdev] OVMS - HW
> Olav, the temperature should not raise that much, as the PCB is
> dissipating some of the heat. You can just try it and see if it heats up
> too much (being careful not to blow the fuse, as Mark said), or use your
> own 7805 slapped to a small heatsink. If you need more power, a car phone
> charger may be a better choice as it has a more efficient switching supply.
> MG
> 2014-06-17 8:44 GMT+02:00 Olav A. Antonsen <olav at ansit.no>:
> 100°C/W! 9V * 0.2A = 1.8W => I need to keep the relays closed for 1 hour
> so it’s going to overheat!
> Need to find another solution for feeding the relay module with +5V.
> Mastro, any suggestions?
> --Olav
> *Sent:* 17. juni 2014 00:33
> Hi, this is the correct DS:
> http://www.st.com/web/en/resource/technical/document/datasheet/CD00000444.pdf
> for the DPAK package the OVMS is using, you have 8°C/W for the TJ and
> 100°C/W for TA. (it's a small package!)
> Also, you must calc the dissipation thinking about the "dissipated"
> voltage, so not 5V but (14V-5V) = 9V (worst case).
> You should also add some margin, e.g. use 100mA instead of 80mA just to be
> safe.
> Just try it and keep a finger on the IC for a few minutes to see if it
> overheats, it shouldn't hurt the board.
> MG
> 2014-06-17 0:14 GMT+02:00 Olav A. Antonsen <olav at ansit.no>:
> Great video thermal design.
> My knowledge on thermal design is only 30 minutes old, but my
> interpretation of the datasheet gives med
> The regulator will reach 23°C/W above ambient.
> Running at max 1.5A @ 5V = 7.5W.
> 23C/W => 172.5°C -> To hot to handle
> 2 relays @ 80mA each ~ 0.16A @ 5V ~ 0,8W ~ 18.4°C above ambient.
> My conclusion is that adding a consumption of 160mA will raise the
> temperature 18.4°C above ambient. (This comes in addition to the current
> the OVMS module consumes.
> Is this correct?
> Regards
> Olav
> *Fra:* ovmsdev-bounces at lists.teslaclub.hk [mailto:
> ovmsdev-bounces at lists.teslaclub.hk] *På vegne av* Mastro Gippo
> *Sendt:* 16. juni 2014 23:38
> *Til:* OVMS Developers
> *Emne:* Re: [Ovmsdev] OVMS - HW
> The 1.5A is not the whole story; you can watch this:
> https://www.youtube.com/watch?v=8ruFVmxf0zs
> Basically, if you had that 7805 on free air powering your two relays, it
> would (try to) reach about 170°C above ambient temperature. The PCB is a
> nice heatsink, but it is shared with the big GSM regulator, and that rises
> the temperature too.
> By all means, experiment!! The 7805 has thermal protection, and you should
> test your circuit on the bench keeping a finger on the IC to feel if it
> gets too hot.
> You should take care of the increased ripple too, but a small cap should
> do the trick there.
> Regards
> MG
> 2014-06-16 23:09 GMT+02:00 Olav A. Antonsen <olav at ansit.no>:
> I got some help from a user on a Norwegian forum who pointed me to
> https://raw.githubusercontent.com/openvehicles/Open-Vehicle-Monitoring-System/master/vehicle/Car%20Module/v2-base/OVMS_V6A.pdf
> Looks like a 7805-regulator is supplying the OVMS module with +5V @ 1.5A
> max.
> https://www.sparkfun.com/datasheets/Components/LM7805.pdf
> 80mA won't be a problem then.
> --Olav
> *Sendt:* 16. juni 2014 23:03
> It may be a problem to get the 5V from the output of the regulator, but
> the nice thing about that module is that it is isolated; you can connect
> your own power supply and be 100% safe. These relays draw about 80mA each
> (just tested them, I have the same product at home), so if you turn them on
> one at a time and for short periods of time it should be ok (I don't know a
> lot about the termal design of the OVMS).
> MG
> 2014-06-16 22:37 GMT+02:00 Olav A. Antonsen <olav at ansit.no>:
> Hello
> My knowledge of electronics is limited.
> As far as I understand the OVMS module is supplied with +12V via the OBD
> connector. What I don't understand is where the +5V comes from?
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System/blob/master/vehicle/Car%20Module/v2-base/20120814-boarddesign.pdf
> I'm currently trying to control a relay using the RC3 output on the
> PIC18F2580 as a control signal to a rely on a relay module
> http://www.dx.com/p/arduino-2-channel-relay-shield-module-red-144140#.U59Qavl_t8E
> The relay module needs to be supplied with +5V to drive the relays, and my
> plan was to get the +5V from the OVMS module using pin 13 on the HEADER 9X2.
> But I'm afraid I might blow something on the OVMS module if the relay
> module draws to many mA.
> Any advice would be appreciated.
> --Olav
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140618/4e6153d5/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140618/4e6153d5/attachment-0002.png>
