[Ovmsdev] OVMS v3
Matt Beard matt at beard.tv
Tue Jun 17 01:38:35 HKT 2014
My biggest worry would be keeping the end user price similar to what it is
now. Some routes would allow this, but some would put it out of the reach
of lots of potential customers.
What would the likely cost implications of each of the suggested routes be?
Matt Beard
On Monday, 16 June 2014, Kevin Sharpe <kevin.sharpe at zerocarbonworld.org>
wrote:
> Take a look at GEVCU 5;
> https://groups.google.com/forum/#!topic/gevcu-development/sukQFDW8yjc
> I’d like to produce a GEVCU 6 that adds GPS/GPRS and uses the CINCH
> waterproof enclosure giving us WiFi, BT, GPS, GPRS, isolated I/O, and 80MHz
> 32bit Arduino DUE compatible hardware.
> I’m prepared to finance the hardware development and even the cost of
> porting the OVMS software if the current developers are interested in this
> route forward.
> IMO we would all benefit from a single hardware platform and GEVCU already
> has some serious money behind it and some cool libraries that might help
> OVMS grow.
> Kevin Sharpe | Founder & Chair Trustees | Zero Carbon World, a UK
> Registered Charity
> From: Mastro Gippo <gipmad at gmail.com
> <javascript:_e(%7B%7D,'cvml','gipmad at gmail.com');>>
> Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk
> <javascript:_e(%7B%7D,'cvml','ovmsdev at lists.teslaclub.hk');>>
> Date: Monday, 16 June 2014 16:41
> Subject: [Ovmsdev] OVMS v3
> Hi all, I'd like to resurrect an old conversation. As we know, the current
> PIC is quickly running out of resources and maybe it's time to switch to a
> better platform. Two CAN buses are now desirable too. A microSD slot and
> direct USB connectivity wouldn't hurt either.
> I will probably have to design a similar hardware for myself, so I'd like
> to contribute to the OVMS by sharing the HW platform if you want; no
> strings attached of course, if you decide that there's no need for the
> upgrade, I'll keep on working on my project by myself! :)
> That said, I'd like to throw a few ideas to the table.
> - MCU: I'd like to use an STM32 micro. They seem to be emerging as the
> standard choice for diy ARM projects, and this offers a few interesting
> opportunities:
>  -Programming it in c/c++ with the manufacturer CMSIS standard libraries
> (boring)
>  -Programming it with the mbed.org SDK. Unfortunately no dev boards are
> available with dual CAN bus, but it will be easy to move to the correct
> micro of the same series once most of the software is ironed out on a dev
> board like the https://mbed.org/platforms/ST-Nucleo-F302R8/
>  -Programming it with an RTOS. NuttX would be my choice, as it's the one
> used in the Ardupilot Pixhawk platform, and I'd like to learn it. This
> would mean a steeper starting curve, but a lot of flexibility later as a
> lot of stuff is handled on the OS level (network stacks, SD card &
> filesystems, multitasking...). FreeRTOS is a nice option too.
> I'd like to use the STM32F405RG as it's the most similar to the one found
> on the Pixhawk, but of course I'm biased because of that, and that micro is
> quite overkill for the task. We can of course use a lower specced part and
> lose some RTOS fuctionality as long as it has 2 CAN buses.
> - MODEM: I have no experience in this field; is the SIM908 still a good
> choice or does anyone think that we should try new platforms?
> I like this, but I don't know if the price puts it out of budget:
> http://www.telit.com/telit/Pulsar/en_US.Store.display.1001./ge864-gps
> On the bright side, it can be programmed in python, so we can offload some
> of the work to the modem. This *could* allow us to free some space on the
> PIC, and keep that platform without changing MCU..
> - Enclosure: I think that, even with the new MCU, we can still fit the old
> enclosure. Is that ok, or should we think about a more automotive-friendly
> one? Maybe waterproof for the twizy?
> And that's it. I think that the core SW developers should voice their
> opinion, as there is a lot of work to be done on that front. A huge problem
> will be keeping backwards compatibility to add features for the v2 users,
> so we should discuss about this too.
> Regards
> MG
> <javascript:_e(%7B%7D,'cvml','OvmsDev at lists.teslaclub.hk');>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140616/8c61e2da/attachment.htm>
