[Ovmsdev] Nissan Leaf
Mon Jun 16 11:15:05 HKT 2014
I've ordered a bunch of cables suitable for CAR and EV can buses of Nissan Leaf. Pinout is:
Pinout B
J1962-M   DB9-F   Signal
4         3       Chassis/Power GND
6        5      CAN-H (alternate CAN)
14       4      CAN-L (alternate CAN)
13        7       CAN-H (primary CAN)
12        2       CAN-L (primary CAN)
16        9       +12V Vehicle Power
J1962 end should be MALE plug with right angle cable. DB9 end should be FEMALE.
Both ends should be enclosed in shells, and cable should be 1metre in length.
The wiring brings J1962-M pins 13 and 12 (EV can bus) through to our standard OVMS v2 can bus pins. It also brings the normal CAR can bus through on DB9-F pins 5 and 4 (for future use on any dual-can enabled OVMS module, or easy re-wiring at the DB9 end).
Cable itself as per our standard naming:
For simplicity, I'll ask Fasttech to handle logistics for these, as usual.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140616/10f54e75/attachment.htm>
Type: image/jpg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140616/10f54e75/attachment-0002.jpg>
