[Ovmsdev] Build environment
Olav A. Antonsen
olav at ansit.no
Thu Jun 12 06:55:23 HKT 2014
The document
https://github.com/openvehicles/Open-Vehicle-Monitoring-System/blob/master/d
ocs/OVMS_Development.pdf
helps a lot when it comes to setting up the dev environment. I set up the
environment on windows 8, but it seems like everyone else is using linux to
build the firmware.
I was able to build the hex file (on win 8), but I haven't been able to test
the file yet because I'm still waiting for my unit.
https://dl.dropboxusercontent.com/u/12327518/OVMS.X.production.hex
Is anyone else using win 8 to build the firmware?
On the project in MPLAB it's possible to choose between different
configurations
1)V1_Production
2)V2_Experimental
3)V2_Production
4)V2_TR_Production
5)V2_RT_Production
The development documentation tells the user to select "V2_Experimental".
What is the purpose of configuration 4 and 5?
--Olav
-----Opprinnelig melding-----
Fra: ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] På vegne av Olav A. Antonsen
Sendt: 11. juni 2014 00:21
Til: 'OVMS Developers'
Emne: [Ovmsdev] Build environment
Hello
Does anyone know if there exists a tutorial/quick guide on how to setup the
environment needed to code and build the firmware?
--Olav
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk
