[Ovmsdev] Twizy feature ideas
Mon Jun 9 05:52:52 HKT 2014
Nikolay,
I don't need CORS for the auth, that's already working without.
I would need CORS to automatically process the data. And I'd like to do
it with minimal changes to the existing API server.
My CORS research result was:
maybe AnyEvent::HTTPD has some CORS support yet?
If not, these are the headers:
Access-Control-Allow-Methods "POST, GET, PUT, OPTIONS, PATCH, DELETE"
Access-Control-Allow-Origin "*$ORIGIN*"
Access-Control-Allow-Credentials "true"
Access-Control-Allow-Headers "X-Accept-Charset,X-Accept,Content-Type"
...static values except for the "ORIGIN" variable, which needs to
echo back the "Origin:" header from the request. I'm not familiar
with AnyEvent::HTTPD, maybe something like
$req->header('Origin')
There's a bit more to do: method OPTIONS also needs to be supported
for "preflight requests" (access control negotiation), see
https://developer.mozilla.org/en-US/docs/Web/HTTP/Access_control_CORS for
detailed request/response examples.
I suppose that will need a separate handler function, but one for
the /api root should be sufficient.
Btw, methods "PUT", "PATCH" + "DELETE" can be omitted I think.
But if you'd like to build a Node.js based solution, go ahead, sounds
cool :-)
Am 07.06.2014 23:37, schrieb Nikolay Shishkov:
> Hi Michael,
> I think what you have done with the html page is crying for the CORS
> and an angularjs, single page app.
> Here is an open source project with such app that could "easily" be
> modified to do the work.
> Check out a working sample here:
> http://angular-client-side-auth.herokuapp.com/login/
> Nikolay
> On Saturday, June 7, 2014 12:42 AM, Nikolay Shishkov
> <nshishkov at yahoo.com> wrote:
> I believe the following two headers should do it:
> Access-Control-Allow-Origin: *
> Access-Control-Allow-Credentials: true
> But needs to be tested.
> On Friday, June 6, 2014 2:31 PM, Mark Webb-Johnson
> <mark at webb-johnson.net> wrote:
> Bug squished. Live on tmc now (and pushed to github).
> Neat web page. Shows promise.
> Regarding the CORS, I'm very willing to make the changes - just not
> really sure what headers exactly need to be added. Anyone here know
> what I would need to add?
> On 6 Jun, 2014, at 3:03 pm, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
> Nikolay,
> you found an API server bug :-)
> Solution: delete all domain cookies for "openvehicles.com
> <http://openvehicles.com/>" from your browser before using the API.
> The API server gets confused by multiple cookies. If you visit
> www.openvehicles.com <http://www.openvehicles.com/> before using the
> API, you get a persistent PHP session cookie like this:
> Name SESS619b2b3f204291df32506531f8b446dd
> Host .openvehicles.com <http://openvehicles.com/>
> Pfad /
> As the host defines ".openvehicles.com <http://openvehicles.com/>" and
> path "/", this cookie also gets sent to the API host, which then
> confuses this one with the "ovmsapisession" cookie, i.e.
> Name ovmsapisession
> Host tmc.openvehicles.com <http://tmc.openvehicles.com/>
> Pfad /api/
> Am 05.06.2014 23:46, schrieb Nikolay Shishkov:
>> Thanks Michael,
>> I am getting "login ok" when pressing on the login button, but then
>> all the other buttons are giving "authentication error" message.
>> I could check that the cookie is sent with the request, but the
>> server seems to respond with the 400 code.
>> I tried in Chrome. Where, how do you use the page?
>> Nikolay
>> On Thursday, June 5, 2014 10:59 PM, Michael Balzer
>> <dexter at expeedo.de> <mailto:dexter at expeedo.de> wrote:
>> Nikolay,
>> that's right, I intend to get this running without an otherwise
>> necessary proxy, i.e. for local HTML pages on mobile devices or the
>> like. I've been in contact with Mark about CORS on the perl server.
>> A server could of course be used, most simply the HTTP API itself
>> could deliver the client page, but CORS should now enable to cope
>> without and open possible cross origin data/control integrations. Not
>> sure about static pages for this though, not yet tested. I think it
>> would be cool to just load some HTML file in your browser and have a
>> graphical OVMS client.
>> The "code" is currently just a first test bed HTML page to interact
>> with the HTTP API. No graphics, just a simple table view. Works, but
>> is clumsy as hell.
>> Try yourself, I've attached it.
>> Am 05.06.2014 11:26, schrieb Nikolay Shishkov:
>>> Hi Michael,
>>> I am very interested in the "Browser client using HTTP API and
>>> jQuery/Flot for visualization". From the comment that CORS is needed
>>> I suspect you want to have the html5 page locally and then fetch
>>> data from the server while using other sources for context data.
>>> Have you considered running this on a separate server that serves as
>>> a gateway to the TMC server?
>>> Have you uploaded the code somewhere?
>>> I have been playing around with C# client and was thinking of using
>>> it on an asp.net <http://asp.net/> server...
>>> Nikolay
>>> On Wednesday, June 4, 2014 11:22 PM, Michael Balzer
>>> Am 04.06.2014 07:38, schrieb Gianluca Magalotti:
>>> > For nice2have features I'll wait for your list (I have my personal
>>> > list too but maybe we'll have a later focus on that)
>>> So here it is.
>>> If other Twizy drivers would like to add their ideas, you're welcome.
>>> I'll do my best to check new ideas against my collected knowledge of
>>> what's possible up to now and give you some feedback.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140608/77d16edd/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140608/77d16edd/attachment-0002.vcf>
