[Ovmsdev] SEVCON ALERT
Julien (JaXX) Banchet jaxx at jaxx.org
Mon Jun 30 06:40:29 HKT 2014
Hi,
Renault isn’t to my experience very good at callbacks (they « forgot » to do my callback about the power line water infiltration issue). That said yeah, I confirm, there is a callback on badly responding pedals, « logically » stuck and/or « physically » slow to come back to initial position. I don’t know how the sevcon determinates the state but well, give Renault a call with the VIN number and they’ll tell you for sure or call you in for a checkup (as sometimes out of series VIN remain affected, I had a non responding pedal effect a couple of times in the past, barely noticeable as you rekick it in by reflex within a second, didn’t have the OVMS yet at the time)
JaXX./.
PS: The throttle issue can be accentuated by cold weather I’ve heard on french forums… which can be the case as… well… summer still hasn’t showed up everywhere yet ;-)
-----Original Message-----
De: Michael Balzer <dexter at expeedo.de>
Répondre: OVMS Developers <ovmsdev at lists.teslaclub.hk>>
Date: 29 juin 2014 at 23:08:54
À: ovmsdev at lists.teslaclub.hk <ovmsdev at lists.teslaclub.hk>>
Sujet:  Re: [Ovmsdev] SEVCON ALERT
> Gianluca,
> there's a fault code list in the SEVCON DVT package, you can find it on
> the web.
> Info from that list:
> Description: "Throttle appears to be stuck. This fault will clear if
> throttle starts to work again."
> Recommended action: "Check throttle wiring and installation."
> There once was a throttle service callback concerning mechanically stuck
> pedals, maybe that's the cause?
> But first check if the fault persists.
> Am 29.06.2014 22:42, schrieb Gianluca Magalotti:
> > Tonight I've received on my app the following message:
> > SEVCON ALERT 0x4582 Safety Case 1
> > What does it mean?
> > *Gianluca*
> > Il giorno 29/giu/2014, alle ore 06:00,
> > ovmsdev-request at lists.teslaclub.hk
> > ha scritto:
> >> Send OvmsDev mailing list submissions to
> >> To subscribe or unsubscribe via the World Wide Web, visit
> >> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
> >> or, via email, send a message with subject or body 'help' to
> >> You can reach the person managing the list at
> >> ovmsdev-owner at lists.teslaclub.hk
> >> When replying, please edit your Subject line so it is more specific
> >> than "Re: Contents of OvmsDev digest..."
> >> Today's Topics:
> >> 1. Re: changing android app server IP (Tom Saxton)
> >> 2. Re: changing android app server IP (Lee Howard)
> >> Message: 1
> >> Date: Sat, 28 Jun 2014 09:28:52 -0700
> >> From: Tom Saxton
> >> Subject: Re: [Ovmsdev] changing android app server IP
> >> To: OVMS Developers
> >> Message-ID:
> >> Content-Type: text/plain;charset="US-ASCII"
> >> I just downloaded the Android Open Vehicle app and configured it for our
> >> Roadster. It gives me an error message that it can't connect and
> >> recommends checking my passwords. I've double-checked the passwords and I
> >> think they are right.
> >> I don't see anywhere to enter my OVMS server user name, which the iOS app
> >> requires. Is that the problem?
> >> Tom
> >> From: Mark Webb-Johnson
> >> Reply-To: OVMS Developers
> >> Date: Saturday, June 28, 2014 at 6:06 AM
> >> To: OVMS Developers
> >>> Lee,
> >>> Looks good. I merged it, and submitted v3.2.2 to google play.
> >>> Regards, Mark.
> >>> On 28 Jun, 2014, at 3:44 am, Lee Howard wrote:
> >>>> On 06/27/2014 10:38 AM, Lee Howard wrote:
> >>>>> On 06/26/2014 08:38 PM, Tom Saxton wrote:
> >>>>>> Arguably the server account should be per-vehicle but I'm
> >>>>>> guessing the
> >>>>>> thought was that anyone who has multiple OVMS vehicles will have them
> >>>>>> all
> >>>>>> on the same server and making that app-wide means you only have to
> >>>>>> enter
> >>>>>> username, password and server IP once.
> >>>>>> Of course none of this is any help for figuring out how to do it on
> >>>>>> Android...
> >>>>> As I dug-into the Android code better to hard-code the address change
> >>>>> I discovered - to my delight - that the app server address is
> >>>>> stored in
> >>>>> a per-car data object. Yay! So this is nice. I'm going to give this
> >>>>> another shot.
> >>>> Here is the patch. Someone with privs can apply it and commit these
> >>>> changes to the repository if it meets with their approval.
> >>>> It's a very small enhancement - basically permitting an interface to
> >>>> sel_server in the CarData object. The interface is right where it
> >>>> should be, IMO: right where you enter the vehicle info and passwords.
> >>>> The default is left to "tmc.openvehicles.com", but the user now has the
> >>>> capability to modify it (on a per-car basis, even).
> >>>> I did not change the sel_server initialization value of
> >>>> "tmc.openvehicles.com". I could have changed this to "" as with the
> >>>> other CarData strings, but it probably makes little difference. Leaving
> >>>> it to initialize with "tmc.openvehicles.com" possibly it could be
> >>>> confusing to someone later who doesn't recognize that the initialized
> >>>> value is always overwritten by the configured value (as with the other
> >>>> CarData strings which are initialized to ""). If someone cares
> >>>> they can
> >>>> modify that at the top of CarData.java.
> >>>> This patch also makes one obvious grammatical correction in a string
> >>>> appearing on the same page layout.
> >>>> If there is any concern just look at the patch - it's a very, very
> >>>> benign set of changes. This e-mail is longer than the patch is.
> >>>> Thanks,
> >>>> Lee.
> >>>> *Lee Howard*
> >>>> *Mainpine, Inc. Chief Technology Officer*
> >>>> Tel: +1 866 363 6680 | Fax: +1 360 462 8160
> >>>> lee.howard at mainpine.com | www.mainpine.com
> >>>> __________________________________________
> >>>> _____
> >>>> OvmsDev at lists.teslaclub.hk
> >>> _______________________________________________
> >> Message: 2
> >> Date: Sat, 28 Jun 2014 10:05:43 -0700
> >> From: Lee Howard
> >> To: ovmsdev at lists.teslaclub.hk
> >> Message-ID: <53AEF5E7.1060806 at mainpine.com>
> >> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> >> I'm using my built .apk instead of the one from Google Play, but my
> >> source code is now identical to the one in the git repository.
> >> Mine is working fine for me.
> >> Admittedly, I do get confused about which one is the server password and
> >> which one is the module password, and so I just swap them around if I
> >> get the password error. Maybe the Android app has the two mixed-up?
> >> As for the app not needing the your account username... I've never
> >> needed it on the Android app before. I think that it just uses the car
> >> info.
> >> Thanks,
> >> Lee.
> >>> and I
> >>> iOS app
> >>> Tom
> >> *Lee Howard*
> >> End of OvmsDev Digest, Vol 29, Issue 73
