[Ovmsdev] SEVCON ALERT
Gianluca Magalotti
gianluca at magalotti.net
Mon Jun 30 04:42:30 HKT 2014
Tonight I've received on my app the following message:
SEVCON ALERT 0x4582 Safety Case 1
What does it mean?
Gianluca
Il giorno 29/giu/2014, alle ore 06:00, ovmsdev-request at lists.teslaclub.hk ha scritto:
> Send OvmsDev mailing list submissions to
> ovmsdev at lists.teslaclub.hk
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> ovmsdev-owner at lists.teslaclub.hk
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OvmsDev digest..."
> Today's Topics:
> 1. Re: changing android app server IP (Tom Saxton)
> 2. Re: changing android app server IP (Lee Howard)
> Message: 1
> Date: Sat, 28 Jun 2014 09:28:52 -0700
> From: Tom Saxton <tom at idleloop.com>
> Subject: Re: [Ovmsdev] changing android app server IP
> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
> Message-ID: <CFD43A7E.6BBAD%tom at idleloop.com>
> Content-Type: text/plain; charset="US-ASCII"
> I just downloaded the Android Open Vehicle app and configured it for our
> Roadster. It gives me an error message that it can't connect and
> recommends checking my passwords. I've double-checked the passwords and I
> think they are right.
> I don't see anywhere to enter my OVMS server user name, which the iOS app
> requires. Is that the problem?
> Tom
> -----Original Message-----
> Date: Saturday, June 28, 2014 at 6:06 AM
>> Lee,
>> Looks good. I merged it, and submitted v3.2.2 to google play.
>> On 28 Jun, 2014, at 3:44 am, Lee Howard <lee.howard at mainpine.com> wrote:
>>> On 06/27/2014 10:38 AM, Lee Howard wrote:
>>>> On 06/26/2014 08:38 PM, Tom Saxton wrote:
>>>>> Arguably the server account should be per-vehicle but I'm guessing the
>>>>> thought was that anyone who has multiple OVMS vehicles will have them
>>>>> all
>>>>> on the same server and making that app-wide means you only have to
>>>>> enter
>>>>> username, password and server IP once.
>>>>> Of course none of this is any help for figuring out how to do it on
>>>>> Android...
>>>> As I dug-into the Android code better to hard-code the address change
>>>> I discovered - to my delight - that the app server address is stored in
>>>> a per-car data object. Yay! So this is nice. I'm going to give this
>>>> another shot.
>>> Here is the patch. Someone with privs can apply it and commit these
>>> changes to the repository if it meets with their approval.
>>> It's a very small enhancement - basically permitting an interface to
>>> sel_server in the CarData object. The interface is right where it
>>> should be, IMO: right where you enter the vehicle info and passwords.
>>> The default is left to "tmc.openvehicles.com", but the user now has the
>>> capability to modify it (on a per-car basis, even).
>>> I did not change the sel_server initialization value of
>>> "tmc.openvehicles.com". I could have changed this to "" as with the
>>> other CarData strings, but it probably makes little difference. Leaving
>>> it to initialize with "tmc.openvehicles.com" possibly it could be
>>> confusing to someone later who doesn't recognize that the initialized
>>> value is always overwritten by the configured value (as with the other
>>> CarData strings which are initialized to ""). If someone cares they can
>>> modify that at the top of CarData.java.
>>> This patch also makes one obvious grammatical correction in a string
>>> appearing on the same page layout.
>>> If there is any concern just look at the patch - it's a very, very
>>> benign set of changes. This e-mail is longer than the patch is.
>>> Thanks,
>>> Lee.
>>> *Lee Howard*
>>> *Mainpine, Inc. Chief Technology Officer*
>>> Tel: +1 866 363 6680 | Fax: +1 360 462 8160
>>> lee.howard at mainpine.com | www.mainpine.com
>>> <ovms-android-editserver.patch>__________________________________________
>>> _____
> Message: 2
> Date: Sat, 28 Jun 2014 10:05:43 -0700
> From: Lee Howard <lee.howard at mainpine.com>
> To: ovmsdev at lists.teslaclub.hk
> Message-ID: <53AEF5E7.1060806 at mainpine.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> I'm using my built .apk instead of the one from Google Play, but my
> source code is now identical to the one in the git repository.
> Mine is working fine for me.
> Admittedly, I do get confused about which one is the server password and
> which one is the module password, and so I just swap them around if I
> get the password error. Maybe the Android app has the two mixed-up?
> As for the app not needing the your account username... I've never
> needed it on the Android app before. I think that it just uses the car
> info.
> Thanks,
> Lee.
>> Tom
> *Lee Howard*
> End of OvmsDev Digest, Vol 29, Issue 73
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140629/26712ef9/attachment-0001.html>
