[Ovmsdev] Twizy 45
Sat Jun 28 22:33:36 HKT 2014
Gianluca,
the CFG macro commands work identically on both models, automatically
respecting the lower T45 limits.
So there is no usage difference between the models, and no need for
separate instructions.
I just saw I forgot to remove one "only 80 kph" passage from the manual
on page 27, I suppose that's what you mean... fixed, will check that in
later.
Section intro now is:
"All macro commands work identically for the 80 kph and the 45 kph
versions of the Twizy, automatically using the respective limits (see
previous section on limit differences). The limits will be applied on
setting the registers, so you can even load a T80 macro profile into a
T45 (but don't expect similar driving results)."
Am 28.06.2014 14:28, schrieb Gianluca Magalotti:
> First of all please confirm that CFG commands (SPEED, POWER, RECUP,
> etc.) will work properly with Twizy 45. I've tried them on it and
> everything
> In any case I think we have to update twizy documentation at page 26
> to be less ambiguous.
> More in general I think guide should be upgraded to provide
> instructions for both 45 and 80 model. I can try to do it with support.
> *G.*
> Il giorno 28/giu/2014, alle ore 06:00,
> ovmsdev-request at lists.teslaclub.hk
> <mailto:ovmsdev-request at lists.teslaclub.hk> ha scritto:
>> Send OvmsDev mailing list submissions to
>> ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
>> To subscribe or unsubscribe via the World Wide Web, visit
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> ovmsdev-owner at lists.teslaclub.hk
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of OvmsDev digest..."
>> Today's Topics:
>> 1. Re: changing android app server IP (Christopher Cook)
>> 2. Re: changing android app server IP (Lee Howard)
>> 3. Re: changing android app server IP (Lee Howard)
>> Message: 1
>> Date: Fri, 27 Jun 2014 12:44:52 +0800
>> From: Christopher Cook <christopher.cook at webprofusion.com>
>> Subject: Re: [Ovmsdev] changing android app server IP
>> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>> Message-ID: <r7evp31xp6nup2wd3sya83eu.1403844292014 at email.android.com>
>> Content-Type: text/plain; charset=utf-8
>> Off topic but long term it would be prudent to investigate the cross
>> platform options for the app, otherwise there's a lot of duplicate work.
>> I'd consider HTML/Cordova, Xamarin (and perhaps Xamarin Forms),
>> Titanium Sdk, etc.
>> Not saying cross platform doesn't have its challenges but otherwise
>> there's probably not enough dev resources to expect to develop a
>> complete app for all platforms.
>> Chris
>> Tom Saxton <tom at idleloop.com> wrote:
>>> On iOS, the App settings is buried in the System Settings app, a
>>> terrible
>>> UI design. Finally, with iOS 8, there will be a way for apps to send you
>>> straight to the app settings. But for now...
>>> Open the Setting app, then scroll down to the bottom to find a list of
>>> apps that use the built-in settings mechanism. You'll find an item for
>>> "Open Vehicle". In there you'll find the configuration for your OVMS
>>> account, including the server IP address.
>>> That's also where you can turn the Open Charge Map stuff on/off and
>>> where
>>> you can override the module's choice for distance and temperature units.
>>> Arguably the server account should be per-vehicle but I'm guessing the
>>> thought was that anyone who has multiple OVMS vehicles will have
>>> them all
>>> on the same server and making that app-wide means you only have to enter
>>> username, password and server IP once.
>>> Of course none of this is any help for figuring out how to do it on
>>> Android...
>>> Tom
>>> -----Original Message-----
>>> From: Lee Howard <lee.howard at mainpine.com>
>>> Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>>> Date: Thursday, June 26, 2014 at 4:22 PM
>>>> On 06/11/2014 05:23 PM, Mark Webb-Johnson wrote:
>>>>> I think the 'tmc' server is hard-coded in the Android App.
>>>>> The code on github is up-to-date, if anyone wants to take a stab at
>>>>> making it configurable.
>>>> I spent a few days getting acquainted with Android development and
>>>> toying with the OVMS Android app code, loading it onto the Android
>>>> emulator, etc.
>>>> I couldn't decide where was the best place was to put an "app settings"
>>>> menu item, and so I caved and downloaded OVMS from the App Store
>>>> onto my
>>>> iPad...
>>>>> The iOS App has it in the system settings tab.
>>>> I don't see it. Is this in unreleased/unpublished code?
>>>> There is the "OVMS Server IP" in the "Parameters" section of the
>>>> "Control" menu for each configured car. However, I believe that refers
>>>> to the server IP configured in the car module and not for the app. AND
>>>> this same section and menu exist on the Android app (after waiting
>>>> long-enough for it to populate... or getting lucky... I can't
>>>> figure out
>>>> which since it often doesn't populate at all).
>>>> Since for each car the app needs to talk to the same server as the car
>>>> module it would be ideal for changes made to this "OVMS Server IP" in
>>>> the "Parameters" section to apply to both the IP where the module
>>>> communicates *AND* to where the app communicates for that car, but
>>>> since
>>>> this "Parameters" section doesn't even come up at all until the app can
>>>> talk to the server and module, I don't think that's how it works,
>>>> presently, and it would appear to need a lot of effort to get it
>>>> working
>>>> in that fashion.
>>>> It would be nice if I could have different car modules talking to
>>>> different servers and for me to be able to use one app to rule them
>>>> all. The app would merely talk to different servers for each car.
>>>> Anyway... since my initial interest is in doing server-side and
>>>> car-module-side developments (and not so much the app-side of things)
>>>> I'm inclined to just make a hard-coded change to the server IP address
>>>> in my Android app and move on for the sake of being productive.
>>>> Thanks,
>>>> Lee.
>>>> *Lee Howard*
>>>> *Mainpine, Inc. Chief Technology Officer*
>>>> Tel: +1 866 363 6680 | Fax: +1 360 462 8160
>>>> lee.howard at mainpine.com | www.mainpine.com
>> Message: 2
>> Date: Fri, 27 Jun 2014 10:38:05 -0700
>> To: ovmsdev at lists.teslaclub.hk
>> Message-ID: <53ADABFD.4010407 at mainpine.com>
>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>> terrible
>>> UI design.
>> Oh, I see. Thank you. That was very helpful.
>> Yes, it is a terrible UI design by Apple on iOS.
>> I was going to try to do on Android similar to what had been done on
>> iOS, but since this is so terrible, I'd rather not do it like that.
>>> them all
>>> Android...
>> As I dug-into the Android code better to hard-code the address change I
>> discovered - to my delight - that the app server address is stored in a
>> per-car data object. Yay! So this is nice. I'm going to give this
>> another shot.
>> Thanks,
>> Lee.
>> *Lee Howard*
>> Message: 3
>> Date: Fri, 27 Jun 2014 12:44:16 -0700
>> Message-ID: <53ADC990.5010708 at mainpine.com>
>> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
>>>> thought was that anyone who has multiple OVMS vehicles will have them
>>>> all
>>>> enter
>>>> Android...
>>> I discovered - to my delight - that the app server address is stored
>>> in a per-car data object. Yay! So this is nice. I'm going to give
>>> this another shot.
>> Here is the patch. Someone with privs can apply it and commit these
>> changes to the repository if it meets with their approval.
>> It's a very small enhancement - basically permitting an interface to
>> sel_server in the CarData object. The interface is right where it
>> should be, IMO: right where you enter the vehicle info and passwords.
>> The default is left to "tmc.openvehicles.com", but the user now has the
>> capability to modify it (on a per-car basis, even).
>> I did not change the sel_server initialization value of
>> "tmc.openvehicles.com". I could have changed this to "" as with the
>> other CarData strings, but it probably makes little difference. Leaving
>> it to initialize with "tmc.openvehicles.com" possibly it could be
>> confusing to someone later who doesn't recognize that the initialized
>> value is always overwritten by the configured value (as with the other
>> CarData strings which are initialized to ""). If someone cares they can
>> modify that at the top of CarData.java.
>> This patch also makes one obvious grammatical correction in a string
>> appearing on the same page layout.
>> If there is any concern just look at the patch - it's a very, very
>> benign set of changes. This e-mail is longer than the patch is.
>> Thanks,
>> Lee.
>> *Lee Howard*
>> -------------- next part --------------
>> A non-text attachment was scrubbed...
>> Type: text/x-patch
>> Desc: not available
>> URL:
>> <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140627/df2a0078/attachment-0001.bin>
>> End of OvmsDev Digest, Vol 29, Issue 69
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140628/d5bdb152/attachment-0001.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140628/d5bdb152/attachment-0001.vcf>
