[Ovmsdev] GPRS Problem
Sat Jun 28 21:08:34 HKT 2014
Gianluca,
Can you try to work through the steps here:
http://www.openvehicles.com/helpme
If still not working:
If all else fails, please send the output results of the following SMS messages to
support (at) openvehicles (dot) com
MODULE?
SERVER?
GPRS?
STAT
DIAG
On 28 Jun, 2014, at 8:56 pm, Gianluca Magalotti <gianluca at magalotti.net> wrote:
> Hi again,
> I'm not able to enable GPRS in OVMS.
> I've tried some SIM cards with different operators and I think I've used properly APN settings (the same used in the phone) but it still having the 0x0041 error.
> In Italy (where I live) we have LTE, 3,5G 3G, 2.5G and 2G (not for every operator) but if I use the sim in a Phone and force 2G connections both SIM i've tried work (Vodafone and Telecom Italia).
> As lat information GSM works fine and I can communicate with OVMS by SMS.
> Any hint?
> Gianluca
> Il giorno 28/giu/2014, alle ore 06:00, ovmsdev-request at lists.teslaclub.hk ha scritto:
>> Send OvmsDev mailing list submissions to
>> ovmsdev at lists.teslaclub.hk
>> To subscribe or unsubscribe via the World Wide Web, visit
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> ovmsdev-owner at lists.teslaclub.hk
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of OvmsDev digest..."
>> Today's Topics:
>> 1. Re: changing android app server IP (Christopher Cook)
>> 2. Re: changing android app server IP (Lee Howard)
>> 3. Re: changing android app server IP (Lee Howard)
>> Message: 1
>> Date: Fri, 27 Jun 2014 12:44:52 +0800
>> From: Christopher Cook <christopher.cook at webprofusion.com>
>> Subject: Re: [Ovmsdev] changing android app server IP
>> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>> Message-ID: <r7evp31xp6nup2wd3sya83eu.1403844292014 at email.android.com>
>> Content-Type: text/plain; charset=utf-8
>> Off topic but long term it would be prudent to investigate the cross platform options for the app, otherwise there's a lot of duplicate work.
>> I'd consider HTML/Cordova, Xamarin (and perhaps Xamarin Forms), Titanium Sdk, etc.
>> Not saying cross platform doesn't have its challenges but otherwise there's probably not enough dev resources to expect to develop a complete app for all platforms.
>> Chris
>> Tom Saxton <tom at idleloop.com> wrote:
>>> On iOS, the App settings is buried in the System Settings app, a terrible
>>> UI design. Finally, with iOS 8, there will be a way for apps to send you
>>> straight to the app settings. But for now...
>>> Open the Setting app, then scroll down to the bottom to find a list of
>>> apps that use the built-in settings mechanism. You'll find an item for
>>> "Open Vehicle". In there you'll find the configuration for your OVMS
>>> account, including the server IP address.
>>> That's also where you can turn the Open Charge Map stuff on/off and where
>>> you can override the module's choice for distance and temperature units.
>>> Arguably the server account should be per-vehicle but I'm guessing the
>>> thought was that anyone who has multiple OVMS vehicles will have them all
>>> on the same server and making that app-wide means you only have to enter
>>> username, password and server IP once.
>>> Of course none of this is any help for figuring out how to do it on
>>> Android...
>>> Tom
>>> -----Original Message-----
>>> From: Lee Howard <lee.howard at mainpine.com>
>>> Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>>> Date: Thursday, June 26, 2014 at 4:22 PM
>>>> On 06/11/2014 05:23 PM, Mark Webb-Johnson wrote:
>>>>> I think the 'tmc' server is hard-coded in the Android App.
>>>>> The code on github is up-to-date, if anyone wants to take a stab at
>>>>> making it configurable.
>>>> I spent a few days getting acquainted with Android development and
>>>> toying with the OVMS Android app code, loading it onto the Android
>>>> emulator, etc.
>>>> I couldn't decide where was the best place was to put an "app settings"
>>>> menu item, and so I caved and downloaded OVMS from the App Store onto my
>>>> iPad...
>>>>> The iOS App has it in the system settings tab.
>>>> I don't see it. Is this in unreleased/unpublished code?
>>>> There is the "OVMS Server IP" in the "Parameters" section of the
>>>> "Control" menu for each configured car. However, I believe that refers
>>>> to the server IP configured in the car module and not for the app. AND
>>>> this same section and menu exist on the Android app (after waiting
>>>> long-enough for it to populate... or getting lucky... I can't figure out
>>>> which since it often doesn't populate at all).
>>>> Since for each car the app needs to talk to the same server as the car
>>>> module it would be ideal for changes made to this "OVMS Server IP" in
>>>> the "Parameters" section to apply to both the IP where the module
>>>> communicates *AND* to where the app communicates for that car, but since
>>>> this "Parameters" section doesn't even come up at all until the app can
>>>> talk to the server and module, I don't think that's how it works,
>>>> presently, and it would appear to need a lot of effort to get it working
>>>> in that fashion.
>>>> It would be nice if I could have different car modules talking to
>>>> different servers and for me to be able to use one app to rule them
>>>> all. The app would merely talk to different servers for each car.
>>>> Anyway... since my initial interest is in doing server-side and
>>>> car-module-side developments (and not so much the app-side of things)
>>>> I'm inclined to just make a hard-coded change to the server IP address
>>>> in my Android app and move on for the sake of being productive.
>>>> Thanks,
>>>> Lee.
>>>> *Lee Howard*
>>>> *Mainpine, Inc. Chief Technology Officer*
>>>> Tel: +1 866 363 6680 | Fax: +1 360 462 8160
>>>> lee.howard at mainpine.com | www.mainpine.com
>> Message: 2
>> Date: Fri, 27 Jun 2014 10:38:05 -0700
>> To: ovmsdev at lists.teslaclub.hk
>> Message-ID: <53ADABFD.4010407 at mainpine.com>
>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>> UI design.
>> Oh, I see. Thank you. That was very helpful.
>> Yes, it is a terrible UI design by Apple on iOS.
>> I was going to try to do on Android similar to what had been done on
>> iOS, but since this is so terrible, I'd rather not do it like that.
>>> Android...
>> As I dug-into the Android code better to hard-code the address change I
>> discovered - to my delight - that the app server address is stored in a
>> per-car data object. Yay! So this is nice. I'm going to give this
>> another shot.
>> Thanks,
>> Lee.
>> *Lee Howard*
>> Message: 3
>> Date: Fri, 27 Jun 2014 12:44:16 -0700
>> Message-ID: <53ADC990.5010708 at mainpine.com>
>> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
>>>> all
>>>> Android...
>>> I discovered - to my delight - that the app server address is stored
>>> in a per-car data object. Yay! So this is nice. I'm going to give
>>> this another shot.
>> Here is the patch. Someone with privs can apply it and commit these
>> changes to the repository if it meets with their approval.
>> It's a very small enhancement - basically permitting an interface to
>> sel_server in the CarData object. The interface is right where it
>> should be, IMO: right where you enter the vehicle info and passwords.
>> The default is left to "tmc.openvehicles.com", but the user now has the
>> capability to modify it (on a per-car basis, even).
>> I did not change the sel_server initialization value of
>> "tmc.openvehicles.com". I could have changed this to "" as with the
>> other CarData strings, but it probably makes little difference. Leaving
>> it to initialize with "tmc.openvehicles.com" possibly it could be
>> confusing to someone later who doesn't recognize that the initialized
>> value is always overwritten by the configured value (as with the other
>> CarData strings which are initialized to ""). If someone cares they can
>> modify that at the top of CarData.java.
>> This patch also makes one obvious grammatical correction in a string
>> appearing on the same page layout.
>> If there is any concern just look at the patch - it's a very, very
>> benign set of changes. This e-mail is longer than the patch is.
>> Thanks,
>> Lee.
>> *Lee Howard*
>> -------------- next part --------------
>> A non-text attachment was scrubbed...
>> Type: text/x-patch
>> Desc: not available
>> URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140627/df2a0078/attachment-0001.bin>
>> End of OvmsDev Digest, Vol 29, Issue 69
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140628/b67b52e5/attachment-0001.html>
