[Ovmsdev] Nissan Leaf
Nigel Jones
nigel at cherrybyte.me.uk
Mon Jun 16 14:17:02 HKT 2014
Brilliant - thanks Mark.
My OVMS has been offline for a few weeks due to my 12V issue, and then
being away for work... I'm due to get it replaced today (2nd attempt..
let's see if the dealer actually has a suitable battery this time!) at
which point I can get the OVMS back in to experiment.
I'm pretty sure the EV bus is going to be a lot more useful to work with,
especially in terms of battery/charging data so I'll be ordering a cable
the instant I can! Thanks so much for getting the cable specced.
Nigel.
On 16 June 2014 04:15, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> I've ordered a bunch of cables suitable for CAR and EV can buses of Nissan
> Leaf. Pinout is:
> *Pinout B*
> J1962-M DB9-F Signal
> 4 3 Chassis/Power GND
> *6 5 CAN-H (alternate CAN)*
> *14 4 CAN-L (alternate CAN)*
> 13 7 CAN-H (primary CAN)
> 12 2 CAN-L (primary CAN)
> 16 9 +12V Vehicle Power
> J1962 end should be MALE plug with right angle cable. DB9 end should be
> FEMALE.
> Both ends should be enclosed in shells, and cable should be 1metre in
> length.
> The wiring brings J1962-M pins 13 and 12 (EV can bus) through to our
> standard OVMS v2 can bus pins. It also brings the normal CAR can bus
> through on DB9-F pins 5 and 4 (for future use on any dual-can enabled OVMS
> module, or easy re-wiring at the DB9 end).
> Cable itself as per our standard naming:
> For simplicity, I'll ask Fasttech to handle logistics for these, as usual.
Nigel Jones
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140616/c2ad41f4/attachment-0001.html>
Type: image/jpg
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140616/c2ad41f4/attachment-0001.jpg>
