[Ovmsdev] Build environment
Olav A. Antonsen olav at ansit.no
Thu Jun 12 08:16:34 HKT 2014
I'm using the mcc18 compiler from a CD that came in the package when
ordering the OVMS from FastTech.
MPLAB C18 v3.35 Copyright 2000-2010 Microchip Technology Inc.
Looks like 3.47 is the latest version
(http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=SW0060
11).  Do you know if v3.35 still uses medium-optimisation? Is there a way to
detect what level of optimisation the compiler uses?
--Olav
-----Opprinnelig melding-----
Fra: ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] På vegne av Mark Webb-Johnson
Sendt: 12. juni 2014 01:51
Til: OVMS Developers
Emne: Re: [Ovmsdev] Build environment
The issue with building under windows is that the C compiler Microchip gives
for free used to do medium-optimisation under windows, with
high-optimisation a cost option. Then, they switched (silently, without any
fanfare) to no-optimisation for the windows compiler. Both the Linux and OSX
compiler continue with medium-optimisation. Without optimisation, the code
won't fit into available flash space. They sell a commercial version of the
C18 compiler for about US$500. Almost enough to drive one to ARM... I have
heard rumours of people typing 'microchip c18 hack' into google.
Configurations 4 and 5 are the 'full' featured production builds for Tesla
Roadster and Renault Twizy (provided as a convenience for owners of those
vehicles who just want a binary .hex to flash).
On 12 Jun, 2014, at 6:55 am, Olav A. Antonsen <olav at ansit.no> wrote:
> The document
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System/blob/ma
> ster/d
> ocs/OVMS_Development.pdf
> helps a lot when it comes to setting up the dev environment. I set up
> the environment on windows 8, but it seems like everyone else is using
> linux to build the firmware.
> I was able to build the hex file (on win 8), but I haven't been able
> to test the file yet because I'm still waiting for my unit.
> https://dl.dropboxusercontent.com/u/12327518/OVMS.X.production.hex
> Is anyone else using win 8 to build the firmware?
> On the project in MPLAB it's possible to choose between different
> configurations
> 1)V1_Production
> 2)V2_Experimental
> 3)V2_Production
> 4)V2_TR_Production
> 5)V2_RT_Production
> The development documentation tells the user to select "V2_Experimental".
> What is the purpose of configuration 4 and 5?
> --Olav
> [mailto:ovmsdev-bounces at lists.teslaclub.hk] På vegne av Olav A.
> Antonsen
> Sendt: 11. juni 2014 00:21
> Til: 'OVMS Developers'
> Emne: [Ovmsdev] Build environment
> Hello
> Does anyone know if there exists a tutorial/quick guide on how to
> setup the environment needed to code and build the firmware?
> --Olav
