[Ovmsdev] Twizy feature ideas
Wed Jun 11 14:21:06 HKT 2014
Michael,
Can you try to put your simpleclient.htm up on a website you run, then access it? From what I can see that now works (using the simple SORS response recommended by that mozilla article). It seems to me that we fit into the simple CORS model, and it should work. But, I guess it depends on how individual browsers implement the request.
On 11 Jun, 2014, at 2:25 am, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> simpleclient.htm currently does no attempt at a CORS request. I'll prepare a CORS version.
> To test CORS compliance until then, you can use: http://client.cors-api.appspot.com/client
> The test currently does not succeed, I think because we also need at least...
> Access-Control-Allow-Credentials: true
> ...for the cookie.
> Am 09.06.2014 03:06, schrieb Mark Webb-Johnson:
>> Looking at the references mozilla document, it seems that our API use cases fall within the 'simple' approach.
>> I have changed the tmc.openvehicles.com server to return "Access-Control-Allow-Origin: *" for all requests, and that is live now. I have also put up the simpleclient.htm for testing at:
>> http://www.openvehicles.com/simpleclient.htm
>> It seems to work for me. But, then www.openvehicles.com and tmc.openvehicles.com are somewhat related so this is not a true test.
>> On 9 Jun, 2014, at 5:52 am, Michael Balzer <dexter at expeedo.de> wrote:
>>> Nikolay,
>>> I don't need CORS for the auth, that's already working without.
>>> I would need CORS to automatically process the data. And I'd like to do it with minimal changes to the existing API server.
>>> My CORS research result was:
>>> maybe AnyEvent::HTTPD has some CORS support yet?
>>> If not, these are the headers:
>>> Access-Control-Allow-Methods "POST, GET, PUT, OPTIONS, PATCH, DELETE"
>>> Access-Control-Allow-Origin "$ORIGIN"
>>> Access-Control-Allow-Credentials "true"
>>> Access-Control-Allow-Headers "X-Accept-Charset,X-Accept,Content-Type"
>>> ...static values except for the "ORIGIN" variable, which needs to echo back the "Origin:" header from the request. I'm not familiar with AnyEvent::HTTPD, maybe something like
>>> $req->header('Origin')
>>> There's a bit more to do: method OPTIONS also needs to be supported for "preflight requests" (access control negotiation), see https://developer.mozilla.org/en-US/docs/Web/HTTP/Access_control_CORS for detailed request/response examples.
>>> I suppose that will need a separate handler function, but one for the /api root should be sufficient.
>>> Btw, methods "PUT", "PATCH" + "DELETE" can be omitted I think.
>>> But if you'd like to build a Node.js based solution, go ahead, sounds cool :-)
>>> Am 07.06.2014 23:37, schrieb Nikolay Shishkov:
>>>> Hi Michael,
>>>> I think what you have done with the html page is crying for the CORS and an angularjs, single page app.
>>>> Here is an open source project with such app that could "easily" be modified to do the work.
>>>> Check out a working sample here:
>>>> http://angular-client-side-auth.herokuapp.com/login/
>>>> Nikolay
>>>> On Saturday, June 7, 2014 12:42 AM, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
>>>> I believe the following two headers should do it:
>>>> But needs to be tested.
>>>> On Friday, June 6, 2014 2:31 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>> Bug squished. Live on tmc now (and pushed to github).
>>>> Neat web page. Shows promise.
>>>> Regarding the CORS, I’m very willing to make the changes - just not really sure what headers exactly need to be added. Anyone here know what I would need to add?
>>>> Regards, Mark.
>>>> On 6 Jun, 2014, at 3:03 pm, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Nikolay,
>>>> you found an API server bug :-)
>>>> Solution: delete all domain cookies for "openvehicles.com" from your browser before using the API.
>>>> The API server gets confused by multiple cookies. If you visit www.openvehicles.com before using the API, you get a persistent PHP session cookie like this:
>>>> Name SESS619b2b3f204291df32506531f8b446dd
>>>> Host .openvehicles.com
>>>> Pfad /
>>>> As the host defines ".openvehicles.com" and path "/", this cookie also gets sent to the API host, which then confuses this one with the "ovmsapisession" cookie, i.e.
>>>> Name ovmsapisession
>>>> Host tmc.openvehicles.com
>>>> Pfad /api/
>>>> Regards,
>>>> Michael
>>>> Am 05.06.2014 23:46, schrieb Nikolay Shishkov:
>>>>> Thanks Michael,
>>>>> I am getting "login ok" when pressing on the login button, but then all the other buttons are giving "authentication error" message.
>>>>> I could check that the cookie is sent with the request, but the server seems to respond with the 400 code.
>>>>> I tried in Chrome. Where, how do you use the page?
>>>>> Nikolay
>>>>> On Thursday, June 5, 2014 10:59 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> Nikolay,
>>>>> that's right, I intend to get this running without an otherwise necessary proxy, i.e. for local HTML pages on mobile devices or the like. I've been in contact with Mark about CORS on the perl server.
>>>>> A server could of course be used, most simply the HTTP API itself could deliver the client page, but CORS should now enable to cope without and open possible cross origin data/control integrations. Not sure about static pages for this though, not yet tested. I think it would be cool to just load some HTML file in your browser and have a graphical OVMS client.
>>>>> The "code" is currently just a first test bed HTML page to interact with the HTTP API. No graphics, just a simple table view. Works, but is clumsy as hell.
>>>>> Try yourself, I've attached it.
>>>>> Regards,
>>>>> Michael
>>>>> Am 05.06.2014 11:26, schrieb Nikolay Shishkov:
>>>>>> Hi Michael,
>>>>>> I am very interested in the "Browser client using HTTP API and jQuery/Flot for visualization". From the comment that CORS is needed I suspect you want to have the html5 page locally and then fetch data from the server while using other sources for context data.
>>>>>> Have you considered running this on a separate server that serves as a gateway to the TMC server?
>>>>>> Have you uploaded the code somewhere?
>>>>>> I have been playing around with C# client and was thinking of using it on an asp.net server...
>>>>>> Nikolay
>>>>>> On Wednesday, June 4, 2014 11:22 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>> Am 04.06.2014 07:38, schrieb Gianluca Magalotti:
>>>>>> > For nice2have features I'll wait for your list (I have my personal
>>>>>> > list too but maybe we'll have a later focus on that)
>>>>>> So here it is.
>>>>>> If other Twizy drivers would like to add their ideas, you're welcome.
>>>>>> I'll do my best to check new ideas against my collected knowledge of
>>>>>> what's possible up to now and give you some feedback.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140611/fd2c2261/attachment-0001.html>
