[Ovmsdev] Åter-: Re: Mitsubishi logging problem
Nikolay Shishkov
nshishkov at yahoo.com
Mon Jun 9 00:15:18 HKT 2014
I can change the code so the CarOn=1 only when that particular message (the 412) is received. But I still need to set it to 0 when the car is not on and charging.
The current code is setting the CarOn=0 when CANBUS communication is missing for 60 seconds, so If I park the car, and plug it without switching off the CarOn is going to stay 1.
Maybe a timer on the 412 message? So if not received within 10 seconds I can set CarOn to 0?
Nikolay
Den sön 8 jun 2014 10:44 EEST skrev Thomas Bergo:
>From what i remember this should be a easy fix.
>The car_speed and car_odometer @ PID 412 is only updated when ignition is
>ON.
>So setting the car_doors1bits.CarOn = 1 when PID 412 is received should fix
>this issue. Setting car_doors1bits.CarOn = 0 when no CANBUS activity is
>already implemented in the code.
>Regards, Thomas
>2014-06-08 7:51 GMT+02:00 Tom Saxton <tom at idleloop.com>:
>> It sounds like the Mitsubishi code is setting the car_doors1bits.CarON
>> incorrectly. That bit should only be set if the car is turned on. Perhaps
>> it needs to be more discerning as to which CAN messages indicate the car is
>> on.
>> Tom
>> On 6/7/14, 2:32 PM, "Nikolay Shishkov" <nshishkov at yahoo.com> wrote:
>> I have been testing the logging for the mitsubishi and noticed a problem
>> with it - no matter if I was charging or driving the log was always showing
>> driving.
>> I have been looking at the code and I think I found the problem. If I
>> understand this correctly in vehicle_mitsubishi_ticker1 function
>> in vehicle_mitsubishi.c file the car_doors1bits.CarON is set depending on
>> wheather there is CAN bus communication. This is unfortunate since
>> the car_doors1bits.CarON (via CAR_IS_ON) is used in the logging.c to
>> determine if the car is "driving"... and if it is, then it is not
>> "charging".
>> I am not sure what the best solution would be:
>> - to set the car_doors1bits.CarON to 0 if the car is charging or
>> - to refactore the logging code to prefer the CAR_IS_CHARGING and test
>> for it first in the various if/else statements.
>> I have not been able to build and test any of this yet.
>> Any comments, ideas, suggestions on how to solve this?
>> Nikolay
>> _______________________________________________ OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140608/33cf3dc8/attachment.html>
