[Ovmsdev] v2 PCB traces
Sun Jul 20 01:44:36 HKT 2014
Arthur,
Sorry, no PCB layouts available. These are done by the factory, and we don't have them. It is just a two-sided PCB, so if you can't see the trace (top nor bottom) then it is probably ok.
On 17 Jul, 2014, at 11:19 pm, Arthur Hebert <ahebert at gmail.com> wrote:
> Hello,
> Is there a file available with the copper trace layout of the v2 PC board? Is see the schematic files in the GIT repository under vehicle/Car Module/v2-base/, but nothing about the physical hardware layout.
> Specifically I'm looking for a safe spot to drill a couple of holes in the PCB without damaging the circuit.
> Any help is much appreciated.
> Thanks,
> Arthur Hebert
