[Ovmsdev] i-Miev/C-Zero/iOn
Thu Jan 23 16:29:47 HKT 2014
Mark,
if the Mitsubishi code does not use the new polling hooks, poll0() will
not be called if the polling code is compiled in.
I had the same problem for the Twizy, that's why I introduced the
OVMS_POLLER compiler switch.
Am 22.01.2014 02:18, schrieb Mark Webb-Johnson:
> Thomas,
> Strange. So far, I see 4 cars using 2.6.2, but only one (presumably
> yours) is showing authentication errors.
> I also can't see any changes to the vehicle_mitsubishi.c code that
> would cause poll0 to stop working. It is certainly working in other
> vehicle modules.
> I'll keep looking, but would be grateful if you could try to narrow
> down the poll0 problem.
> On 22 Jan, 2014, at 5:00 am, Thomas Bergo <thomas.bergo at gmail.com
> <mailto:thomas.bergo at gmail.com>> wrote:
>> Mark,
>> Was testing the new 2.6.2 code on i-Miev today.
>> Two observations:
>> - Lots of restarts and "Vehicle authentication failed" messages in
>> the iOS app
>> - No CAN bus messages form PID in poll0, while messages in poll1 is
>> working OK.
>> Programmed the OVMS module with a version, and verified that the
>> module was OK.
>> Regards, Thomas
>> 2013/10/30 Thomas Bergo <thomas.bergo at gmail.com
>>     Matt,
>>     Please report back when you have done some testing on the QC.
>>     If the car report 0A while QC, the current code will not detect
>>     that we are charging. So then we need to rely on the estimated
>>     range reported as 255 to detecting that the car is QC.
>>     Regards, Thomas
>>     2013/10/30 Matt Beard OVMS <smvo at mxf.org.uk <mailto:smvo at mxf.org.uk>>
>>         Hi Thomas,
>>         During QC you don't get valid values reported in 0x389 - it
>>         seems to be constant 255V, 0A during QC.
>>         My code is relying on the fact that the estimated range only
>>         ever seems to be reported as 255 during QC (except for the
>>         first few messages at startup, but those are easy to filter
>>         out). In my testing so far this seems to work for detecting
>>         the start and end of QC. I am going to be doing 3 more tests
>>         today with my latest code and will report back later.
>>         Matt
>>         On 27 October 2013 20:13, Thomas Bergo
>>         <thomas.bergo at gmail.com <mailto:thomas.bergo at gmail.com>> wrote:
>>             Hi Matt
>>             I have started to look into the QC code. And i have one
>>             concern.
>>             Have you seen if the voltage and charging current (PID
>>             0x389) is reported during QC?
>>             If not, we are not able to detect that the car is
>>             charging during QC with current code.
>>             Thomas
>>             _______________________________________________
>>             OvmsDev mailing list
>>             OvmsDev at lists.teslaclub.hk
>>             <mailto:OvmsDev at lists.teslaclub.hk>
>>             http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>         OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140123/7e6e41e5/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140123/7e6e41e5/attachment-0002.vcf>
