[Ovmsdev] Twizy release 3.0.2
Sat Jan 18 22:14:59 HKT 2014
I implemented an "offline" cfg reset method -- which btw unfortunately
could also be used by any thieve... well, maybe not quite "any" though ;-)
Am 18.01.2014 13:55, schrieb Mark Webb-Johnson:
> Sounds like it might be cool to hook this into the valet msg. Valet ON
> is save limit then set speed limit to 10kph. Valet off is restore
> limit. Lock/Unlock could be similar.
> I would just be a little concerned if gsm connectivity was lost after
> lock/valet. Without connectivity, you couldn't unlock and it would be
> a real slow drive to the next cell tower :-)
> Mark
> On 18 Jan, 2014, at 8:14 pm, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
>> Nikki,
>> nice ideas.
>> You can reduce available power simply by a CFG DRIVE command, i.e.
>> "CFG DRIVE 10" will reduce available power to 10%.
>> To completely disable it, "CFG DRIVE 0" should also work -- haven't
>> tried that yet.
>> Another option if valet mode still needs the power (i.e. hills): "CFG
>> SPEED 10" will reduce maximum speed to 10 kph.
>> Am 18.01.2014 11:57, schrieb Nikki Gordon-Bloomfield:
>>> Michael,
>>> Great work!
>>> I wonder if there would be a way to use this as a valet mode option?
>>> Really reduce motor settings etc?
>>> Yes, its no Tesla, but more might be useful for some.
>>> Also, could this be used to make the twizy more secure?
>>> I know it has an immobilizer but no locks on the doors, making it
>>> perhaps a target for thieves?
>>> Could OVMS he used to lock down a twizy with really poor parameters?
>>> In other words, if someone does defeat the lock and turn it on, this
>>> could event them from moving the car?
>>> On 18 Jan 2014 08:27, "Michael Balzer" <dexter at expeedo.de
>>>     Thanks :-)
>>>     There should also be a visible change in crash history records,
>>>     my crash count with the new version is still 0.
>>>     The extended mode also has been running 100% fine during the
>>>     last days, so I can also check in some more Twizy & CANopen
>>>     functionality later on :-)
>>>     Btw, I read about the Mia also using a SEVCON Gen4. So if
>>>     there's a Mia OVMS development going on somewhere: the Twizy
>>>     tuning commands should be easily portable, should just need to
>>>     be adapted to the other defaults.
>>>     Regards,
>>>     Michael
>>>     Am 18.01.2014 03:46, schrieb Mark Webb-Johnson:
>>>         Wow, just wow!
>>>         I've been running this (2.6.x code, with Michael's interrupt
>>>         handling enhancements, and a switch to extended mode
>>>         compilation) in my car and the difference is amazing.
>>>         The best indicator I have of interrupt performance is the
>>>         digital speedo in the Tesla Roadster. That relies on picking
>>>         up the transmission of a single CAN bus message, then
>>>         following it up very quickly with a sequence of 3 override
>>>         CAN bus messages. Previously it was ok, but now (with the
>>>         new Interrupt code) it seems much much smoother.
>>>         Well done, Michael! Great contribution.
>>>         I'll be fixing up the compiler warnings (just a difference
>>>         in 'static' vs 'auto' storage mode in extended mode) and
>>>         then will commit the switch to extended mode to the
>>>         repository as 2.6.2. I should get this done today.
>>>         Regards, Mark.
>>>         On 15 Jan, 2014, at 6:19 am, Michael Balzer
>>>         <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>             Mark,
>>>             I now also have compiled in extended mode (got no
>>>             choice). I only get some warnings about static function
>>>             args, not sure if they need to be static, doesn't seem so.
>>>             First tests have been completely fine in both diag and
>>>             live mode, so I'll use the extended mode firmware during
>>>             the next days to see if anything goes wrong.
>>>             Regards,
>>>             Michael
>>>             Am 08.01.2014 14:18, schrieb Mark Webb-Johnson:
>>>                 Not sure if we can use extended mode or not - if we
>>>                 can, it will give us a lot of breathing room. If I
>>>                 enable extended mode, everything compiles just fine
>>>                 (all configs). Supposedly the PIC18F2685 supports
>>>                 the C-optimised extended instruction set.
>>>                 Regards, Mark.
>>>             Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>             Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>             <dexter.vcf>_______________________________________________
>>>             OvmsDev mailing list
>>>             OvmsDev at lists.teslaclub.hk
>>>             <mailto:OvmsDev at lists.teslaclub.hk>
>>>             http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>         OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>> <dexter.vcf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140118/b258cc4c/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140118/b258cc4c/attachment-0002.vcf>
