[Ovmsdev] Twizy release 3.0.2
Wed Jan 8 21:11:12 HKT 2014
Mark,
can't look at the config right now, but if V2_*
contain everything, I think that will be too much
on both ROM and RAM size now.
I had a similar problem with V2_RT before
disabling logging and acc.
Maybe you can get it to build if you disable the
Twizy battery monitor and the new cfg command.
Am 08.01.2014 13:50, schrieb Mark Webb-Johnson:
> Michael,
> I added the OVMS_POLLER as necessary, and
> committed that code. But, not getting much luck
> compiling this.
> The single vehicle configs (V1, V2_TR and V2_RT)
> compile ok.
> But, V2_EXPERIMENTAL gives the following error:
> Error - section 'MATH_DATA' can not fit the
> section. Section 'MATH_DATA' length=0x00000014
> and V2_PRODUCTION gives:
> Error - section '.tmpdata' can not fit the
> section. Section '.tmpdata' length=0x00000024
> I'm not sure why it is complaining about
> .tmpdata, when it should now be using
> high_isr_tmpdata for the code.
> I'll keep looking, but I'm not sure if this
> approach will be so easy...
> On 8 Jan, 2014, at 8:08 am, Mark Webb-Johnson
> <mark at webb-johnson.net
> <mailto:mark at webb-johnson.net>> wrote:
>> Michael,
>> Nice. I'll have a play with it this weekend.
>> P.S. I was aware (recently) of the ISR stuff,
>> but didn't realise the fix was so (relatively)
>> easy. Thanks for handling this.
>> On 5 Jan, 2014, at 9:22 am, Michael Balzer
>> <dexter at expeedo.de <mailto:dexter at expeedo.de>>
>> wrote:
>>> Hi everyone,
>>> I have integrated the latest Twizy release
>>> 3.0.2 with framework version 2.6.1 and pushed
>>> it into the main repository.
>>> Please note:
>>> 1) I had to introduce a new preprocessor flag
>>> for the vehicle polling system: OVMS_POLLER
>>> The Twizy firmware will just barely compile
>>> with it enabled, but not work (poll0() will
>>> not be called). Anyway it doesn't need the
>>> polling system, so I disabled it instead of
>>> changing something.
>>> You'll need to add the flag to your build
>>> configurations if you use the polling.
>>> 2) I have included a major stability
>>> improvement for the interrupt codes. With
>>> deeper nesting and stack usage, my crashes
>>> multiplied. On checking everything I stumbled
>>> across the info, that calling functions is
>>> among the worst things to do inside an ISR.
>>> The compiler needs to save the complete
>>> context including all temporary data on the
>>> stack, which is both very time consuming and
>>> can use a lot of stack space.
>>> There's a good info on this topic on the web:
>>> http://www.xargs.com/pic/c18-isr-optim.pdf
>>> I've implemented a separate tmpdata section
>>> for both low and high priority ISRs based on
>>> this info and had not a single crash since
>>> then. Also no CAN data has been lost since the
>>> change and the module has become rock steady
>>> on the GSM and GPS connection.
>>> The downside is, it needs some additional RAM
>>> for the ISR tmpdata sections. As both the ISR
>>> main/entry functions and all called functions
>>> need to use the separate tmpdata section, I
>>> changed all vehicle modules accordingly.
>>> Please check if everything still works.
>>> With acc and logging disabled and all Twizy
>>> features activated I now get...
>>> RAM Used: 3152 (0xC50) Free: 176 (0xB0)
>>> Flash Used: 97756 (0x17DDC) Free: 548 (0x224)
>>> So I'm approaching the final frontier... but
>>> in another way as expected, I always thought
>>> RAM is my problem...
>>> Am 31.12.2013 13:39, schrieb Michael Balzer:
>>>> Hi everyone,
>>>> sorry for dropping behind/off last months,
>>>> lots of work.
>>>> I've not been able to catch up on the
>>>> framework advances yet, but nevertheless
>>>> wanted to announce a major Twizy update I'm
>>>> currently working on.
>>>> This update enables access to the SEVCON
>>>> controller configuration of the Twizy.
>>>> Low level commands allow read and write
>>>> access to all SDOs. Macro commands allow to
>>>> easily change common settings like maximum
>>>> speed, maximum torque, power and recuperation
>>>> levels and drive profile characteristics.
>>>> There is a potential benefit for other
>>>> vehicles from this development: I've done a
>>>> basic CANopen SDO protocol implementation for
>>>> this. The implementation is specific to the
>>>> Twizy only because it's limited to addressing
>>>> just node #1 and currently only supports
>>>> expedited SDO transfers, not segmented. The
>>>> node id could easily be made variable, and
>>>> segmented transfers should be not much of a
>>>> problem. It still is nowhere near a complete
>>>> CANopen protocol implementation, but allows
>>>> SDO reading and writing. Tell me if this
>>>> sounds useful for other vehicles.
>>>> As I've not yet integrated your latest work,
>>>> I've pushed this into my Github repository
>>>> first:
>>>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System
>>>> I'll also wait for some more user feedback
>>>> before going on, and I also want to implement
>>>> support for the Twizy 45 before merging this in.
>>>> Just wanted to let you know in case you
>>>> wonder about rising OVMS hardware sales
>>>> lately ;-)
>>>> Oh, and I wish you all a happy new year!
>>>> Regards,
>>>> Michael
>>>> OvmsDev mailing list
>>> <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140108/f0d6a9bd/attachment.htm>
