[Ovmsdev] Twizy release 3.0.2
Sat Jan 18 20:14:52 HKT 2014
Nikki,
nice ideas.
You can reduce available power simply by a CFG DRIVE command, i.e. "CFG
DRIVE 10" will reduce available power to 10%.
To completely disable it, "CFG DRIVE 0" should also work -- haven't
tried that yet.
Another option if valet mode still needs the power (i.e. hills): "CFG
SPEED 10" will reduce maximum speed to 10 kph.
Am 18.01.2014 11:57, schrieb Nikki Gordon-Bloomfield:
> Michael,
> Great work!
> I wonder if there would be a way to use this as a valet mode option?
> Really reduce motor settings etc?
> Yes, its no Tesla, but more might be useful for some.
> Also, could this be used to make the twizy more secure?
> I know it has an immobilizer but no locks on the doors, making it
> perhaps a target for thieves?
> Could OVMS he used to lock down a twizy with really poor parameters?
> In other words, if someone does defeat the lock and turn it on, this
> could event them from moving the car?
> On 18 Jan 2014 08:27, "Michael Balzer" <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
> Thanks :-)
> There should also be a visible change in crash history records, my
> crash count with the new version is still 0.
> The extended mode also has been running 100% fine during the last
> days, so I can also check in some more Twizy & CANopen
> functionality later on :-)
> Btw, I read about the Mia also using a SEVCON Gen4. So if there's
> a Mia OVMS development going on somewhere: the Twizy tuning
> commands should be easily portable, should just need to be adapted
> to the other defaults.
> Am 18.01.2014 03:46, schrieb Mark Webb-Johnson:
> Wow, just wow!
> I've been running this (2.6.x code, with Michael's interrupt
> handling enhancements, and a switch to extended mode
> compilation) in my car and the difference is amazing.
> The best indicator I have of interrupt performance is the
> digital speedo in the Tesla Roadster. That relies on picking
> up the transmission of a single CAN bus message, then
> following it up very quickly with a sequence of 3 override CAN
> bus messages. Previously it was ok, but now (with the new
> Interrupt code) it seems much much smoother.
> Well done, Michael! Great contribution.
> I'll be fixing up the compiler warnings (just a difference in
> 'static' vs 'auto' storage mode in extended mode) and then
> will commit the switch to extended mode to the repository as
> 2.6.2. I should get this done today.
> On 15 Jan, 2014, at 6:19 am, Michael Balzer <dexter at expeedo.de
> Mark,
> I now also have compiled in extended mode (got no choice).
> I only get some warnings about static function args, not
> sure if they need to be static, doesn't seem so.
> First tests have been completely fine in both diag and
> live mode, so I'll use the extended mode firmware during
> the next days to see if anything goes wrong.
> Am 08.01.2014 14:18, schrieb Mark Webb-Johnson:
> Not sure if we can use extended mode or not - if we
> can, it will give us a lot of breathing room. If I
> enable extended mode, everything compiles just fine
> (all configs). Supposedly the PIC18F2685 supports the
> C-optimised extended instruction set.
> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140118/a4103974/attachment-0001.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140118/a4103974/attachment-0001.vcf>
