[Ovmsdev] Motor temp does not support negative numbers (car_tmotor)
Pierre Uhl
pi.uhl at bluewin.ch
Mon Jan 13 23:52:35 HKT 2014
Highest Motor Temperature on Roadster is 157°C. Then the Power will be
reduced to cool down the Motor.
Rgards
Pierre Uhl
Von: ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Håkon Markussen
Gesendet: Montag, 13. Januar 2014 13:50
An: OVMS Developers
Betreff: [Ovmsdev] Motor temp does not support negative numbers (car_tmotor)
Hi (Mark).
In ovms.h the motor temperature is defined as unsigned char (non-negative):
extern unsigned char car_tmotor; // Tmotor
Currently the weather is cold in Norway (-15 C) and I noticed that motor
temp was 244C.
Is it possible to update the car_tmotor to
extern signed char car_tmotor; // Tmotor
in ovms.h?
Best regards
Håkon
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140113/d35fa76e/attachment.html>
