[Ovmsdev] Motor temp does not support negative numbers (car_tmotor)
Håkon Markussen
hakon.markussen at gmail.com
Mon Jan 13 22:31:03 HKT 2014
I was not aware of the industry standard -40C offset, so thank you (all)
for good inputs.
The "problem" is hereby addressed :)
@Kevin: Can you recall the highest motor temperature ever seen on the
Roadster? Do you know is Model S has the same temperature characteristics
as the Roadster?
Br.
Håkon
2014/1/13 Mastro Gippo <gipmad at gmail.com>
> Håkon, it is industry standard to apply an offset of -40C. We should do
> that instead of transforming it to signed, as Collin said. That would also
> be directly compatible to the CAN message from the twizy. Let's wait for
> Mark's opinion.
> Regards
> MG
> 2014/1/13 Håkon Markussen <hakon.markussen at gmail.com>
>> The highest motor temperature I ever have seen on Think City is ~45 C.
>> This is the offset for the cooling thermostat
>> I cannot even imagine that other EV-motors should reach a temperature
>> near 100C? Then the cooling system have to be out of order ... or ...?
>> Anybody who knows the expected operation range of motor temp for
>> Roadster, Leaf, iMiEV and Zwizy?
>> Think City reports temperature in 8 bits - signed.
>> When bit8 (msb) is set to "1" it means negative temperature, so when the
>> motor temp actually is -1C , OVMS reports 255C. When motor temp is -11 Ovms
>> reports 245C ,etc.
>> I think that this problem might apply to all vehicles(?).
>> Mark, do you have any suggestion for solution?
>> Br.
>> Håkon
>> 2014/1/13 Collin Kidder <collink at kkmfg.com>
>>> I don't think you'd want to do that. 127 deg C really isn't that
>>> terribly hot and -128C is extremely cold. If it is necessary to retain use
>>> of an 8 bit variable then the standard solution is to just offset the
>>> temperature stored by -40. That way you can read -40 to 215C which is a
>>> pretty reasonable range. Unfortunately, I fear such a change would
>>> necessitate many other changes in code. It might be better to expand to a
>>> signed 16 bit integer.
>>> On Mon, Jan 13, 2014 at 7:50 AM, Håkon Markussen <
>>> hakon.markussen at gmail.com> wrote:
>>>> Hi (Mark).
>>>> In ovms.h the motor temperature is defined as unsigned char
>>>> (non-negative):
>>>> extern unsigned char car_tmotor; // Tmotor
>>>> Currently the weather is cold in Norway (-15 C) and I noticed that
>>>> motor temp was 244C.
>>>> Is it possible to update the car_tmotor to
>>>> extern signed char car_tmotor; // Tmotor
>>>> in ovms.h?
>>>> Best regards
>>>> Håkon
>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140113/4ce2280e/attachment-0001.html>
