[Ovmsdev] Twizy45 testing needed
    Julien (JaXX) Banchet
    jaxx at jaxx.org
    Tue Feb  4 16:17:59 HKT 2014
Hi,
Sorry for the late extra report.
Well, it gave me time to try the setings with a bit more time.
I bet some had a concern about the effect of these settings on range.
Well after a few days of adapting, I can say that it has very little
effect on range, less than a 10% cutback depending on driving habits,
though achieving better and needless to say "Safer" performances.
I'm mostly against vehicle modifications of such sort, that said, on a
country to country basis, the 45kmh limitation on 50kmh limited roads is
in the end a bit dangerous where people are aggressive to the least
while driving (I've only had good surprises in most surrounding
countries). Therefor, being able to reach 50kmh, or even a tad more to
keep up with the flow, avoids being pushed (or bullied) too much. (I did
try 60 (+2) on some 70kmh segments, but rarely ever went over 50 in
general. The simple fact of having a bit extra watts in the wheel shows
that the Twizy deserves respect, the bullying evaporates with it :-)
But this can be a subject of much debate.
So again, with all the subjectivity this post can have, I believe that
Michael has done a tremendous job! Thanks !
Oh, be aware: despite the bitter cold and it's effect on the traction
battery, I estimate I kept my previous average of 70km of range, and
still have my usual 3 stars on the eco-meter, though it takes a sensibly
softer foot on the pedal. But, these mods will drastically change the
speed of variation of the range-meter. Extra power with extra recup
makes the estimation less smooth, obviously :-)
All I need now is a "Low Service Battery" alert, idiots managed to turn
just about everything on (mainly the warning lights) and killed the
service battery the other night :-)
Hugs and drive Safe !
JaXX
( damn, despite being the coolest driver in town, I hope no cops are
reading this, my name is on the car o_O )
Le 27/01/2014 12:44, Michael Balzer a écrit :
> The "knock" sound is due to the gear box being coupled a little bit
> loosely. This knock can also be heard on rapid load changes.
> That's why the "start" ramp is normally so slow (3% on the T45, 4% on
> the T80), SEVCON calls this parameter "oscillation damping for loose
> gear boxes".
> So 100% instead is of course a radical change ;-), experiment with
> this value (first RAMPS param) until it sounds ok.
> Range will be affected by "race modes", but you can also configure
> "eco" modes as well. You can also gain a little bit range through
> higher recuperation, if you carefully use the power plus. It's all in
> your foot :-)
> Am 27.01.2014 09:14, schrieb Julien (JaXX) Banchet:
>> Well, 11km run, with a few higher speed portions.
>> Achieves illegal speeds swiftly ! (I'll put it back to normal)
>> RAMPS/SMOOTHING combo kicks, literally.
>> Actually, when putting the power on, you can hear a "knock" sound,
>> like if the motor made a x° rotation to sync in some position, but I
>> could be wrong.
>> At low speeds, pushing or releasing the accelerator is immediate
>> followed by the expected behavior, making the car rock a bit.
>> Range seems affected, no massively but there is a difference, of
>> course, will have to see that over time, plus it was freezing.
>> see ya soon !
>> Le 27/01/2014 02:17, Mark Webb-Johnson a écrit :
>>> The flexibility in the tuning of this is making me very jealous!
>>> Mark.
>>> On 27 Jan, 2014, at 3:14 am, Julien (JaXX) Banchet <jaxx at jaxx.org>
>>> wrote:
>>>> Sure will try tomorrow !
>>>> Maybe something like this
>>>> CFG RECUP 25 35
>>>> CFG TSMAP N 100 100 80 50
>>>> CFG TSMAP B 75 100 80 60
>>>>> 39 will have a recup kick with breaks (urban situation anyways,
>>>>> barely ever over that speed, unless I leave early enough :-) )
>>>> the sub 33kmh will have near matching values between neutral and
>>>> breaking, a no surprise zone in other words
>>>> Won’t be getting back much more juice in the end but well, it’s
>>>> still that :)
>>>> Will give a shoot to the RAMPS/SMOOTH combo as well,
>>>> MfG,
>>>> JaXX
>>>> De: Michael Balzer dexter at expeedo.de
>>>> Répondre: Michael Balzer dexter at expeedo.de
>>>> Date: 26 janvier 2014 at 19:58:38
>>>> À: Julien (JaXX) Banchet jaxx at jaxx.org, ovmsdev at lists.teslaclub.hk
>>>> Sujet: Re: [Ovmsdev] Twizy45 testing needed
>>>>> Hi Julien,
>>>>> thanks :-)
>>>>> Great to read everything works as designed :-)
>>>>> Supplementing the POWER command, you should also try
>>>>> RAMPS 100 100
>>>>> SMOOTH 0
>>>>> -- this sets start and acceleration ramps to maximum speed and
>>>>> disables
>>>>> smoothing. This makes the Twizy much more responsive to the throttle
>>>>> and
>>>>> can make more difference than the 11% torque increase (120% will
>>>>> be cut
>>>>> down internally to 111%).
>>>>> For RECUP, take a look at docs/Twizy-Torque-Speed-Profiles.ods:
>>>>> you can
>>>>> shape the braking recuperation strength per speed. Try:
>>>>> TSMAP B 80 100 60 40
>>>>> -- this is from sheet 2 "Recup1" and will shift the braking recup
>>>>> max to
>>>>> ~39 kph. This works pretty well on the T80 with 40% braking recup
>>>>> level.
>>>>> Btw: the TSMAP speed points are at the same for the T45.
>>>>> Regards,
>>>>> Michael
>>>>> Am 26.01.2014 19:20, schrieb Julien (JaXX) Banchet:
>>>>>> Hi all,
>>>>>> Hi Michael,
>>>>>> Listen, first things first:
>>>>>> Wow, what a f*cki’n crazy great job you’ve done there !!!
>>>>>> Now: well, works as expected on my Twizy45,
>>>>>> Tried these on a very short run:
>>>>>> POWER 120 115 110 (I believe I feel a slight difference, but not
>>>>> that obvious)
>>>>>> SPEED 60 75 (didn’t have any slope to go beyond, got up to 60 neat
>>>>> and fast, kind of surprising/scary at first)
>>>>>> RECUP 27 42
>>>>>> Ok, Recup: 27 instead of the default 21 (on the T45) is sensible,
>>>>> at the limit of slowing down a bit to fast for the following cars
>>>>> without a brake light
>>>>>> 42 on brake is scary: you’re already at 27, once you barely touch
>>>>> the brake, 42% recuperation kicks in after half a second, so you
>>>>> get your expected friction-brake slowdown and boom, an extra
>>>>> slow down from recuperation… 42 is really too agressive, making
>>>>> an in between/modulated foot controlled slowdown nearly impossible…
>>>>>> Will try 25 35 (Delta of 10% instead of 15%)
>>>>>> We’ll see…
>>>>>> Again: w00t! in town the crazy parisians will be less tempted
>>>>> to push me over the road as long as I can keep up with their illegal
>>>>> speeds !
>>>>>> (note: This is to be done at your own risk, mostly legal)
>>>>>> (sorry for the lack of mail quote, I deactivated the digest mode
>>>>> which is kind of a pita)
>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>> OvmsDev mailing list
