[Ovmsdev] OvmsDev Digest, Vol 30, Issue 12
Fri Aug 1 16:54:52 HKT 2014
Jeff,
I think the diag port is not something a normal user should be
confronted with. The OVMS setup and troubleshooting is already quite
complex for a simple user. If you're able to use a serial port, you're
able to find and read the tech docs -- just my 2 cents.
Now for your trace: is a GSM lock configured (parameter #13)? If so, try
without.
Also, does the SIM work correctly in a mobile phone?
Am 01.08.2014 06:46, schrieb Aatheus:
> Mark,
> Thank you for the info. Can the serial port parameters get added to the
> helpme page? The info is not findable anywhere on the page. I did find
> it in the development PDF, but it was hard to find!
> I managed to get serial access to the OVMS board, and it looks like the
> data call is repeatedly failing. I verified that my GeoSIM card has $15
> balance on it. Is my SIM card screwed up? I activated the SIM on the
> GeoSIM site, and I think it's set up ok.
> RDY
> +CFUN: 1
> +CPIN: READY
> +PACSP: 1
> +CREG: 0
> +CREG: 2
> Call Ready
> GPS Ready
> AT
> OK
> AT+CGPSPWR=1;+CGPSRST=0;+CSMINS?
> +CSMINS: 0,1
> OK
> AT+CCID;+CPBF="O-";+CPIN?
> (SERIAL OBSCURED)
> +CPIN: READY
> OK
> AT+IPR?;+CREG=1;+CLIP=1;+CMGF=1;+CNMI=2,2;+CSDH=1;+CIPSPRT=0;+CIPQSEND=1;+CLTS=1;E0
> +IPR: 9600
> OK
> ERROR
> +CREG: 3
> +CREG: 0
> OK
> +CSMINS: 0,1
> OK
> (SERIAL OBSCURED)
> +CPIN: READY
> OK
> +IPR: 9600
> OK
> ERROR
> +CREG: 3
> OK
> +CSMINS: 0,1
> OK
> (SERIAL OBSCURED)
> +CPIN: READY
> OK
> +IPR: 9600
> OK
> ERROR
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140801/2f517994/attachment.vcf>
