[Ovmsdev] Hello, & Nissan Leaf support
Tue Apr 29 14:38:17 HKT 2014
Just a note to say thanks for Kevin for all his support for this project. You have been instrumental in several key areas, and it is most appreciated.
On 28 Apr, 2014, at 5:26 pm, Kevin Sharpe <kevin.sharpe at zerocarbonworld.org> wrote:
> Just to keep everyone in the loop, I’ve given Nigel, Nikki, and Robert, free OVMS hardware to kick start the Leaf development.
> I’m happy to do the same for other people if they can convince me they’ll contribute to the development in some way. Send me an email and convince me :-)
> Exciting times!
> Kevin Sharpe | Founder & Trustee | Zero Carbon World, a UK Registered Charity #1141347
> From: Nigel Jones <nigel at cherrybyte.me.uk>
> Date: Monday, 28 April 2014 09:18
> Subject: Re: [Ovmsdev] Hello, & Nissan Leaf support
> Hi all,
> I'm currently waiting for some the hardware.(ovms, odb cable, gps antenna) It should arrive in the next few days to add to the pic 3 programmer, various obd cables, serial adapter I have here, a mobile SIM & I've also setup some fresh VMs for development & have partially setup git. More of this last item & mplabx/compiler to to be setup soon.
> I am working this week but will try and squeeze in a little time to at least get the HW programmed with the current firmware & see what we have.
> Nigel.
> On 28 April 2014 09:07, Paul Churchley <paul at churchley.org> wrote:
>> I bought 2 OVMS kits... one for my Ampera and one for my 2011 Nissan Leaf. I set up the Ampera one and that os now operational with the installed version of the firmware but I haven't yet set up the Leaf.
>> Now that Nigel is coming on board (Hi Nigel!), who I have met a few times now, perhaps between him and me we might start to make a bit of progress. I am rather busy with Plug in Britain at the moment so I can't promise to do much of the actual codong but I certainly can be someone local that can try stuff out on the Leaf and may be help a bit.
>> So I'll stay in the loop and if there is anything you need help with just say :-)
>> Paul Churchley
>> On 28 April 2014 07:09, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> Nikki,
>>> The car bus has the car stuff on it (speed, gear, etc). The ev stuff has the battery, pem, etc, on it (voltages, etc). They are bridged by one of the controllers sitting on both the buses, so we can poll the EV bus from the car bus, and vice versa.
>>> The community documentation is lousy, but the PIDs and various bus messages are now fairly well known. The LeafSpy and active-polling threads work certainly contain enough information for OVMS to work on the Leaf (at least for basic monitoring). Jury is out on whether we will be able to do stuff like lock/unlock and preheat from the car or ev buses.
>>> On 28 Apr, 2014, at 2:03 pm, Nikki Gordon-Bloomfield <Nikki at littlecollie.com> wrote:
>>>> On Mon, Apr 28, 2014 at 5:54 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>>> On 16 Apr, 2014, at 12:54 am, Nigel Jones <nigel at cherrybyte.me.uk> wrote:
>>>> Did we ever get to the bottom of the differences between the different busses? I know the EV bus and the CAN bus are on different pins....
>>>> OvmsDev mailing list
> Nigel Jones
> _______________________________________________ OvmsDev mailing list OvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140429/805d11ba/attachment.html>
