[Ovmsdev] Connection issues
Matt Beard OVMS
smvo at mxf.org.uk
Mon Sep 30 16:03:21 HKT 2013
There is a historical oddity in the UK as T-Mobile (TMO UK) and Orange used
to be two separate networks, but are now the same company. Both physical
networks work at times, but both also fail at times. This is true in a wide
area (I have tried as far south as Perth which is about 100 miles away) so
it can't be an issue with the local cell tower. There is no O2 coverage in
my area of the country (despite what their coverage map claims). I think I
may need to return the hardware.
Matt
On 30 September 2013 08:10, Nikki Gordon-Bloomfield
<nikki at littlecollie.com>wrote:
> What's the coverage map in your area like, Matt?
> Sent from my iPhone
> > On 30 Sep 2013, at 08:06, Kevin Sharpe ZCW <
> kevin.sharpe at zerocarbonworld.org> wrote:
> > I use giffgaff (O2 network) and it works like a charm all over the UK.
> > I couldn't get GEO-sim to work although I gave up quickly because
> giffgaff was easy.
> > Kevin
> >> On 30 Sep 2013, at 07:34, "Nikki Gordon-Bloomfield" <
> nikki at aminorjourney.com> wrote:
> >> If the carrier was the problem, it would be concurrent with the
> problems I had when I tried to put a non-compatible SIM in the unit.
> >> Matt, I can recommend O2… if you're having problems with signal in the
> area.
> >> I would suggest you run it on the bench for a dummy test in generic
> mode? See if it connects then -- as Mark says, with GSM Lock…
> >>> On 30 Sep 2013, at 07:24, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
> >>> Matt,
> >>> One thing glaring is the flapping between Orange and TMO. Can you try
> to GSMLock to just one (preferred) provider (using PARAM_GSMLOCK, #13)?
> >>> The log itself shows "PDP: DEACT" - which means it can't establish
> GPRS. The COPS gets through ok, so it managed to connect to GSM ok - which
> would seem to indicate the antenna and basic network reception was ok.
> >>> Regards, Mark.
> >>>> On 30 Sep, 2013, at 3:54 AM, Matt Beard <matt at beard.tv> wrote:
> >>>> I have been having issues with my OVMS module not connection.
> >>>> When it does connect I tend to find it has very good signal strength,
> but it often will not connect when I power it on and I find that it drops
> off quite often.
> >>>> I received my RS232/USB adaptor so logged the following data, any use?
> >>>> P.S. This is with a Global GeoSIM, in the UK
> >>>> ==== LOG ====
> >>>> GPS Ready
> >>>> ATREG: 5
> >>>> OK
> >>>> AT+CGPSPWR=1;+CGPSRST=0;+CSMINS?
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> AT+CCID;+CPBF="O-";+CPIN?
> >>>> 89234185500007905230
> >>>> +CPIN: READY
> >>>> OK
> AT+IPR?;+CREG=1;+CLIP=1;+CMGF=1;+CNMI=2,2;+CSDH=1;+CIPSPRT=0;+CIPQSEND=1;E0
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"Orange"
> >>>> OK
> >>>> SHUT OK
> >>>> OK
> >>>> OK
> >>>> +PDP: DEACT
> >>>> ERROR
> >>>> OK
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> +CPIN: READY
> >>>> OK
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"TMO UK"
> >>>> OK
> >>>> SHUT OK
> >>>> OK
> >>>> OK
> >>>> +PDP: DEACT
> >>>> ERROR
> >>>> OK
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> +CPIN: READY
> >>>> OK
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"Orange"
> >>>> OK
> >>>> SHUT OK
> >>>> OK
> >>>> OK
> >>>> +PDP: DEACT
> >>>> ERROR
> >>>> OK
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> +CPIN: READY
> >>>> OK
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"TMO UK"
> >>>> OK
> >>>> SHUT OK
> >>>> OK
> >>>> OK
> >>>> +PDP: DEACT
> >>>> ERROR
> >>>> OK
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> +CPIN: READY
> >>>> OK
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"Orange"
> >>>> OK
> >>>> SHUT OK
> >>>> OK
> >>>> OK
> >>>> +PDP: DEACT
> >>>> ERROR
> >>>> OK
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> +CPIN: READY
> >>>> OK
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"TMO UK"
> >>>> OK
> >>>> SHUT OK
> >>>> OK
> >>>> OK
> >>>> +PDP: DEACT
> >>>> ERROR
> >>>> OK
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> +CPIN: READY
> >>>> OK
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"Orange"
> >>>> OK
> >>>> SHUT OK
> >>>> OK
> >>>> OK
> >>>> +PDP: DEACT
> >>>> ERROR
> >>>> OK
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> +CPIN: READY
> >>>> OK
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"TMO UK"
> >>>> OK
> >>>> SHUT OK
> >>>> OK
> >>>> OK
> >>>> +PDP: DEACT
> >>>> ERROR
> >>>> OK
> >>>> +CSMINS: 0,1
> >>>> OK
> >>>> +CPIN: READY
> >>>> OK
> >>>> +IPR: 9600
> >>>> OK
> >>>> +COPS: 0,1,"Orange"
> >>>> OK
> >>>> _______________________________________________
> >>>> OvmsDev mailing list
> >>>> OvmsDev at lists.teslaclub.hk
> >>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130930/51c05455/attachment.htm>
