[Ovmsdev] i-Miev/C-Zero/iOn
Matt Beard
matt at beard.tv
Wed Sep 25 05:52:58 HKT 2013
More strange behaviour with my C-Zero.
Trying to investigate charging current today I discovered that the car
would not charge for longer than a couple of minutes with the OVMS
connected (with Thomas' image loaded). It would start charging, then the
current would drop to zero, but the charge light stayed on. After a while
it stopped even trying to charge. Disconnecting the OVMS didn't fix it
until I also turned the car on and off again (with the OVMS not connected).
Did can noise cause problems again?
Matt
On Tuesday, September 24, 2013, Thomas Bergo wrote:
> The first models (2011) was delivered with a 16A cable. This was changed
> for the later models (2012 ->) to 10A cable do to firesafty.
> At home i use a 16A cable for charging, but the car only draw 13A.
> I'm not sure what is the correct info, EVSE limit or the charger limit.
> Any way the car will only draw 13A.
> The can message for current limit set by EVSE is not know for the i-Miev,
> so until this information is available we need to hardcode a value to be
> displayed in "STANDARD xxA" in the app.
> Regards, Thomas
> 2013/9/24 Håkon Markussen <hakon.markussen at gmail.com>
> Nice work Thomas,
> Your attached image reminds me that I should implement the car_time and
> car_parktime in the Think City module :-)
> Regards to max charge rate "STANDARD xxA":
> The variable car_chargelimit should contain the maximum available mains
> current, which is set by the EVSE.
> This is done in vehicle_thinkcity.c and I assume this can-message is
> available in a iMiEV and could replace the hardcoded "13A".
> The evse sends a pilot signal controlling the charger max rate, which can
> be adjusted by the user in steps depending on the evse type.
> The first evse's for iMiEV was delivered with two charging steps (maybe
> 10-16A) and got popular among Leaf-owners. Running up to 16A over the
> Schuko-connector is bad firesafety, so the later evse's were replaced with
> 13A. (I guess) limit max.
> This one is a nice one(mode 2, type 2 delivered with different charging
> connectors:
> http://salto.no/produkter/ladekabel-justerbar-13-a-type-2-shuko/
> When the max charge current is set by the evse, e.g. 13A the ac-charge
> current (which can be measured or viewed in a can-message) will never
> exceed this limit.
> Br.
> Håkon
> 2013/9/24 Thomas Bergo <thomas.bergo at gmail.com>
> I don't remember to have seen any documentation. There is a common
> understanding in Norway that the car only can drain 13A.
> I have also measured hove much current the car use when charging.
> This setting is only for information in the app, as no information is send
> to the car from the car module. There is no way that the car module can
> impact on the charge current. The voltage and current (13A) is reported by
> the car and not limited by the OVMS.
> [image: Innebygd bilde 1]
> Regards, Thomas
> 2013/9/24 Matt Beard OVMS <smvo at mxf.org.uk>
> Do you have a source for this 13A maximum claim? Mitsubishi claim that
> the on-board charger in the iMiev runs at 240V 15A in the USA.
> If you want to use the output rating of the charger you need to reduce the
> figure to 9A as the output is 330V.
> What does the Roadster version set - does it use the input current, or
> some version of the output current?
> I notice that the Volt/Ampera code sets 16A as the charge limit.
> Matt
> On 24 September 2013 19:58, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> The charger is only able to deliver 3 KW to the battery, so the car will
> maximum use 13A from the grid. I therefor hardcoded the charging to
> "STANDARD 13A"
> Regards, Thomas
> I think my hardware may have a dodgy connection as it is working again!
> I am using the hex file Thomas sent (one that failed yesterday!)
> I noticed that the charge level is reported wrongly. I am using a 16A
> charger (and the car does charge at > 13A) yet the C-Zero code is reporting
> the
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130924/c2ba28eb/attachment.htm>
