[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo
thomas.bergo at gmail.com
Wed Sep 25 02:18:14 HKT 2013
Thanks
Attached is the hex file compressed with rar
Regards, Thomas
2013/9/24 Michael Jochum <mikeljo at mac.com>
> Hi,
> i think it is NOT a good Idea to send a hex File plain.
> I sometimes receive and send some hex Files (AVR). They are ALL corrupt.
> It ONLY works (in my case) to zip or rar the hex and send this.
> Then they work ALL.
> The bad thing is that they can sometimes flash into the µC without crc
> error. But didn't work.
> Bye
> Am 24.09.2013 um 11:42 schrieb Matt Beard <matt at beard.tv>:
> I'm using a Global SIM.
> I may try the diag port if I can find something that reads RS-232 in this
> day and age! I must try and get a USB adapter.
> Matt
> On Tuesday, 24 September 2013, Nikki Gordon-Bloomfield wrote:
>> Great. In addition, you might want to try and attach something to the
>> diagnostics port. You should be able to read through the port any AT
>> commands, to make sure it's working correctly.
>> I believe there's a list somewhere of the messages you'll get from the
>> diagnostic port for that chip.. 901 is it? (I can't remember, but it's
>> what we used to diagnose the SIM card was at fault.)
>> Nikki.
>> P.S. What SIM are you using? Global? O2?
>> On 24 Sep 2013, at 09:16, Matt Beard <matt at beard.tv> wrote:
>> Actually, running it with stock firmware as OBDII in our ICE is next on
>> my list of checks.
>> Matt
>> On Tuesday, September 24, 2013, Nikki Gordon-Bloomfield wrote:
>> The other suggestion I would have is to plug the ODBII module into
>> another car -- or power it from a bench supply using the method detailed in
>> the development guide?
>> Nikki.
>> On 24 Sep 2013, at 08:08, Mark Webb-Johnson <mark at webb-johnson.net>
>> wrote:
>> Matt,
>> I have modules with me for replacement, if necessary.
>> I am concerned about your comments regarding soldering. All the v2
>> modules are supposed to be machine soldered, and we have had almost zero
>> returns of broken modules.I would be grateful if you could let me know the
>> serial number of your module, the approximate date you received it, and if
>> possible a picture of the soldering issues.
>> I too am perplexed why the module would work SMS but not GPRS. Perhaps
>> you can try setting the vehicle type to 'XX', which would eliminate any can
>> bus/message issues, and see if the problem still occurs.
>> Please eMail me, off list, as mark (at) openvehicles (dot) com, and I'll
>> work through this with you.
>> On 24 Sep, 2013, at 5:13 AM, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
>> Thanks Thomas,
>> That has confirmed for me that my hardware has died.
>> Looking at the circuit board the soldering on the GSM modem is shocking,
>> but I don't understand how it can work for SMS, but crash with GPRS. Looks
>> like I will be spending most of my effort in the coming days trying to get
>> the hardware replaced!
>> I have confirmed that the unit functions perfectly (though is pretty
>> useless) with the GPRS switch set to disabled. If it is booted with the
>> switch enabled it dies as soon as I set the GPRS parameters, then enters an
>> endless reboot loop.
>> Matt
>> On 23 September 2013 21:18, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>> Attached is the hex file, this is the exact same that is running om my
>> module now.
>> Regards, Thomas
>> 2013/9/23 Matt Beard <matt at beard.tv>
>> Thomas,
>> That would be really useful. I am worried that the module may have failed.
>> I did not keep a copy of the last working hex file (lesson learned!) but
>> did save the sources. Rebuilt from previous sources and loaded. It still
>> fails.
>> Matt
>> On Monday, September 23, 2013, Thomas Bergo wrote:
>> Matt:
>> I can send you the hex file i'm running in my OVMS module, so you can try
>> if that woking in your module?
>> Regards, Thomas
>> 2013/9/23 Thomas Bergo <thomas.bergo at gmail.com>
>> I did a rebuild from clean to ensure that i running the exact same code.
>> My OVMS module is booting as expected, and only the green led is blinking
>> OK (one blink]
>> Which version of the OVMS FW are you running? I have only tested with the
>> 2.5.2 FW.
>> Are there any significant changes from 2.5.2 that can impact the code to
>> constantly reboot?
>> Regards, Thomas
>> 2013/9/23 Matt Beard OVMS <smvo at mxf.org.uk>
>> OK - either this code is broken, or my OVMS is.
>> I flashed the code and set the unit up - no go, kept rebooting and the
>> GPRS does not work.
>> Rebuild from clean. Reflashed, reloaded settings and still constant
>> rebooting and GPRS does not work.
>> Matt
>> On 23 September 2013 10:24, Thomas Bergo <thomas.bergo at gmail.com> wrote:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130924/87b02eaf/attachment.htm>
Type: application/rar
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130924/87b02eaf/attachment-0002.bin>
