[Ovmsdev] i-Miev/C-Zero/iOn
Matt Beard
matt at beard.tv
Tue Sep 24 16:16:33 HKT 2013
Actually, running it with stock firmware as OBDII in our ICE is next on my
list of checks.
Matt
On Tuesday, September 24, 2013, Nikki Gordon-Bloomfield wrote:
> The other suggestion I would have is to plug the ODBII module into another
> car -- or power it from a bench supply using the method detailed in the
> development guide?
> Nikki.
> On 24 Sep 2013, at 08:08, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Matt,
> I have modules with me for replacement, if necessary.
> I am concerned about your comments regarding soldering. All the v2 modules
> are supposed to be machine soldered, and we have had almost zero returns of
> broken modules.I would be grateful if you could let me know the serial
> number of your module, the approximate date you received it, and if
> possible a picture of the soldering issues.
> I too am perplexed why the module would work SMS but not GPRS. Perhaps you
> can try setting the vehicle type to 'XX', which would eliminate any can
> bus/message issues, and see if the problem still occurs.
> Please eMail me, off list, as mark (at) openvehicles (dot) com, and I'll
> work through this with you.
> On 24 Sep, 2013, at 5:13 AM, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
> Thanks Thomas,
> That has confirmed for me that my hardware has died.
> Looking at the circuit board the soldering on the GSM modem is shocking,
> but I don't understand how it can work for SMS, but crash with GPRS. Looks
> like I will be spending most of my effort in the coming days trying to get
> the hardware replaced!
> I have confirmed that the unit functions perfectly (though is pretty
> useless) with the GPRS switch set to disabled. If it is booted with the
> switch enabled it dies as soon as I set the GPRS parameters, then enters an
> endless reboot loop.
> Matt
> On 23 September 2013 21:18, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> Attached is the hex file, this is the exact same that is running om my
> module now.
> Regards, Thomas
> 2013/9/23 Matt Beard <matt at beard.tv>
> Thomas,
> That would be really useful. I am worried that the module may have failed.
> I did not keep a copy of the last working hex file (lesson learned!) but
> did save the sources. Rebuilt from previous sources and loaded. It still
> fails.
> Matt
> On Monday, September 23, 2013, Thomas Bergo wrote:
> Matt:
> I can send you the hex file i'm running in my OVMS module, so you can try
> if that woking in your module?
> Regards, Thomas
> 2013/9/23 Thomas Bergo <thomas.bergo at gmail.com>
> I did a rebuild from clean to ensure that i running the exact same code.
> My OVMS module is booting as expected, and only the green led is blinking
> OK (one blink]
> Which version of the OVMS FW are you running? I have only tested with the
> 2.5.2 FW.
> Are there any significant changes from 2.5.2 that can impact the code to
> constantly reboot?
> Regards, Thomas
> 2013/9/23 Matt Beard OVMS <smvo at mxf.org.uk>
> OK - either this code is broken, or my OVMS is.
> I flashed the code and set the unit up - no go, kept rebooting and the
> GPRS does not work.
> Rebuild from clean. Reflashed, reloaded settings and still constant
> rebooting and GPRS does not work.
> Matt
> On 23 September 2013 10:24, Thomas Bergo <thomas.bergo at gmail.com> wrote:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130924/3090cded/attachment.htm>
