[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo thomas.bergo at gmail.com
Tue Sep 24 04:03:42 HKT 2013
I did a rebuild from clean to ensure that i running the exact same code.
My OVMS module is booting as expected, and only the green led is blinking
OK (one blink]
Which version of the OVMS FW are you running? I have only tested with the
2.5.2 FW.
Are there any significant changes from 2.5.2 that can impact the code to
constantly reboot?
Regards, Thomas
2013/9/23 Matt Beard OVMS <smvo at mxf.org.uk>
> OK - either this code is broken, or my OVMS is.
> I flashed the code and set the unit up - no go, kept rebooting and the
> GPRS does not work.
> Rebuild from clean. Reflashed, reloaded settings and still constant
> rebooting and GPRS does not work.
> Matt
> On 23 September 2013 10:24, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>> Have tested and fixed a lot of errors this weekend. and i believe that
>> the code is now in a state where it can be merged into the main project.
>> Have pushed a release 1.3 to my fork on GitHub.
>> Changes:
>> 1.3  23.09.13 (Thomas)
>> - Fixed charging notification when battery is full, SOC=100%
>> - TODO: Fix battery temperature reading.
>> 1.2  22.09.13 (Thomas)
>> - Fixed Ideal range
>> - Added parking timer
>> - Added detection of car is asleep.
>> 1.1  21.09.13 (Thomas)
>>  - Fixed ODO
>>  - Fixed filter and mask for poll0 (thanks to Matt Beard)
>>  - Verified estimated range
>>  - Verified SOC
>>  - Verified Charge state
>>  - Added battery temperature reading (thanks to Matt Beard)
>> 1.0  Initial release
>> Regards, Thomas
>> 2013/9/21 Thomas Bergo <thomas.bergo at gmail.com>
>>> Thanks to you all for participate.
>>> Managed to spend some time on this project yesterday and this this
>>> evening.
>>> Yesterday i was able to fix the ODO. And thanks to Matt i was able test
>>> the SOC, ideal range and Charge state.
>>> Added the battery temperature reading form Matt's code.
>>> My car is reporting range and ODO in Km, so added support to handle both
>>> miles and Km for ODO and Range based on can_mileskm.
>>> *"To receive all 0x3nn messages we could use filter SID 0x300 and mask
>>> 0x700, but I am worried that may cause a flood of messages."*
>>> The current code runs with this filter and mask, ans seems to be stable
>>> so far.
>>> Still see some errors with the ideal range and the temperature reading.
>>> The app is reporting PEM: -125C, Motor: 144C and Battery: 5C
>>> Pushed  the code with updates from Matt to GitHub.
>>> Regards, Thomas
>>> 2013/9/21 Michael Jochum <mikeljo at mac.com>
>>>> Hi,
>>>> You can only set the Mask and Filter in a Configuraton Mode.
>>>> From Datasheet:
>>>> 23.3.1 CONFIGURATION MODE
>>>> The CAN module has to be initialized before the activation. This is
>>>> only possible if the module is in the Configuration mode. The Configuration
>>>> mode is requested by setting the REQOP2 bit. Only when the status bit,
>>>> OPMODE2, has a high level can the initial- ization be performed.
>>>> Afterwards, the Configuration registers, the Acceptance Mask registers and
>>>> the Acceptance Filter registers can be written. The module is activated by
>>>> setting the REQOP control bits to zero.
>>>> The module will protect the user from accidentally violating the CAN
>>>> protocol through programming errors. All registers which control the
>>>> configuration of the module can not be modified while the module is on-
>>>> line. The CAN module will not be allowed to enter the Configuration mode
>>>> while a transmission or reception is taking place. The Configuration mode
>>>> serves as a lock to protect the following registers:
>>>> • ConfigurationRegisters
>>>> • FunctionalModeSelectionRegisters • BitTimingRegisters
>>>> • IdentifierAcceptanceFilterRegisters •
>>>> IdentifierAcceptanceMaskRegisters • FilterandMaskControlRegisters
>>>> • MaskSelectionRegisters
>>>> In the Configuration mode, the module will not transmit or receive. The
>>>> error counters are cleared and the interrupt flags remain unchanged. The
>>>> programmer will have access to Configuration registers that are access
>>>> restricted in other modes.
>>>>  I don't believe that it will work without bad sideeffects.
>>>> Bye
>>>> michael
>>>>  Am 21.09.2013 um 11:32 schrieb Matt Beard OVMS <smvo at mxf.org.uk>:
>>>> I may also try modifying the RX0 mask during the 1-second poll so that
>>>> it cycles through filtering a single SID each time, meaning that it will
>>>> take 4 seconds for a full update. I don't think this will be an issue as
>>>> none of this data is fast changing.
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130923/6f47b3ec/attachment.htm>
