[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo
thomas.bergo at gmail.com
Thu Sep 19 21:29:08 HKT 2013
Thank you for your attention.
This is the same information that i have:
SOC shuld be 0x374, byte 1. This I have confirmed using my laptop and the
CAN-Do SW.
I used the Think code as a template for setting up the filter and poll
interupts. So I belived that it shuld be a straight forward task to read
the messages.
I will post my filter setup and poll1 code later, I belive that you will
see what's wrong.
Regards, Thomas
torsdag 19. september 2013 skrev Nikolay Shishkov følgende:
> Hi Thomas,
> Here is some info on the messages that you can see on the Miev CAN bus.
> 0x210 - accelerator pedal
> 0x298 - trip meter
> 0x346 - range
> 0x373 - amps, volts
> 0x374 - SOC
> 0x389 - Amp, Volts
> 0x412 - speed, odometer
> 0x418 - shifter position
> 0x424 - switches and stuff - like lights, etc.
> 0x6E1, 0x6E2, 0x6E3, 0x6E4 - cell voltages, and temps
> Once you get familiar with the ovms, maybe you can find it easier to use
> the Twizy or the Think code, instead of starting from scratch.
> Hope this helps,
> Nikolay
> *From:* Thomas Bergo <thomas.bergo at gmail.com <javascript:_e({}, 'cvml',
> 'thomas.bergo at gmail.com');>>
> *To:* OVMS Developers <ovmsdev at lists.teslaclub.hk <javascript:_e({},
> 'cvml', 'ovmsdev at lists.teslaclub.hk');>>
> *Sent:* Thursday, September 19, 2013 9:01 AM
> *Subject:* Re: [Ovmsdev] i-Miev/C-Zero/iOn
> Yesterday I managed to verify that both poll0 and poll1 interrupt is
> called.
> Printed "car_idealrange =id;" from poll0 to see the PID's that triggered
> the interrupt. Only get id 768 (0x300) printed out.
> Also tried to do a the printout fom inside case 0x374: but no updates. The
> strange ting is that I can see a lot of "374" messages, and none "300" when
> using my laptop.
> Start wonder if the PID "374" that I find on my laptop is not a hex value?
> Any one here that has any experiance with CAN-Do SW for analysing CAN
> mesages?
> Will do some more testing later.
> Regards, Thomas
> onsdag 18. september 2013 skrev Mark Webb-Johnson følgende:
> Is there a simple way to print out a value to the DIAG port for debugging?
> You can just net_puts it, normally prefixed with a "#" sign as a comment.
> Have a look in diag.c for lots of examples. You will need to type 'ATE1'
> when going into diag mode, to get the echo output. The way it works is that
> you send the command to the modem (net_puts()), which discards it as
> unrecognised, but echos it back to the terminal.
> But, you can't do that in interrupt handlers - only in normal ticker(), or
> message handler, style code
> On 18 Sep, 2013, at 8:22 PM, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> Thank you for your help.
> Fixed some typos and now ODO updates in "STAT?" ODO is still wrong, but at
> least i get updates. No luck with SOC so far.
> Have verified that the PID and the data is correct by using a CAN
> interface on my laptop.
> Will do some more debugging to verify that both poll0 and poll1 is called.
> Regards, Thomas
> 2013/9/17 Mark Webb-Johnson <mark at webb-johnson.net>
> Thanks, Håkon - nice clear answer.
> One other suggestion is that you can put "car_idealrange++; return TRUE;"
> and "car_estrange++; return TRUE;" in the poll0 and poll1 functions, near
> the top. A few STAT commands and you can see if the poll functions are
> actually being called. You can also put "car_idealrange=id; return TRUE;",
> etc, to get an idea of what IDs are being delivered. It is very nasty
> trying to debug interrupt handlers, but this approach can help.
> The diag port mentioned is shown here:
> OVMS Setup Diagnostics Mode <http://www.youtube.com/watch?v=-24PoWtHVzk>
> On 16 Sep, 2013, at 4:55 PM, Håkon Markussen <hakon.markussen at gmail.com>
> wrote:
> Hi Thomas,
> *"Still has some debugging to do on the i-Miev code, as i'm only get
> "SOC: 0%" from STAT?"
> Are you able to read any CAN-bus values from your iMiEV?
> I experienced once at my Think City, that the Ovms-module did not read the
> CAN-bus at all; I got 0% SOC.
> The problem was I had two external CAN-devices connected at the same time
> (Duinomite Mega + OVMS). It worked fine when both modules were powered on
> at the same time, but Ovms failed to read the bus when the Duinomite Mega
> was powered off.
> Du you have access to any kind of can-reader tool? This can be used to
> verify that you are looking at the correct bytes.
> I've used P-CAN USB adapter
> http://www.peak-system.com/PCAN-USB.199.0.html?&L=1
> and PCANView
> http://www.computer-solutions.co.uk/gendev/can-basic-dll.htm
> You can use it to verify you have SOC in msg 0x374 byte 1.
> To understand the mask and filter, you have to consider the mask as a bit
> "enable" / "disable". Any zero in the mask bit disables that
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130919/2301efed/attachment.htm>
